Go to Post Never allow your students to get away with an answer that amounts to "because it's better". Have them prove it to the best of their ability, and when they're wrong, ask them to figure out why they're wrong. - Tom Line [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-04-2004, 20:27
HFSbF5 HFSbF5 is offline
HFSbF5 is on a distinguished road
Re: LED flashers
I think that the LED's were a good change. They definitely saved weight, although you could save more if the cables were only about 6" long to start with, then you could use extensions if needed (4' is excessive).
The LED's definitely need to be brighter, but that gets to be tough in SMT LED's. 5mm LED's can be so bright that they blind you, so you would have to use something to diffuse them or use diffused LED's (the lens assembly would probably do the trick, just as in the flashers that certain teams have as souvenirs). (We could use 2 Luxeon LED's behind the lens and that would definitely do the trick!)
They definitely take less energy to power, probably ~200 ma in a short pulse rather than an amp or so constantly for the revolving light (I think that's what it took).
It would be good to have the LED's flash more all the time, because that would make them seem brighter.
It would also be easier to mount if it was designed to be like a rotating light--an all-in-one, cylindrical unit that only has one set of wires.
'Program State' LED stays blinking yellow after download clynch Control System 5 18-02-2004 19:34
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
LED colors archiver 2001 1 24-06-2002 00:04
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
