Go to Post You need to stay on top of your classes or you will be back as a returning freshman on next year's team. - [more]
Unread 06-04-2004, 20:44
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Re: Going over 6 inch step with 12 inch wheels
Originally Posted by Al Skierkiewicz
Joe,
I think if you watched closely, the robot front tires are actually being pushed into the step edge. The resulting force combined with the turning ability of the tire results in the tire climbing the edge. The robot front wheels would climb even if they weren't powered. (Think of a bike going up a curb.) There is just more point friction on the front tires. Lowering the air pressure in the rear tires should help quite a bit. Some teams have added some friction enhancers, i.e. teeth or grippers, to the tires. These grip the edge during climbing and do not allow the tires to slip on the platform edge. I have seen grippers mounted right on the tire and on a wheel attached to the tire.
Thanks for all the replies from everybody.
You Guys are the best.
Joe P
Unread 10-04-2004, 01:11
Grommit Grommit is offline
#0115 (Monta Vista Robotics)
Grommit will become famous soon enoughGrommit will become famous soon enough
Send a message via AIM to Grommit
I have a similar question about the smaller wheels:
We were considering replacing our dysfunctional swerve drive with a wheel setup that might actually give us the mobility to perform on the field. We were wondering if it might be feasible to, at the same time, climb up the steps. So my question is, can we manage to clim the 6 inch step with 8 inch wheels, given that we have a 3 inch foot? I know that theoretically, we should be able to, because with the foot down, the center of our 8 inch wheels are over 7 inches off the ground, and with a little shove, we should be up. I was wondering if anyone actually tested this themselves, as this would help us decide between what replacement we should select.
Shrenik Shah
Engineering Director
Team 115: Monta Vista Robotics
Congratulations to Mr. Shinta for winning Woodie Flowers at Silicon Valley!
Unread 10-04-2004, 01:27
Aaron's Avatar
Aaron Aaron is offline
FRC #3719 (Whaler Robotics)
Aaron is on a distinguished road
Send a message via AIM to Aaron
it's probally a balance problem, we had the same problem until we decided to flip the sticks around and drive the robot backwards. when we got the weight to the front we got up fine
Team 3719 - 2013-Present
2014 RI District Judges Award
Team 1493 - 2007
2007 UTC Connecticut Regional 2nd Seed and Semi- Finalist
Team 11 - 2001-2005
2005 New Jersey Regional Chairmans Award Winners, Palmetto Autodesk Visualization Award Winners, Palmetto Judges Award Winner
2004 Palmetto Regional winners of DiamlerChrysler Team Spirit Award, Palmetto Regional Winners(281, 11, 122), Curie Division 5th seed (11, 190, 179)
2002 J&J MidAtlantic Regional Finalists, Canadian Regional winners of the Xerox Creativity award
Unread 10-04-2004, 18:49
Mel's Avatar
Mel Mel is offline
Retired Scalawag President
#1359 (The Scalawags)
Mel is on a distinguished road
Send a message via AIM to Mel Send a message via MSN to Mel
My teams robot has 4 16in wheels and we found that putting extra weight on the front helps. Also, we keep them all a little deflated but it took a while to find what the optimum amount of air was. Maybe during practice rounds you could experiment with the pressure a little; make sure to have the same amount on either side or you won't be able to drive straight!
2004 PNW Rookie All-Stars
2004 PNW Highest Rookie Seed (seed #2!)
2004 PNW Imagery Award
Unread 10-04-2004, 19:01
Brandon Holley's Avatar
I don't know if you guys have any type of arm, but thats the key. In NJ, our robot would bounce and bounce and bounce for about 40 seconds until it got up the ramp, and then we had to do it all over again...wasn't pretty. This way was with the hook in the back. Next match we turned the bot around and extended the arm in front of our robot, we were on the top step hanging in 15 seconds...the start of our success.....try it with an arm if not...might i recommend zip ties and pneumatic tubing....
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-04-2004, 21:14
Combat Chuck Combat Chuck is offline
Team Role: Scout
Combat Chuck is on a distinguished road
If you guys can get the front wheels on easily and are having trouble with the back wheels, have you considered using a small piston on the back end to lift the rear of the robot enough to clear the platform. If you lift the back of the robot, you can pull the robot forward with the front wheels until the back wheels are on the platform, then retract the piston and continue on.
2004 Peachtree Regional Finalists
2003 GA BEST Champions
Unread 10-04-2004, 21:51
We also use 16" wheels, and had a little trouble getting up the step. We added some weight to the front (on the bottom) and now have no trouble. A lot of the other suggestions are good too, if you don't have weight to spare.
Unread 10-04-2004, 21:53
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
My team quickly realized that so much can happen on the platforms. (tested out our tread drive subsystem and flipped every time) What I would suggest is add another 2 feet to your arm/hanging mechanism so that you can hang from the floor. We have a light (4 lb) 12' telescoping arm, the extra 2 feet was well worth it for us. I realize this might not be possible, but just tossing another idea out.
Unread 10-04-2004, 22:21
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
for all teams that have problems with turning and the like - in the future, use 6 wheel drive. all your problems will be solved
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 11-04-2004, 00:15
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Originally Posted by jjdebner
This may sound silly. But if you reduce the pressure in the tires to get more traction then if it is a four wheel drive system won't it jerk and jump when turning alot more. So it is basically a trade off between turning and climbing. Unless you have "special wheels". So just make sure you can still turn when you have some pressure taken out.
We use a pnuematic cylindar with a delrin skid on the end to lift the robot's rear two wheels while turning. This enables us to have a 3 point turn, 2 being powered, the other being a skid. The piston ONLY engages (theoritically) during a turn, as defined by software. While going foreward (i.e. pushing, climbing), all four kit wheels are engaged on the ground for full torque/traction.
Definetly take some pressure out of the tires to climb. I'm also thinking more weight towards the front of the robot will help. We've found its not so much the diameter issue on the wheels, but the traction the tires get on the diamond plate. Our robot could climb up the side of a diamond plate wall until it reached the point where it would flip (around 12" high). By decreasing the pressure, you'll increase surface area of the wheel against the diamond plate. More surface area = more traction = more climbage (climbage a word?...dunno..)
If what I said makes sense, ALRIGHT! If not, lemme know!
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 12-04-2004, 11:15
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
My team looked into doing this early in the year, here was our ideal. Put a skid leading to the back wheels, and put the weight in the front, creating a fulcrum along the skid, the weight on the front wheels will pull the front wheels to the platform, and pull you up the step. Simple, yet effective.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
