Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Unread 13-04-2004, 21:21
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Making your robot drive easier
Originally Posted by Andrew Schuetze
SNIP
I would really like to hear more about this idea. Anybody make a six wheeled robot with all wheel drive??? I saw team 418 at the Lone Star Regional but didn't get an up close look at their drive. I was more impressed with their ball catcher and laminated wood biggens ball arms
post some pics or PM me or send a link to your site with photos
Thanks,
next year.
APS
aschuetze@sbcglobal.net
Here's a link to the 47 robot who uses a sweet 6 wheel drive with chain drive on each side team 47's bot
and here is the 254/60 "bionic poof" with their 6 wheel drive with the middle ones lowered a little bit
i think, correct me if i am wrong, that 25 was one of the teams that most successfully implemented this last year and many teams have used similar ideas.
Penn Class 08
Unread 13-04-2004, 21:45
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
We had a 6-wheeled robot this year...I don't know whether it was six-wheel drive though. It took us a few days to get the middle-axle lowering set the right way, but it helped a LOT. Oh I should tell you that we used some spiffy donated tracks, and it made us look like an R/C tank out there.
Robo pics and videos are here: http://www.sau53.org/net9/First/media.htm
You may also see the team at PARC in May. I wish I could go, but I'm going to Washington D.C. that weekend :-C
I haven't updated my signature since last May. Who wants to suggest a replacement?
Unread 13-04-2004, 22:24
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i posted a pic of our 6 wheel drive train. theres some stuff in the way, but you can still see most of it.
http://www.chiefdelphi.com/forums/pi...gle&picid=7644
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 13-04-2004, 22:38
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Watch your speed. I saw some teams build robots that were incredibly fast, but I can just imagine the nightmare those drivers go through whenever they try to do something rather than getting from point A to B.
Unread 14-04-2004, 07:16
feedback - PID control loop on the steering
using the default code to let the position of the joysticks control how much voltage (pwm) is thrown at the drive motors is as crude a control method as you can get (well, there is one thats worse, only having a GO/STOP switch :^)
no matter what your drivetrain is if you put yaw rate and/or linear speed sensors on the bot, and use feedback, you can remove all the nonlinearitiy, inertia, friction.... from the control system and MAKE the bot do exactly what the driver is commanding at any given instant.
another idea is to add a 'jog' function to your control system - I posted stuff about this before - let me search and see if I can find it...
yep,heres the thread - BTW it contains several other simple ideas on how to make your bot better:
http://www.chiefdelphi.com/forums/sh...&highlight=jog
Unread 14-04-2004, 07:45
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Let me elaborate a little. We used the brecoflex tracks this season. They have and awesome amount of friction (cof ?). The problem we had was we could turn because they spread out on the floor 26" and was only 21" wide. To solve the we put a larger we wheel in the center reducing the amount of track on the ground by about 45% in either direction. This gave us just the right amount of track on the ground to turn and allowed us to move alittle faster.
If you have any questions about it PM me or IM me.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 14-04-2004, 08:38
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
if you are really looking for a good team's drive that uses 6 wheels, check out team 42. for the past 4 years they have gone with the same drive, and its really worked out well for them.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 14-04-2004, 10:23
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Best way to drive well.......... have a great driver! A great driver can overcome and drive system.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 14-04-2004, 14:20
Bob's Avatar
Bob Bob is offline
AKA: Robert Kennedy
FRC #0084 (Chuck 84)
Bob is an unknown quantity at this point
Send a message via AIM to Bob Send a message via Yahoo to Bob
You could aso check out team 25. They have had a great 6 wheel drive system for the last two years.
Team Communication - Making it easier Balbinot Website Design/Showcase 3 10-02-2004 13:50
What motors do you use to drive your robot? _GP_ General Forum 25 25-01-2004 21:14
Rookie team drive tream idea Max Lobovsky Technical Discussion 18 21-01-2004 03:36
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
