Go to Post "I want to be like them. We will strive to be like them. Lets get started! :D " - Rion Atkinson [more]
Unread 09-04-2004, 02:51
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: pic: 254 Drivetrain
Originally Posted by sanddrag
Yes, I know all about the 6 wheel drive and the center one being a little lower. It is just like a Home Depot shopping cart. What I was asking though is if the 4 outer wheels have toe in. On Kingman's bot, it did appear to have about 2 degrees of toe in per wheel (or "toe out" depending on your perspective of front and rear of the vehicle)
Just a guess, but I am willing to bet it wasnt intended to be like that (if it truely is more than just an optical illusion). My guess is that their tensioning devices have a tendancy to pull the sprocket side of the axle closer to the gearbox (in essence making it look like the wheel is pointing inward) I would guess it is partially due to the way they canteliver the wheels out, but also the way the chain is wrapped on the inside sprocket and how the wheel is moved on slotted mounts to tension it)
When I took a "close" look at 254's robot, I did not notice it at all. I would be willing to bet it was not intentional if it was anything more than an optical illusion...
254/60 care to enlighten us?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 09-04-2004, 02:58
phrozen solyd's Avatar
phrozen solyd phrozen solyd is offline
AKA: Adrian Santos
#0254 (Cheesy Poofs)
phrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nicephrozen solyd is just really nice
Send a message via AIM to phrozen solyd
I can't speak for Kingman's bot, but on ours, the wheels don't normally toe out like that. Unless the chains are overtensioned - we noticed this on Saturday at SVR, and fixed it soon after.
- Adrian Santos
Team 254, the Cheesy Poofs
Unread 09-04-2004, 04:37
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
Posted by phrozen solyd
The treads are held into the wheels with screws.
How do you cap the screws? Do you countersink them? We tried all kinds of things last year but we could never convince ourselves that we weren't violating the "Traction devices may not have surface features such as metal" rule. Plastic fasteners were not as good as glue. Of course, that's not what the four students that went around with their fingers stuck together for two weeks thought.
Thanks for the help,
Lucien
Unread 09-04-2004, 09:43
Dennis Jenks Dennis Jenks is offline
It's good to be home.
FRC #0254
Dennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud ofDennis Jenks has much to be proud of
Lucien
If you look at the wheels you can see that they are of two piece construction. Each side has a small lip on it so that when they are sandwiched together they grip the tread and keep it in place. The wheels are tapped and we use a pair of small pan head screws, not to hold the tread down but simply to keep the tread pulled tight. These are positioned so that they sit in the waffle well below the tread. If you are using screws to physically hold the tread down then you would need to use a larger head which may not sit deep enough to pass inspection.
Dennis Jenks
FIRST Team 254 Mentor
Unread 09-04-2004, 10:46
Glenn Glenn is offline
#0060 (Bionic Bulldogs)
Glenn has a spectacular aura aboutGlenn has a spectacular aura aboutGlenn has a spectacular aura about
There is no toe in unless something got bent, maybe I had better check! But seriously no toe in or out is not required to make the robot maneuverable.
The six wheel drive is the best system we have found so far it is simple, light, maintenance free, very little loss of horse power due to mechanical friction, and you will get the same traction as any other system.
Many people think you get better traction with a track system, not true. The only two things that effect traction are weight and the coefficient of friction of the treads. Surface area is not part of the formula. Ask your engineer.
Unread 09-04-2004, 17:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Correct me if I'm wrong, but doesnt surface area matter in instances when the tread material deforms a surface such as carpet, and "interlocks" (for lack of a better word) with the individual fibers?
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 09-04-2004, 18:10
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Cory
Glen is right as far as he goes. But sometimes the co-efficient of friction varies with either the load or the load divided by the area. This usually happens in systems where something is deforming enough to be noticable. Generally these interactions are also non-linear and need to be quantified emperically. At least that is easiest for our type of systems.
There were a couple of very good white papers posted by IBApril180 about this a while back that address this question. Here are the links.
http://www.chiefdelphi.com/forums/pa...le&paperid=120
http://www.chiefdelphi.com/forums/pa...le&paperid=119
Christopher H Husmann, PE
"Who is John Galt?"
Unread 09-04-2004, 18:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There definitely was some toe at Phoenix. I'm willing to bet it is what Travis said above.
Unread 10-04-2004, 00:06
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
would it be possible for 254 or 60 to post a white paper about their drivetrain? of course...i guess I can always see it in NEWTON! or just e-mail me information
collinfultz@att.net
Collin Fultz
Unread 10-04-2004, 01:01
SteveK254 SteveK254 is offline
Engineer
SteveK254 will become famous soon enough
Send a message via AIM to SteveK254
collinfultz@att.net
Hi Collin,
We don't plan to generate a white paper on the transmission, due to focusing on our collaboration white paper. However you are welcome to any of our drawings as well as an invitation to unlimited questions. Please stop by our pits (60/254) at the Nationals and we would be happy to answer any of your questions. You can also see the working model.
Unread 18-04-2004, 23:20
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
I'm wondering how 60/254 packed their solenoids together sooo tight.....is there room for the hose/fittings....can anyone elaborate...?
Unread 18-04-2004, 23:29
Engineering Mentor
FRC #0254
It is a SMC solenoid manifold. It is available through any SMC distributor (Motion industries etc). It has a common pressure input, and has ports for the solenoids on top and quick disconnect fittngs on the side, 2 for each solenoid. Block off plates are available if you decide to remove a solenoid or cannot purchase a small enough manifold. (in our case we needed ports for 7 solenoids, and thus had to purchase an 8 port manifold, we blocked off the 8th port) I think they come in manifolds of 2 and larger (maybe 4, I can't remember) and I recall them being in multiples of 2.
Hope that helps!
-Travis Covington
Unread 20-04-2004, 00:32
Originally Posted by SteveK254
Hi Collin,
i'm terribly sorry that I didn't get to see the model...i was either talking to judges, trying to shoot balls, or ogiling over the HOF displays...plus i didn't see your post until today. if there is any other way to get the information, digital pictures, gearing ratios, or anything else that would be great...thank you!
Collin Fultz
Unread 04-05-2004, 12:28
magnetnerd's Avatar
magnetnerd magnetnerd is offline
AKA: Brett
#1364 (RYOBI KMHS Robotics)
Team Role: Student
magnetnerd is on a distinguished road
Send a message via AIM to magnetnerd Send a message via Yahoo to magnetnerd
How did you make your tires, or did you order them? Specifically, the wheels and not the waffle treds.
Do not meddle in the affairs of nerds, for they are subtle and quick to anger.
Unread 04-05-2004, 12:50
Cory's Avatar
AKA: Cory McBride
They made them. I believe it was explained elsewhere, but they are 3 separate pieces. The hub, and then the two side plates that sandwich the hub. By design, the two pieces trap the tread in the wheel well, so that screws aren't needed to fasten it.
2001-2004: Team 100
pic: team 254 teaser CD47-Bot Robot Showcase 10 02-03-2004 10:06
pic: team 254 teaser CD47-Bot Robot Showcase 4 07-02-2004 09:37
pic: Team #461 Drivetrain CD47-Bot Robot Showcase 8 05-03-2003 08:07
pic: Team 254 Robot Cart (1 of 3) CD47-Bot Extra Discussion 3 28-02-2003 16:51
254 The Best Partner in FIRST sfield Regional Competitions 5 03-04-2002 23:23
