Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 15-04-2004, 17:25
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Thumbs up Re: Spazing Robot
Originally Posted by kmcclary
5) Stacking order: Place the FAN wires on the screw FIRST, THEN an "internal star lock washer", THEN the power wiring. All Reds go on the "+" screw, All Blacks go on the "-" screw. Reattach the screws. From the BOTTOM UP, your stack should now be: Frame contact on Victor, POWER lead wiring, internal star lock washer, FAN lead wiring, screw head.
I would appretiate comments on what I understand to be a new idea for our team in regards to wiring of the cooling fans on the Victor's.
The above post is suggesting that the wire leads from the fan atop the SC be wired directly to the power terminals of that same Victor? If this is the case, have teams using this wiring scheme every had issues with inspection?
I really like the idea as it cleans up the nest of wires around the controllers. We have always ganged two or more cooling fan sets of leads to single female spade connectors and taken then to a circuit breaker panel and run them off of a single 20 amp breaker.
Thanks for your input in advance and the excellent idea if it jives with FIRST rules.
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
Are you willing to let others take picture of your robot? Ken Leung Robot Showcase 21 10-04-2002 22:50
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
