Go to Post It is great to see your friends and other teams succeed. - Bob Steele [more]
Unread 13-04-2004, 23:44
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Need info on gears inside drill transmission.
I'm curious why you want this info. Are you trying to replicate the gear sets?
If you're just trying to run another motor through the drill transmision, say the Fischer Price, I might know exactly how to do that and have prints ready to send you . We just pulled the drill gears using a bearing seperator and pin on an arbor press, then amade adapter shafts.
The reason I ask is as mentioned we adapted the drill trannies for use in this year's bot because we needed the high reduction over a short distance/small space for the FP's.
If I'm off base in my guess as to what you're doing please let me knowlet me know.
Unread 14-04-2004, 00:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I was just wondering what they were because I wanted to take them out of there and find another use for them. I didn't have a specific use in mind, I was more just curious. I was thinking to maybe stick one on an FP, but not to run the FP through the drill tranny. Nonetheless, I would like to see some details or something on how you ran the FP through the drill tranny, it sounds intriguing.
If anyone does have the info on those gears, I sure would like to know.
Unread 14-04-2004, 01:08
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Actually, this sounds really interesting to me. would you be willing to e-mail me those specs? I have no clue if we would ever even use something like that, but having more options is always good. Thank You
Unread 14-04-2004, 01:16
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Thought THIS may help.It's not for the motor directly but info on part numbers for the drill assembly and a place to order them rather cheaply.
Also, THIS PAGE on FIRST's website may have some usefull specs as well you can look over.
Unread 14-04-2004, 01:24
I remembered that the powerpoint on disassembling that thing (on the first spec sheet page) shows the gears so I was able to count the teeth. It doesn't look like any of them will work for what I had in mind. But I'm still glad I found out how many teeth they have. Maybe I'll get a new idea.
Does anyone know if it is possible to take a gear with a certain bore, weld the bore closed with filler, and then drill a new bore that is smaller? Would this work? Or instead of welding, what about pressing in a pin and then re-drilling it out?
Unread 14-04-2004, 10:57
I have a whitepaper ready to post on how to adapt the FP to the dril. Had more time than I thought today. However, I need to post the print I made as a tif. This format is disallowed by the Delphi system. If I convert it to a JPG I lose too much resolution for it to be legible. If anyone can help with this please let me know.
Unread 14-04-2004, 11:01
Possible yes. Advisable no.
We made a stepped adapter shaft to accomplish this. One end presses into the pinnion gear and the other presses over the motor shaft. We have had no problems with this and I suggest it as an alternitive to what you mentioned above.
Drill Motor Transmission Help aznbomber Motors 12 09-03-2004 20:38
CAD of Bosch drill motor transmission? Crazy Inventor 7 21-01-2004 12:03
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
What is it ESSENTIAL to do to a drill transmission... Iain Motors 12 04-02-2003 21:56
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
