Re: Galileo scouting
Team 1359 The Scalawags:
Awards/Honors: (all are from the Pacific Northwest Regional) Rookie All-Star Highest Rookie Seed (#2!!) Imagery Award Robot Strengths: -Hangs from the bar VERY consistently -uses autonomous to knock off yellow 10pt ball -herds balls -2 speeds -gets up and over all steps, no prob -can be driven from front or back -hasn't broken down yet!! How we made these strengths: -Arm pulls up the robot with two 80lb pneumatics. The joint is worked by a rack-and-pinion device powered by the window motor. -To herd balls, there are flaps that come down over the front and back with one powered by a small pneumatic kicker device to get the balls into the corral. -We got the two speeds by designing a transmission that is powered by a drill motor. It shifts on the fly allowing us to go a regular speed and really fast. There are two motor-transmission assemblies on the robot. -16in wheels allow us to get up the steps -A switch allows us to have either end be the front http://www.chiefdelphi.com/forums/pi...&quiet=Verbose |
-Team 263
-Sachem Aftershock -SBPLI quaterfinalist, NYC 11th seed Semifinalist -2x ball handler -2 section arm, each arm section has 180 degrees of movement. Lower arm section driven by van door motor, upper by window motor. -Pneumatic claw (to grab 2x ball) -can cap/uncap any goal, Fast and acurate -5 pt. ball gatherer -"Wings" rotate out from sides of bot w/ 270 degrees of movement -"wings" driven by globe motors - 2 rear wheel drive -Front HDPE skids - 4 or 8 ft per sec. (4 ft w/ electric speed reduction (via programming and speed controller) controlled by driver, used at end of match when capping) Grabbing 2x ball Going for the cap (stationary goal) Holding the 2x ball Capped the stationary goal |
Team 469
Las Gurrillas 2 wheel drive 2x Ball handler (can cap stationalry and mobile goals, cna pick up from any location) small ball collector ( multi roller system for collection of up to 16 balls) small balls ejected quickly from a back door and ramp to guide balls into corral, balls are rarely lost from a side quick and efficient hook, has never lost a goal yet climbs 6" step 4 gripper system on arm Please come visit us at our pits, or email me (diaval9000@yahoo.com) if you have any questions. Natasha |
Team 537
Charger Robotics Awards: *St. Louis Regional Winners*, *Midwest Judges Award*, *St. Louis Autodesk Visualization Award* Main Task: 2x handler (Both cap/uncap of Movable and Stationary goal) Very Good Ball Herder, *God bless teflon cookie sheets *4 wheel Drive with Atwood motors and custom gearboxes autonomous: knock either 10 pt., ready to grab 2x off movable goal, push goal into opposing human player corral. thats about all i can think of right now... sorry couldnt find a pic, maybe ill post one when i can find one. |
So... It's not the best picture of 537, but it's something. |
Team #365: The Miracle Workerz featuring GizMOE
Hanger/2x Ball handler Can cap/decap Mobile and Stationary goal Hang from mid or top platform 2 motor/4 wheel drive powered by Bosch Drill motors Pop-down omniwheels for turning. Variety of Autonomous programs http://www.chiefdelphi.com/forums/pi...&quiet=Verbose |
#7
Team 358
Robotic Eagles Semi & Quarter finalists 2X ball handler - cap/uncap stationary goal, mobile goal, robot Mobile goal handler Hang from floor 4-wheel drive - drills & CIMs - 9.5fps autonomous: Play with mobil goal, knock off 10pt ball gyro/encoder controlled Command script programming Last edited by Mark McLeod : 12-04-2004 at 12:51. |
| San Jose Scouting online...may help at Nationals | MaxM | Scouting | 6 | 08-01-2005 19:24 |
| Championship Event Scouting Database? | Ricky Q. | Scouting | 5 | 13-04-2004 06:50 |
| NEW! Excel spreadsheet for scouting uploaded | GreenDice | Championship Event | 1 | 08-04-2003 22:01 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| WASH scouting fields | Mike Soukup | Scouting | 0 | 04-02-2002 02:39 |
