Go to Post a robot is never finished... It can always be redone and improved. - EricVicenti [more]
Unread 10-04-2004, 10:17
Billfred's Avatar
Billfred Billfred is offline
Re: Switching the Channel for Competition
Alright, I think I'm up for building a dongle for our team. But since I'd rather not fork over $1200 for a new OI, I figured I'd ask and make sure my wiring scheme would work. It's attached. (I'm sorry about the .bmp--my computer is a pain in the booty.)
Any tips for building one (other than to be careful and don't short anything out)?
Unread 11-04-2004, 01:02
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
This is perfect. When I build them, I use a 3-position switch for the Disable and Autonomous function instead of using two switches. It will work fine with 2 switches though.
It's really not difficult to make ... and even if you do screw up, chances are you wont completely fry your OI. I've accidentally shorted the wrong pins a few times, and we've never lost an OI. We had one start acting weird ... but a reboot fixed it right up.
Good luck.
Unread 11-04-2004, 01:08
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Originally Posted by Ian W.
We wanted some blue LEDs flashing, so I jammed a paperclip in the right pins (I looked them up), played with the channal dipswitches, and got it set to 13. Now we have blue LEDs.
It's not that hard, just don't do anything dumb ;-).
Real risky with the paper clip, We lost a OI CPU messing about with not up to specs wiring practices. Some of the pins on the Comp port go directly to the CPU in the OI and it clearly states that you fry things messing with the port and there is no warrenty. More than 150 dollars including the overnight shipping. As the Innovation First Service Tech said, triple check your wiring before stabbing on to the Comp port.
Unread 11-04-2004, 01:15
AKA: Tom Cooper
There is a doc on the Innovation First Web site that lists the pin outs. I'm having trouble getting to thier site right now so I will attach the PDF
Unread 11-04-2004, 11:49
Billfred's Avatar
Thanks for the input.
I noticed on my sketch that I just had 8 and 12 hooked together directly for channel access. IFI's has a switch to enable/disable this. Is there any advantage either way?
And I'm just thinking out loud--if those are all the pins one needs to do autonomous and disabling and channel setting, how hard would it be to create a rudimentary arena controller? Just run the wires for four dongles to one central spot, perhaps add a timer to the disable circuit, and bada-bing! (I figure that even the channel -shouldn't- matter, since the RC checks for team number as well. Of course, it wouldn't hurt to give each robot their own channel in matches.)
Now for my final question: where on earth do you get those DB15 connectors? I checked my local Radio Shack, then their site. No luck either place.
<edit> And I'm just curious, since my team is always looking for easy sources of bling (is reminded of the team's initial idea to stick strobe lights in the metal 2x4s)...is there enough power going through these pins to send juice to an LED (or similar device) indicate that said pins are connected? </edit>
Thanks again!
Unread 11-04-2004, 17:25
KevinB's Avatar
AKA: Alum
There is absolutely no advantage to using a switch ... don't use one.
You are correct, this would be reasonably easy.
The channels absolutely must be different. Even with the team number check, the packets will still interfere with each other.
You should have received several in the Kit of Parts. Otherwise, check www.digikey.com
Unread 11-04-2004, 22:31
Billfred's Avatar
(checks digikey)
Good heavens, that's a lot of parts. Can anyone point me to a particular item number or some other method for the non-electrical genius?
And I know I asked this before, but I've got a hunch it got overlooked: Is there an easy way to hook some sort of LED or similar object that indicates that a certain switch is on?
Thanks again!
Unread 11-04-2004, 23:25
KevinB's Avatar
AKA: Alum
(checks digikey)
Digi-Key Part Number 215M-ND.
Thanks again!
Yes, this is possible. I don't know the specific details, but I know it involves using Pin 1 to get power.
Unread 12-04-2004, 09:02
A safe method is to simply use a DPDT switch from Radio Shack and a 9 volt battery ignoring the power pin altogether. Hook up the competition port pins to one side of the switch and an LED/resistor/9volt to the isolated DPDT pins on the other side of the switch. When the switch is "on" the LED will also be "on", but the LED is actually on a separate circuit powered by the 9v battery.
This is probably the normal method most teams use for LEDs on the OI.
Unread 13-04-2004, 10:29
Billfred's Avatar
Okie doke...so now my wiring diagram has grown to this...(see attached)
A note on the switches...I was thinking, and while it's smart to have a nice, big, mash-the-red-button-to-stop-that-robot disable button, it isn't as good for autonomous mode, as then if you mash it, you'll probably be disabling the sucker anyways. So I figure that the disable switch will be alternate action (either DPDT, or perhaps two separate switches activated by the same button), and then the autonomous switch would be more light-switchy in activation. (I wired in the LED so that you can tell pretty easily whether or not the disable switch is activated without having to decipher the OI. Maybe I'll make it a buzzer, to make it really obvious. Saves having to troubleshoot the stupid stuff, I figure.)
Although, given my tackling by our robot when it leapt into autonomous the last build night, I'm tempted to take a cue from our ROTC corps' F-16 simulator and make it like the nuclear consent switches--you know, lift the flap that holds it off, and THEN you get to flip the switch and launch the nukes. Or start autonomous mode. Your choice.
Switch choices and ergonomics of the box aside, any comments on the updated wiring scheme?
Unread 13-04-2004, 10:57
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
i would suggest putting a resister in between the 9volt battery and the positive lead on the LED. Also since LED's are a diode, LED's have a distinct positive lead. Normally the longer lead coming from the LED is the positive lead.
-Michael Dessingue
Unread 13-04-2004, 11:09
Wiring looks fine, just make sure you are looking at the correct side of the connector when you wire it together. The view you have is looking at the front of your Digi-key soldercup connector, not the back where the wires connect.
[edit] LEDs with integral resistors came in the robot kit, or Radio Shack carries them. As dez250 says you'll need a resistor in series or you'll burn out the LED rather quickly.
Unread 13-04-2004, 13:11
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
You're right, it is quite simple if you have teams set their own channel. For this past year's miniFIRST competition, we just wired up a connector to some telephone line, and had a three position switch for autonomous and disabling on the other end.
It is even possible to build a more complex system. The person who wrote the current official FIRST scoring software is an alum of Team 190, and while on the team he was working on making his own system that would interface with his scoring software. I don't think he finished it before he started working for FIRST, but it definately looked possible.
Zan Hecht
Unread 13-04-2004, 14:24
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
It's not hard to do. We've made a system for our practice field that is computer controlled and allows individual stations to be controlled, as well as real matches with all 4 starting in autonomous then transitioning to normal mode at the correct time. There's a big time display on a monitor so the drivers can get used to watching the clock, and we even have the sounds nicely integrated and all. It makes for some fun (and realistic) practices!
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
Science Channel 2004 FIRST Video Ralph Lambert General Forum 26 22-10-2003 20:20
Channel 1 News archiver 2001 0 24-06-2002 03:08
Robots and the Learning Channel.... archiver 2000 0 24-06-2002 00:16
New First Robotics Discussion IRC channel Andrew Wyatt General Forum 10 07-12-2001 06:25
