Re: Who used IR this year?
Team 122 used the IR sensors quite successfully this year ... the IR sensors never really caused us problems, we were lined up every time, but from time to time our pots would malfunction, which is what we depended on to knock the ball down (we had quite an elaborate procedure due to space, actually). I don't know what future IR will have... but odds are it'll be a pretty big role in next year's game. So far as reflections, and FIRST needing to do more testing, I don't know about this. A lot, I think, depends on how you house the IR sensors, making sure internal reflection and viewing angle is minimized -- I don't think the original setup with the heat shrink will cut it. Though for more complicated things, I suppose, more precision will be required. Though we never had any problems, we also designed our system so it didn't have to be real precise.
Team 503 used the banner sensors to follow the line to the ball. It worked very well after we got it adjusted to the correct speeds. We did not even consider the IR sensor as an option. And luckly we didn't b/c we were very very close to 130.
Our sensors were shielded and worked perfectly on our practice field. At the different regionals I was at I used the IR tester that was at each event to prove that the field beacons worked. By turning the sensor around you could see were the different beams were coming from. I could get readings from both sides when facing away from the beacons. There were times were I could pick up the beacon behind me but not the one in front. The people testing with me were slightly baffled so I am not sure on how they did their initial tests.
We had an IR system to get us to the 10 pt ball, with a sensor on one wheel as a backup distance counter. We didn't use it much because there were usually other things we needed to do during autonomous. I think we used that mode three times at Championships and it worked properly twice.
They keep telling us that IR will be important next year, so development of a good IR system is a big summer project this year. The sensors in the kit were designed for remote control of consumer electronics, so they are designed to convert any signal above the detection limit into digits for the TV. To deal with an environment where signal strength matters for finding the beacon rather than a reflection, we need an analog output from our detector. Does anyone know of a detector that has the amplification, agc, and demodulation of the kit sensor but produces an analog output proportional to the strength of the IR input? I'd prefer to avoid reinventing the wheel. Thanks, Greg |
We wanted to use the IR sensors on our robot for this year, to make autonomous a little bit easier. We got them to work on our robot, but there was a high percentage (about fifty percent) that the robot will not "see" the beacon. Maybe we were going too fast and the sensors did not see the beacon. Who knows, because we have worked five weeks on the programming to get the IR sensors to work, and ended up not using them.
| UTC Hartford and the Pits in 2001. The same setup for this year??? | Elgin Clock | Regional Competitions | 3 | 01-11-2002 19:11 |
| Next year: Make the game understandable | archiver | 1999 | 23 | 23-06-2002 22:53 |
| 2000 not a new Millenium | archiver | 2000 | 7 | 23-06-2002 22:17 |
| Is the registration this year fair? | tjrage_25 | General Forum | 11 | 27-09-2001 00:08 |
| Making heads or tails of the new announcement... | Jessica Boucher | General Forum | 66 | 26-09-2001 11:13 |
