Go to Post What is this, presto change-o rules every week? - Racer26 [more]
Unread 10-04-2004, 12:17
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Question Parallax: What version?
Question: What version of the PBASIC Stamp editor did you use last year? and what other info do I need to know about last year's EDU/Controller? (seeing as InnovationFIRST.com is down, I can't look at the legacy docs)
Thanks!
Unread 10-04-2004, 14:17
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Parallax: What version?
Any version of the editor works. The other things you need to know depend on what you are doing with the Stamp. Default code should be enough for most applications.
Robot Inspector
Unread 10-04-2004, 15:33
AKA: Jamie Bliss
Ok, what stamp was used in last year's EDU and controller? The new editor (v2.5) isn't compatible with BASIC Stamp 1. I wasn't around, so I don't know.
Unread 10-04-2004, 15:51
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
BS2sx is what you are looking for?
Unread 10-04-2004, 15:53
AKA: Jamie Bliss
Yes, big thank you!
Unread 10-04-2004, 17:26
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Anyone know how you can program pic's using pbasic. I have read books that says you can I just haven't found anything yet.
Unread 10-04-2004, 17:40
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
It's not actually "PBASIC", as that's property of Parallax, Inc. There're third-party compilers for PicBasic (in various combinations of capitalization). Some are free, some are not. Google "picbasic", and you'll find some.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 10-04-2004, 17:57
AKA: Jamie Bliss
Of course, I nearly misspelled "Parallax". I accidently stuck in 2 Rs! Try going to www.parrallax.com
DISCLAIMER: follow url at your own risk!
Parallax Stamp DIED!!! Carl Owenby Programming 1 16-02-2003 14:44
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
Parallax Basic Stamp Workshop archiver 2000 1 23-06-2002 22:08
Parallax is OUT : DrJoe is IN archiver 2001 5 23-06-2002 22:05
