Go to Post Students leave and new students come. But mentors are forever. - fredliu168 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
I warn/penalize BLUE team for pinning 19 36.54%
I award Bluabot 50 points for hanging 31 59.62%
I award Redabot 50 points for hanging 6 11.54%
I do not award Bluabot any points for hanging 9 17.31%
I do not award Redabot any points for hanging 26 50.00%
I do something else ... please explain 4 7.69%
Multiple Choice Poll. Voters: 52. You may not vote on this poll
Unread 08-04-2004, 16:08
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: YMTC: Bluabot sits on Redabot
My idea (which probably throws away a few rules) is this:
  • Penalize bluabot for forcing redabot down (poor sportsmanship if nothing else)
  • DON'T give bluabot 50 points (penelty)
  • Give redabot 50 points (w/o bluabot, who was penalized, redabot would hang)
Unread 08-04-2004, 16:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I suppose I'll toss my pennies into the argument now..
For the record, this exact situation occurred at LSR, which is where I assume Lucien got the idea from. The call as made was that Blue WAS hanging and Red was NOT. I didn't discuss with the refs, but I assume the logic was as mentioned earlier. Red was touching, when red was removed, Blue was still hanging. There were no other penalties given, as Blue lowered itself very slowly.
I'll just comment real (not) quick:
Red is obviously not hanging, as it is touching the ground, so supported this and removing that is immaterial. if it couldn't lift in the first place because a robot was above it, but enough energy was stored to lift it when the offending robot was removed, it would seem very, very odd to suddenly give it 50 points. How Red has ended up touching is, I think, immaterial. Bringing that into the argument would so horribly complicate rulings that it is infeasible.
Blue obviously IS hanging, if it is still above the platform when Red is removed. The definition of supported clearly states that an object is supported, for FIRST scoring purposes, is the robot is no longer hanging when the supporting object is removed. Thus, by FIRST definition, red cannot be supporting Blue, despite common sense and physics and all that.
Pinning doesn't seem to be an issue here, unless Blue is resting so heavily on Red that Red is completely incapable of moving on the platform. If Red can move to the side, out from under Blue, then it is not pinned. This entire lowering episode is akin to a robot pushing another around on the field. If Team A pushes Team B around in the open field, it is not considered pinning. Atleast, I think it's patently silly to penalize A for pinning when B has the freedom to move away from A. In fact, I have never seen pinning called for such an action. The rule states that pinning is inhibiting a robot's motion. As I see it, this can be interpreted in only two ways: Totally inhibiting, so that a robot may not move at all in any meaningful sense; or partially inhibiting, ie. preventing a robot from moving in any particular direction. If the latter was the correct interpretation, any team could be penalized for pinning simply for getting in the way of another team for several seconds. So, I see dropping onto a robot as simply the vertical equivalent of pushing someone around.
Ahem. that was slightly longer than I'd intended, but I like to be thorough. For the record, my team was the dropping robot, and it won us the match, so I might be biased. I can also state that it was one of the most exciting matches outside of the elims at LSR, and the crowd had no complaints at all about the drama of one robot attempting to dehang another.
YMTC - No battery plugged-in SilverStar You Make The Call 15 10-04-2004 13:12
YMTC: Redabot grabs rail Natchez You Make The Call 10 10-04-2004 12:16
YMTC: Redabot accidentally breaks goal Natchez You Make The Call 9 10-04-2004 12:11
YMTC: Bluabot and Redabot hanging? Natchez You Make The Call 15 23-03-2004 01:42
YMTC: Bluabot dies while pinning Natchez You Make The Call 17 21-03-2004 11:33
