Go to Post When I encounter Dave at competitions and meetings, I find him to be kind, helpful, almost too nice. When I read his hints, I find him to be EVIL! - Ken Loyd [more]
Unread 08-04-2004, 16:08
ufa_mike ufa_mike is offline
AKA: Mike Deaves
#0865 (Warp 7)
ufa_mike has a little shameless behaviour in the past
Cool Making your robot drive easier
I have noticed that all teams who consistently win don't have a complicated design but seem to drive well. SO I sugested to the team we just make a robot that drives and drives well, this year. But I'm not quite sure whet else to do to make it drive easier. Other than making a really solid gearbox with no slop. And ramping the controls.
any ideas?
Unread 08-04-2004, 16:10
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Making your robot drive easier
any ideas?
less c.o.f. wheels so with that spiffy nice gear box in high gear you could turn very easily.. or make omni wheels! Yay! omni wheels
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 08-04-2004, 16:17
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Intuitive controls. Even if you have a complex drive system, if you have a simple/intuitive control system your drivers will be able to drive it.
And practice, lots of practice.
Here's an example (idea taken from some bots, controls from an arcade game):
A bot has four wheels. each has its own drive motor. Each can also spin a continuous 360 degrees (Can spin forever without reversing). Complex drive.
On the control side: 2 joysticks. One for the left, one for the right. Each side goes the direction the joystick is pointed. Up means forward, down means backwards, left means left, right means right. U.L. means 45 degrees to the left from forward. The farther from center, the faster it goes. Front/back wheels are linked in code.
This control system is simple, and follows a standard skid-steer setup (with some mods). however, you can translate (go left/right w/o rotating) by pointing the the joysticks that way. So basically, you can make your robot dance, or rotate while moving forward (advanced technique).
Granted, this sort of set-up would take lot's of practice. lots and lots.
Unread 08-04-2004, 16:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
I'm going to disagree with PitBull a little bit...
I think the key to an easy-to-drive drivetrain is having the optimal lateral coefficient of friction (not the lowest). That is much easier said than done, but here is why I feel this way:
1) If you have too much lateral friction, your drivetrain will not turn well (or maybe not turn at all). This is obviously not desirable for many reasons that everyone knows, so I'm not going to explain further.
2) If you have too little lateral friction, the robot can become difficult to drive. Why? Inertia!
When your driver let's go of the stick, the robot will continue to turn. The amount of excess turn is inversely proporional to the amount of lateral friction you have. If you have too little friction, the robot becomes hard to control since the driver will let go of the stick where he/she want the robot to stop turning, and the robot will overshoot past the stopping point. This can be overcome with a lot of practice, but the whole point of this thread is to make a robot that doesn't require as much practice to drive.
Over the years, we have had robots that had very little lateral friction and I will definitely say that they were our most difficult robots to drive. Once we went to 4-wheel drive, the robots would stop turning the instant the driver let go of the stick - these robots were very easy to drive.
So, the moral of the story is: less friction is not always better. There is an optimal amount of friction - good luck achieving it.
Unread 08-04-2004, 16:24
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
Make a really solid gearbox. I find that you don't need any more then 2 speeds. High and Low. Also you can have wheels with a high C.O.F but to make your bot turn easier you need to 6 wheel drive and lower the middle set of wheels about 5 thou lower then the other ones and there you have a killer drive system.
Student: Team 22
Mentor: Team 4
Unread 13-04-2004, 21:11
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Thumbs up Re: Making your robot drive easier
SNIP
I would really like to hear more about this idea. Anybody make a six wheeled robot with all wheel drive??? I saw team 418 at the Lone Star Regional but didn't get an up close look at their drive. I was more impressed with their ball catcher and laminated wood biggens ball arms
post some pics or PM me or send a link to your site with photos
Thanks,
next year.
APS
aschuetze@sbcglobal.net
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 13-04-2004, 21:21
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
Team 233 has a 6-wheel all drive system. I'm assuming, when you say 6-wheel all drive, you simply mean all wheels are drive wheels.
Anyway, each side is linked to a joystick for tank driving. The middle wheels are lowered just a bit to give us the ability to turn well, and the friction of six wheels sitting on the ground makes us very hard to push sideways. I don't think our team will ever change from this 6-wheel setup (unless we get a radically different game from FIRST).
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Originally Posted by Andrew Schuetze
SNIP
Thanks,
next year.
APS
Here's a link to the 47 robot who uses a sweet 6 wheel drive with chain drive on each side team 47's bot
and here is the 254/60 "bionic poof" with their 6 wheel drive with the middle ones lowered a little bit
i think, correct me if i am wrong, that 25 was one of the teams that most successfully implemented this last year and many teams have used similar ideas.
Penn Class 08
Unread 13-04-2004, 21:45
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
We had a 6-wheeled robot this year...I don't know whether it was six-wheel drive though. It took us a few days to get the middle-axle lowering set the right way, but it helped a LOT. Oh I should tell you that we used some spiffy donated tracks, and it made us look like an R/C tank out there.
Robo pics and videos are here: http://www.sau53.org/net9/First/media.htm
You may also see the team at PARC in May. I wish I could go, but I'm going to Washington D.C. that weekend :-C
I haven't updated my signature since last May. Who wants to suggest a replacement?
Unread 13-04-2004, 22:24
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i posted a pic of our 6 wheel drive train. theres some stuff in the way, but you can still see most of it.
http://www.chiefdelphi.com/forums/pi...gle&picid=7644
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 13-04-2004, 22:38
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Watch your speed. I saw some teams build robots that were incredibly fast, but I can just imagine the nightmare those drivers go through whenever they try to do something rather than getting from point A to B.
Unread 14-04-2004, 07:16
feedback - PID control loop on the steering
using the default code to let the position of the joysticks control how much voltage (pwm) is thrown at the drive motors is as crude a control method as you can get (well, there is one thats worse, only having a GO/STOP switch :^)
no matter what your drivetrain is if you put yaw rate and/or linear speed sensors on the bot, and use feedback, you can remove all the nonlinearitiy, inertia, friction.... from the control system and MAKE the bot do exactly what the driver is commanding at any given instant.
another idea is to add a 'jog' function to your control system - I posted stuff about this before - let me search and see if I can find it...
yep,heres the thread - BTW it contains several other simple ideas on how to make your bot better:
http://www.chiefdelphi.com/forums/sh...&highlight=jog
Unread 14-04-2004, 07:45
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Let me elaborate a little. We used the brecoflex tracks this season. They have and awesome amount of friction (cof ?). The problem we had was we could turn because they spread out on the floor 26" and was only 21" wide. To solve the we put a larger we wheel in the center reducing the amount of track on the ground by about 45% in either direction. This gave us just the right amount of track on the ground to turn and allowed us to move alittle faster.
If you have any questions about it PM me or IM me.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 14-04-2004, 08:38
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
if you are really looking for a good team's drive that uses 6 wheels, check out team 42. for the past 4 years they have gone with the same drive, and its really worked out well for them.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 14-04-2004, 10:23
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Best way to drive well.......... have a great driver! A great driver can overcome and drive system.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Team Communication - Making it easier Balbinot Website Design/Showcase 3 10-02-2004 13:50
What motors do you use to drive your robot? _GP_ General Forum 25 25-01-2004 21:14
Rookie team drive tream idea Max Lobovsky Technical Discussion 18 21-01-2004 03:36
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
