#16
Re: pic: 254 Drivetrain
Just a guess, but I am willing to bet it wasnt intended to be like that (if it truely is more than just an optical illusion). My guess is that their tensioning devices have a tendancy to pull the sprocket side of the axle closer to the gearbox (in essence making it look like the wheel is pointing inward) I would guess it is partially due to the way they canteliver the wheels out, but also the way the chain is wrapped on the inside sprocket and how the wheel is moved on slotted mounts to tension it) When I took a "close" look at 254's robot, I did not notice it at all. I would be willing to bet it was not intentional if it was anything more than an optical illusion... 254/60 care to enlighten us? |
#17
Thanks for the help, Lucien |
#19
There is no toe in unless something got bent, maybe I had better check! But seriously no toe in or out is not required to make the robot maneuverable.
The six wheel drive is the best system we have found so far it is simple, light, maintenance free, very little loss of horse power due to mechanical friction, and you will get the same traction as any other system. Many people think you get better traction with a track system, not true. The only two things that effect traction are weight and the coefficient of friction of the treads. Surface area is not part of the formula. Ask your engineer. |
#21
Correct me if I'm wrong, but doesnt surface area matter in instances when the tread material deforms a surface such as carpet, and "interlocks" (for lack of a better word) with the individual fibers?
Cory |
#22
There were a couple of very good white papers posted by IBApril180 about this a while back that address this question. Here are the links. http://www.chiefdelphi.com/forums/pa...le&paperid=120 http://www.chiefdelphi.com/forums/pa...le&paperid=119 |
#23
would it be possible for 254 or 60 to post a white paper about their drivetrain? of course...i guess I can always see it in NEWTON! or just e-mail me information
collinfultz@att.net |
#25
We don't plan to generate a white paper on the transmission, due to focusing on our collaboration white paper. However you are welcome to any of our drawings as well as an invitation to unlimited questions. Please stop by our pits (60/254) at the Nationals and we would be happy to answer any of your questions. You can also see the working model. ![]() |
#26
I'm wondering how 60/254 packed their solenoids together sooo tight.....is there room for the hose/fittings....can anyone elaborate...?
#27
Hope that helps! |
#28
How did you make your tires, or did you order them? Specifically, the wheels and not the waffle treds.
#30
They made them. I believe it was explained elsewhere, but they are 3 separate pieces. The hub, and then the two side plates that sandwich the hub. By design, the two pieces trap the tread in the wheel well, so that screws aren't needed to fasten it.
| pic: team 254 teaser | CD47-Bot | Robot Showcase | 10 | 02-03-2004 10:06 |
| pic: team 254 teaser | CD47-Bot | Robot Showcase | 4 | 07-02-2004 09:37 |
| pic: Team #461 Drivetrain | CD47-Bot | Robot Showcase | 8 | 05-03-2003 08:07 |
| pic: Team 254 Robot Cart (1 of 3) | CD47-Bot | Extra Discussion | 3 | 28-02-2003 16:51 |
| 254 The Best Partner in FIRST | sfield | Regional Competitions | 5 | 03-04-2002 23:23 |
