Go to Post I love math... :D - Eric W. Jones [more]
Unread 12-04-2004, 13:07
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Re: White Paper Discuss: Karthik's Championship Event Data
Whoa now, like Karthik said already, if a team doesnt like how the awards or accolades factor in, they can always change the values of the statistics. This spreadsheet isnt punishing anyone, its only meant as a tool to help. As such, no one is obligated to use it, or believe in its data management system. 188 is ranked pretty low in Archimedes, but that cant be helped. I realise the situation is a little bit different with your robot actually winning a regional and all, but lets try to keep in mind that this is a tool and not an official ranking of the robots coming to the event. Im sure everyone will have an ace or two up their sleeve
Woburn Robotics, Class of 2005.
Unread 12-04-2004, 16:36
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Originally Posted by ThirdRide
True, the third robot is not always as strong as the first two. BUT, that is already reflected in the qualification matches. Our point total after the qualification matches was lower than our partners. There is no reason why we should be punished again for something unrelated. We are being punished in our winning the regional for our average performance in the qualification matches. One had nothing to do with the other and that should be reflected in the point system.
Remember what rourke said about the SCAM ratings: the name was intentionally chosen to make sure few people take it seriously. These statistics are the same way: helpful in some ways for determining, roughly, what teams did well at regionals, but not a value judgment of your robot or your team. You aren't being punished for anything, and teams aren't being rewarded for anything; it's just a number. Go in and mess with the spreadsheet on the regional specific pages to change the scores, and adjust it until you feel it's right, then use it for your scouting purposes.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 12-04-2004, 17:02
Documentor Documentor is offline
#0967
Documentor is an unknown quantity at this point
Just a quick note, Team 967 won and Team 16 have the awards swapped on the spreadsheet (impressive work, btw). We, Team 967, were awarded teh GM ID and BBS teh Driving Tomorrow's Tech. Not that is it matters much, but just a note of clarity. Sadly, out alliance partners are not in out division....
Unread 13-04-2004, 00:24
Who's John V-Neun?
AKA: Alex Baxter
Ummm, OK I was looking over it again, and...are you sure you got the standard deviations right? There are several SDs that are greater than the mean score, which seems to ring wrong with me (I haven't taken stats but +- 1 SD is about 2/3 of the data, right?). Did you forget to square root on some of them?
Still very impressive.
~Alex Baxter
Unread 13-04-2004, 01:01
The standard deviation is only 2/3 of the data when the data is gaussian (also called normal or bell shaped curve). The score's of most team's matches is no where near a bell shaped curve, and so that doesn't hold. I checked the numbers for team 970 at OH, which was one of the teams where the standard deviation was higher then the mean, and the calculations were correct.
(standard deviation)^2 = (sum(xn - mean)^2)/(n-1)
You can use this webpage to do the calculations for you: http://www.physics.csbsju.edu/stats/...NROW_form.html and this page has explanations of a bunch of different statistical measurments: http://www.physics.csbsju.edu/stats/descriptive2.html
Unread 13-04-2004, 08:17
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I just used Excel's standard deviation function. I did a spot check of about 15 entries, and they looked alright. If you find any specific entries that are wrong, let me know.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
White Paper Discuss: All I Ever Needed to Know I learned in FIRST poster CD47-Bot Extra Discussion 5 28-03-2005 15:44
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: Interrupts for Dummies CD47-Bot Extra Discussion 5 29-01-2005 03:24
White Paper Discuss: Use of Gyros in Navigation, Tip Prevention, and Driver Control CD47-Bot Extra Discussion 1 18-03-2004 08:36
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
