Go to Post (pfft, kid... I sound like I'm Baker's age) - Amanda Morrison [more]
Unread 06-04-2004, 14:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Lightbulb Using an FRC with the RCX?
I was lieing in bed this morning when it hit me: Since the prog port is RS-232, and so is a computer, there is a chance you could connect LEGO's old COMM tower with the prog port on the RC or the EDU. You would probably need to make a custom cable, but it might work.
Basically, to control the RCX, you send it IR messages via the IR tower. From there it's a simple matter of programming the two.
The LUGNET thread for sending messages in VB can be found here.
Here's some FRC code to do it:
#define SendByte(Byte) {TXREG = Byte; Wait4TXEmpty();}
void SendRCXMessage (char Message)
	//Header
	SendByte(0x55);
	SendByte(0xFF);
	SendByte(!0xFF);
	//Opcode for Message
	SendByte(0xF7);
	SendByte(!0xF7);
	//Message Byte
	SendByte(Message);
	SendByte(!Message);
	//Checksum
	SendByte((0xF7 + Message) & 0xFF);
	SendByte(!((0xF7 + Message) & 0xFF));
The RCX, unfortunately, only has a 1 byte buffer for IR, so I thought of a 1 byte setup to set each motor to a certain speed.
The RCX has outputs A, B, and C. They can be Forward, Backward, or stopped, and have a speed of 1-8. This can be expressed as -8 to 8.
If you just want 2 motors, you can set both in the same byte in the range of -7 to 8. Use the first 4 bits for A and the second 4 for B. In NQC:
// A Basic RC Skid-Steer Program (Recieve)
#define mLeft OUT_A
#define mRight OUT_C
#define nOffset 7
#define nBit 16
int Left = 0;
int Right = 0;
task main()
 start GetMessage;
 start RunLeft;
 start RunRight;
task GetMessage()
 Left = Message() / nBit - nOffset;
 Right = Message() % nBit - nOffset;
task RunLeft()
 while (true)
  SetPower (mLeft, abs(Left));
  if (Left > 0) OnFwd(mLeft);
  if (Left < 0) OnRev(mLeft);
  if (Left == 0) Off(mLeft);
task RunRight ()
 while (true)
  SetPower(mRight, abs(Right));
  if (Right > 0) OnFwd(mRight);
  if (Right < 0) OnRev(mRight);
  if (Right == 0) Off(mRight);
(And yes, the RCX does support primitive multi-threading)
In the FRC:
void Set2RCXMotors(signed char Left, signed char Right)
 char Temp = 0;
 //Check Left value
 if (Left > 8)
  Left = 8;
 if (Left < -7)
  Left = -7;
 //Check Right value
 if (Right > 8)
  Left = 8;
 if (Right < -7)
  Left = -7;
 Temp = (Left+7) << 4;
 Temp |= Right+7;
 SendRCXMessage(Temp);
If you want to control all 3 outs directly, then you'll have to specify which one. The first 2 bits are what out, 3 is 0, 4 is direction, 5-7 are power-1, and 8 is "Is on?". So, in a nutshell: MM0D PPPOn.
On the RCX:
// A Basic RC 3 Motor control
int Left = 0;
int Center = 0;
int Right = 0;
task main()
 start GetMessage;
 start RunLeft;
 start RunRight;
 start RunCenter;
task GetMessage()
 int Mess;
 Mess = Message;
 //Left
 if ((Mess/64) == 1)
  if (Mess & 0x10)
   Left = ((Mess/2) & 8) & ((Mess & 1) != 0) ;
  else
   Left = -(((Mess/2) & 8) & ((Mess & 1) != 0));
 //Center
 if ((Mess/64) == 2)
  if (Mess & 0x10)
   Center = ((Mess/2) & 8) & ((Mess & 1) != 0);
  else
   Center = -(((Mess/2) & 8) & ((Mess & 1) != 0));
 //Right
 if ((Mess/64) == 3)
  if (Mess & 0x10)
   Right = ((Mess/2) & 8) & ((Mess & 1) != 0);
  else
   Right = -(((Mess/2) & 8) & ((Mess & 1) != 0)));
task RunLeft()
 while (true)
  SetPower (OUT_A, abs(Left));
  if (Left > 0) OnFwd(OUT_A);
  if (Left < 0) OnRev(OUT_A);
  if (Left == 0) Off(OUT_A);
task RunRight()
 while (true)
  SetPower(OUT_C, abs(Right));
  if (Right > 0) OnFwd(OUT_C);
  if (Right < 0) OnRev(OUT_C);
  if (Right == 0) Off(OUT_C);
task RunCenter()
 while (true)
  SetPower (OUT_B, abs(Center));
  if (Left > 0) OnFwd(OUT_B);
  if (Left < 0) OnRev(OUT_B);
  if (Left == 0) Off(OUT_B);
And on the FRC side:
void Set3RCXMotors(signed char Left, signed char Center, signed char Right)
 char Temp = 0;
 //Check Left value
 if (Left > 8)
  Left = 8;
 if (Left < -8)
  Left = -8;
 //Check Center value
 if (Center > 8)
  Left = 8;
 if (Center < -8)
  Left = -8;
 //Check Right value
 if (Right > 8)
  Left = 8;
 if (Right < -8)
  Left = -8;
 //Motor
 Temp = 0x40;
 //Direction
 Temp |= ((Left<0)? 0 : 0x10); //Ooooh! A Ternary!
 //Power
 Temp |= absdif(Left, 1) << 1;
 //Is On?
 Temp |= (Left != 0) & 1;
 //Again for the center
 //Motor
 Temp = 0x80;
 //Direction
 Temp |= ((Center<0)? 0 : 0x10); //Ooooh! Another Ternary!
 //Power
 Temp |= absdif(Center, 1) << 1;
 //Is On?
 Temp |= (Center != 0) & 1;
 //Again for the right
 //Motor
 Temp = 0xC0;
 //Direction
 Temp |= ((Right<0)? 0 : 0x10); //Ooooh! Another Ternary!
 //Power
 Temp |= absdif(Right, 1) << 1;
 //Is On?
 Temp |= (Right != 0) & 1;
There are obviously a few bugs to work out (I wrote this on the fly!), but I think you can get the idea. (My favorite NQC IDE, BrixCC, can be found Here.) I'll give every one a few hours to chug through that.
Unread 06-04-2004, 15:37
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Using an FRC with the RCX?
That'd probably work. It would be interesting, you could say, have the RCX in charge of controlling drive motors, leaving the RC free to determine where you want to go, etc. I have a Mindstorms set (plus all of the expansions (a few of them twice )), so I might find this and interesting thing to look into.
--EDIT--
Oh, yeah. NQC is good, but BrickOS (former LegOS) is better. BrickOS is also C/C++ programming, but everything is precompiled, not interpruted like with NQC and the default LEGo firmware.
Unread 06-04-2004, 16:27
AKA: Jamie Bliss
Plus, if you have an RCX v1, there is a 9-volt AC adaptor plug in the back (made for the train adaptors). So, connect the 12v Exide to a 12vdc-9vdc transformer, hook that up to the RCX, and you don't need to use 6 AAs!
Anyway, The connecting cable won't be standard: the tower is a Male with just enough space for the cable that came with the kit (No screws). The FRC prog is female. Both the FRC prog and the LEGO IR Tower (LIRT) are made to connect to a computer, so there are going to be problems if you just connect them directly. (Some good info on RS-232 can be found here.)
Using the jargon, we are trying to connect 2 DCE devices. Unfortunately, I only have pins for DTEs which is (DB9):
DTE
Pin   Purpose
 0  - Gnd (Shell)
 1  < DCD (Data Carrier Detect)
 2  < Rx
 3  > Tx
 4  > DTR (Data Terminal Ready)
 5  - Gnd (signal Ground)
 6  < DSR (Data Send Ready)
 7  > RTS (Request To Send)
 8  < CTS (Clear To Send)
 9  < RI (Ring Indicator)
    ^Direction (< = DCE to DTE, > = DTE to DCE, - = None)
So, to connect DCE to DCE (think of the FRC as the DTE):
FRC LIRT
Gnd Gnd
 Tx Rx
 Rx Tx
DSR DTR
DTR DSR
I'm not sure about the rest of it (RI, DCD, RTS, CTS). The problem is that there are 3 lines for DTE>DCE but there are 5 for DCE>DTE. And I don't want to fry my FRC or LIRT. Don't forget, the labels are relative to the DTE. If someone figures it out, tell us!
(The standard is RS-232.)
Unread 06-04-2004, 17:02
Programming User
I want to know why they got rid of it on v1.5 and v2.0.
I'm going to look up some info on the RC to computer protocol.
Unread 06-04-2004, 19:12
AKA: Jamie Bliss
Got it!
Thank you B&B Electronics!
FRC   LIRT
Gnd - Gnd
 Tx < Rx
 Rx > Tx
DTR < DSR
DSR > DTR
RTS < CTS
CTS > RTS
DCD X DCD
 RI X RI
Don't connect DCD or RI to anything.
The pins are as follows (DB9):
Shell Shell (optional)
    5 5
    3 2
    2 3
    4 6
    6 4
    7 8
    8 7
1 and 9 don't connect to anything.
So if anyone fries something doing this, please tell us before we fry something!
Unread 06-04-2004, 20:27
Programming User
LOL!
You'll have to wait until tomorrow for the info. Sorry.
Unread 07-04-2004, 01:48
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
Two questions:
1) What kind of hardware would I need on the receiving end to make this work?
2) Has anyone tried to accomplish this successfully?
Thanks, I would have never thought of trying something like this!
Shrenik Shah
Engineering Director
Team 115: Monta Vista Robotics
Congratulations to Mr. Shinta for winning Woodie Flowers at Silicon Valley!
Unread 07-04-2004, 06:04
Programming User
Originally Posted by Grommit
Two questions:
For the RC, you need a cable to attach to the LEGO IR tower. For the RCX, nothing. It has it's own built in IR.
I don't know of anyone.
Unread 07-04-2004, 07:09
Programming User
Here are a few links:
Packet description: (includes example of sending IR message)
http://graphics.stanford.edu/~kekoa/rcx/protocol.html
From this website, I think that sending:
55 ff 00 f7 08 M ~M C ~C
Where C is the checksum. Sends the messageM. One thing I'm confused on is the checksum. It doesn't seem to work the way I read it in his description. Even trying to figure the checksum using his example I didn't come up with the same thing he did. It may be I just don't understand it. If you kow, tell me how to compute it.
Some more stuff on the packets: (not as good)
http://graphics.stanford.edu/~kekoa/rcx/#Protocol
Do you need to know how to send that out, or do you already have that figured out?
--EDIT--
Here is a site with examples of using it in C++. http://www.generation5.org/content/2001/rob08.asp.
Reading that, it's a great site.
Unread 07-04-2004, 11:34
AKA: Jamie Bliss
Two questions:
LEGO's RCX. That's all (You may need the official firmware to get the message packets to work). At transmission, however, you need an old COM tower, not a new USB.
I don't think so. But it hasn't been very long. The hardest part would be the cable
Neither would I until yesterday!
Unread 07-04-2004, 11:51
AKA: Jamie Bliss
--EDIT--
The example from LUGNET was made for MSCOMM and VB. I just took the array and wrote the functions for the controller.
A message packet is only one additional info section.
Header (3 bytes)
OpCode (2)
Message (Info, 2)
Checksum (2)
The OpCode for Message is 0xF7. It has one argument: the message value. Every data byte is followed by it's not. So you get:
Header = 55FF00
OpCode = F708
Message = M ~M
CheckSum = (F7+M) & FF
I think we're finally getting it!
The second link is extremely helpful. And I'm glad to know about the Null-modem cable thing: The LIRT is CTE, not a CSE (it is a male, like your computer), so maybe a standard cable works!
Unread 07-04-2004, 13:19
Programming User
You said the prog port earlier, but how do we access that? Or, rather, can we get enough control to do what we want? You can send text, but I haven't studied the printf() access of the port. Maybe that port will work or maybe something else is necessary. Correct me if you know the way.
Unread 07-04-2004, 21:17
AKA: Jamie Bliss
Ok. The text is transmitted as bytes (I assumed ASCII, but I'm not sure). So basically, you replace the text with bytes. A string is an array of bytes terminated by a null characcter (0x00).
I looked in printf_lib.c I traced the flow of execution from printf(), and ended up at Write_Byte_To_Uart(). Which is:
* SUBROUTINE NAME: Write_Byte_To_Uart
* PURPOSE:       Writes a byte to the UART.
*     Argument       Type           IO   Description
*         data       int            I    data to transmit to the UART
* RETURNS:       void
static void Write_Byte_To_Uart(int data)
  TXREG = data;  /* a carriage return */
  Wait4TXEmpty();
I simplified it to the macro:
(And I don't actually know how to write macros!)
You call this repeatedly to write the whole packet.
Of course, You can't recieve: the LIRT only remains active for 3 seconds after you transmit something.
Also: this whole setup is unusual, so if it doesn't work, don't worry. We just may end up buying a pair of UART DTEs and making a double box!
Unread 08-04-2004, 06:28
Programming User
That's what I figured would work, but I wasn't sure. Don't do a lot of COMM port work.
And the macro looks fine.
Unread 08-04-2004, 12:53
AKA: Jamie Bliss
Neither do I. I just read the file. It's aparently easy!
FRC Program State Frozen at Power-up WillyC Control System 4 14-02-2004 18:05
Request for FLL Volunteers for FLL National Invitational at the FRC Championships Natchez General Forum 3 08-04-2003 12:19
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
