Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 19-03-2002, 18:29
Steve Prairie's Avatar
Steve Prairie Steve Prairie is offline
Alumni
#0173 (RAGE Robotics)
Steve Prairie is on a distinguished road
Send a message via AIM to Steve Prairie
Exclamation Battery Weight
Hey all,
When we weighed in at the LI Regional (with a 2002 battery) we were exactly at 130.00lbs! (we like to cut it close) One of our engineers had the idea to weight all of our batteries individually. This uncovered a suprising result. Our 2002 batteries were .8lbs HEAVIER than our 2001 batteries! So before you pull out the hole saw, you might want to try all of your batteries.
Just a thought...
Unread 19-03-2002, 18:33
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Weird -
Ours were the other weigh around. (bad pun - sorry)
The old batteries outweighed the new ones by more than a pound.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 19-03-2002, 21:22
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
I think that there are at least two different kinds of batteries from the 2001 season, and maybe two this season. I'm sure that different manufacturers batteries weigh different.
Unread 20-03-2002, 17:08
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
The new batteries have a higher amperage rating this year. This may be why they weigh different also you may want to see if they had shorter battery connector or less eletrical tape or somthing like that.
Andrew
Unread 25-03-2002, 07:29
Those who have several years of batteries laying around will notice that this year's battery has a significant change in the topside design, and different (larger) output connectors.
Good Luck All
Unread 10-04-2002, 11:26
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
Good Luck All
Our 2002 batteries were substantially similar to out 2000 and 2001 batteries, except they had an extra half an amp hour in the rating, and they are gray instead of white. The terminals are the same.
Also, I would recommend that teams use the newest batteries in competition. Less-used batteries generally have more capacity that well-used batteries.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Weigh in with or without battery Joe Clohessy Rules/Strategy 33 21-09-2003 20:31
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
