#16
Re: Using an FRC with the RCX?
2 updates:
1. Found gray cable setup. Code:
GRAY CABLE Rx Tx Tx Rx DTR DTR Gnd Gnd RTS CTS CTS RTS Code:
From front: 1 2 3 4 X X 5 6 X 1 2 4 3 X X 6 5 X Get the idea? 2. What's the TTL output? I was thinking of the possibility of connecting through that. The prog port is used for so much else! |
#17
![]() Quote:
#18
I know that its probably more fun to reverse-engineer it, but have you guys thought about talking to LEGO for the specs? I know that they sponsor team 96 and I think their mindstorms engineers work with them.
#19
Why? all the reverse-engineering and spec-finding has been done for us. The most reverse-engineering I've done yet is putting a continuity tester to the original gray cable! And RS-232 has been standardized to death, so it's the easiest protocal to use (at either end!).
#20
The TTL port uses the same transmission format as RS-232 (low start bit, 8 data bits, high stop bit). So if you take a 3-pin cable and attach it the Tx, Rx, and Gnd pins on a DB9 female connector, you can use TTL port instead of the prog port. The macro would need to be changed slightly.
Odd, ifi_utilities.c and printf_lib.c both use 'TXREG', but ifi_picdefs.h defines 'TXREG1' and 'TXREG2'. |
#21
Use this cable for connecting to the LIRT:
LIRT TTL/Dig DB9F 1x3 Connectors (2x) Tx TTL.Rx Rx TTL.Tx Gnd TTL.Gnd RTS Dig.Sig CTS Dig.Gnd The Pin Equivalents are: Code:
3 TTL.Red 2 TTL.White 5 TTL.Black 7 Dig.White 8 Dig.Black Specific info on what to send can be found in the Mindstorms SDK. (Use v1.5 I believe) |
| FRC Program State Frozen at Power-up | WillyC | Control System | 4 | 14-02-2004 18:05 |
| Request for FLL Volunteers for FLL National Invitational at the FRC Championships | Natchez | General Forum | 3 | 08-04-2003 12:19 |
| Controlling a FIRST robot with a Lego RCX Controller? | archiver | 2001 | 5 | 24-06-2002 04:19 |
