Go to Post So when a team leader decides to give all their heart to a team, it is true love that they exhibit towards it. - Anton Abaya [more]
Unread 19-04-2004, 21:48
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
scottm87 is on a distinguished road
What is the true field infrared emitter?
I was at the IR seminar at nats (which, BTW, was awesome considering it was both organized and presented by some students), and one of the issues that came up was reflection of the IR off field components. A team (sorry, forgot the number) described to me some tests they did on the field, where they found that the IR on the true field was so much more powerful, that reflections were much more common than with the relatively low power emitters given in the kits...
My question is: What is the actual emitter used on the field? Where can you purchase it? If I do any more IR development, I would like to mimic as closely as possible the true field conditions, and this is very important.
Unread 19-04-2004, 22:03
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: What is the true field infrared emitter?
My uneducated info is that they are the same except that the actual field one has 7 emiters not 5. There is also a aluminum backing on the field one were as most teams had none. I personally tested at 3 regionals and found that there were differences between locations. There was reflections all over the place and I proved to those with me that you could not lock onto the beacons. i hope that they that this info back to FIRST. I will be contacting FIRST about this and a few other items so that next year will be even bettter. I hope this helps.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 19-04-2004, 22:17
REVving up for a new season
FRC #2848 (All-sparks)
i know for a fact that they use the edu-bot for the emitter and it's location is underneith the first "sticker" under the field control module in the player station
Unread 20-04-2004, 07:32
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
There have been a few posts about the reflections on the field. I also know that there are about 5 seperate fields (and sets of support equipment) that are shipped around for regionals.
Unread 20-04-2004, 18:22
Kevin Watson's Avatar
La Caņada High School
FRC #2429
It's a Lumex OED-EL-1L2, the same device you got in the kit.
-Kevin
Kevin Watson
http://kevin.org
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Could the field be ice? dez250 Rumor Mill 15 03-01-2004 18:54
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
Lego field wanted--URGENT!!! David Kelly General Forum 0 19-11-2001 12:17
