Go to Post ...I tried to pump it up to the 47 inches. I stopped around 42 inches, than tried getting it through a 36" door. It got stuck, I proceeded to dropkick the thing in front of my team and a girl I had gone out with the previous Fri. It didn't move, I hit the floor. Ouch, my pride. - ChrisMcK2186 [more]
Unread 21-04-2004, 19:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Limit Switches help.
Or just cover them up. It's an engineering bug, not a software bug. But good idea.
? 127 : Joy_1 is a short-hand If-Else. In the form of A ? B : C, If A is true than the ternary returns B, else it returns C. It's also really nice for macros.
The pair of If's is for bottom and top. And Aliases are a must for many things.
PS- When do you stop being a beginner C programmer and move up to the next level? This is my fist real use of C.
Unread 21-04-2004, 21:18
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Hahaha, i thought that was a sarcastic joke before reading the second sentence. Maybe it should have been though. In programming, like everything else in life (though probably more so) people have there own ways of doing things (and obviously think thats the best or right way). Mike doesn't like to use ternary operators while some others do. Though a ternary operator can be somewhat harder to read than an if-else statement, it is useful in many situations because the entire if-else can be in one line. In my opinion, if you understand the concept, have seen properly written and used and examples, and are comfortable with it, then go right ahead. The best part about programming, especially with small simple programs, is that it is pretty easy to try stuff out yourself, so don't hesitate. Follow these guidelines and you should level-up in no time
Team 1257
Unread 21-04-2004, 21:21
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Thats good to know, im working on a program for auton that needs theese switches so as soon as i get ahold of the robot again im going to try what ever i can.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Raising the $3500 limit? Eric Bareiss General Forum 25 01-04-2004 03:15
Limit switches Team168 Programming 8 10-02-2003 16:22
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
Need help with custom switches archiver 2001 3 24-06-2002 00:35
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
