Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 21-03-2002, 13:31
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Need help Importing Autocad >DWG files
I am using Autodesk Inventor R4 and when I try importing the Drill Motor Transmission Mount Autocad .DWG into a drawing file
I get a blank drawing. Can anyone help??
Unread 21-03-2002, 16:19
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
heres what you do...
if the autocad drawing is a 3d model:
open inventor..
goto the add-in manager and turn on dwg
then make a new part and import in the dwg solid.
THen you can make a new idw with the model in inventor
Gabe
Unread 21-03-2002, 17:18
Add-In manager
OK?? the add-in manager does not list dwg to turn on
It has DSS Monitor Add-in and Fasteners listed
Importing inventor files to 3ds max.... I found it!!!!! Tyler Olds 3D Animation and Competition 0 21-01-2003 19:16
Multiple files usage punarhero Programming 2 12-01-2003 11:45
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
AutoCad compatibility archiver 2000 4 23-06-2002 22:51
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
