Go to Post FIRST is more than FRC. - gblake [more]
Unread 03-06-2001, 15:16
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
alternate robots!!
I am in the process of using old parts (the van door motors)
to make my lawn mower remote controlled (it hot out in the sun!!!)
has anyone else tried goofing around woith some of the parts to do fun stuff like that
dahl
Unread 03-06-2001, 15:51
Joel J's Avatar
Joel J Joel J is offline
do you..
Thumbs up Remote...
Haven't done anything that zany, but that remote control lawnmower doesn't sound like such a bad idea. Maybe I could do the same to the snow plow during the winter time.
How exactly do you plan on making the lawnmower remote control?...
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 03-06-2001, 18:28
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Hmm.... that sounds like a very good idea....
then you record the inputs you make, and have it repeat them.... so you don't have to drive it every time... not sure if there is a way to do this on the Innovation FIRST controller... anyone know of a way? plus you'd have to account for things such as battery voltage or other factors.... oh well, a human-drive lawnmower is still a cool idea
Tom Schindler
Team 177
Unread 03-06-2001, 21:37
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Talking Oooh...
Go down to your local hobby store and pick up a model airplane starter kit and two victor 883s for those motors. If you use the airplane reciever PWM outputs to wire the Victors up, you can contol two motors via remote control. It'd be fun, but you'd ned a steady power source, and I think a 12 volt battery source would weigh a lawnmower down...
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 03-06-2001, 22:00
stillnotelf stillnotelf is offline
#0422 (Mech Techs)
stillnotelf is an unknown quantity at this point
Send a message via AIM to stillnotelf
are you trying to use the motors to drive the lawnmower, or the steering column? if it's a rider, you can control the steering column no problem. weight isn't an issue, mowers can carry several hundred pounds, you could put this year's robot on one just fine. my mower has a slot for a car battery, which is 12 volts, which is of course the right voltage for the robotic add-ons. of course, it's got all sorts of complicated gear-change and blade-engaging levers, it would be difficult to control them remotely.
Steven Lewis
Admin Head Team 422
i can't use contractions
Unread 03-06-2001, 23:46
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: alternate robots!!
dahl
One of my team leaders on a former team(74) actually did this...last I knew, he had an entire electronic drive system set up, but because of the amount of space it took, wasn't able to actually have the blade running(if i remember correctly, he used part of the discharge chute to store the electronics)...just used a standard RC car controller...
Nate Smith
nsmith@smythsoft.com
Unread 04-06-2001, 14:15
its a regular push mower
the control system would be on the pushbar (thats folded back over the body
i would use-
battery
two victors
and two drive motors
the motor would connect to the back wheels and drive via
3/8 chain-
connecting the front and back wheels (outside the body)
I should have plans up here in the next couple of weeks
school is over soon and I have to do teacher like things to wrap up the year
dahl
Unread 22-06-2001, 18:12
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Lightbulb Can you Say "HONEY I SHRUNK THE KIDS"? (EOM)
HI
Unread 12-07-2001, 03:43
robahimian robahimian is offline
#0349 (Team 349)
robahimian is an unknown quantity at this point
look it up
The lawn mower idea has been done countless times before. Search the web and you are bound to find tons of info on it. The only trick is adapting it to FIRST equipment but it doesnt seem too hard to do. However doing it safley is another question. In fact, Sharper Image sells an automatic lawn mower. I believe it uses under ground wiring (similair to an electric fence) to control itself. The blade cover goes all the way to the ground and there are sensors all over the thing to prevent it from running over someones foot. It's pretty cool. It's programable too. So you can tell it how and when to cut the grass. The only problem with it, just like everything else at Sharper Image, is the price.
Unread 12-07-2001, 17:17
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Low tech... ok, no tech
Here's a website with a creative non-electrical solution to the robotic lawn mower idea:
http://www.execpc.com/~dsmith/HomeAuto/Mower/
This guy took a large spool of rope, and let a walk-behind self-propelled mower just go in circles around it, with the spool taking in the rope as it went. He matched the width of the spool to that of the mower deck, so that there was minimal overlap.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 12-07-2001, 19:08
mike o'leary's Avatar
mike o'leary mike o'leary is offline
cd addicted ninny
#0419 (rambots)
mike o'leary is on a distinguished road
Send a message via ICQ to mike o'leary Send a message via AIM to mike o'leary Send a message via Yahoo to mike o'leary
hmmmm
the other cool thing about doing it that way is that it would make crazy patterns in the grass...
i am mike oleary
i am not an impersonater
i am a rambot
***ninny pride***
Unread 12-07-2001, 23:59
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
robotics mowers is what you call "laziness". it's not really that hard, this is comming from someone who works for a lawn mowing business.
But they are cool
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 14-07-2001, 09:59
Carolyn Duncan Carolyn Duncan is offline
The_C
Carolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the rough
I too know about cutting grass, my mom owns a landscape company which provides grass cutting in the summer. I've cut grass every summer for the last 4 years. It's really not that bad. Think of it this way, sun tan, sauna like, and counts as your day's exersize. Robahimian, are you talking about that little yellow thing that looks like there is a giant bug running around in your yard?
C~ya,
Carolyn
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
What do you do with old robots? Gui Cavalcanti General Forum 29 05-05-2002 01:05
'Accidently' ripping other robots apart Vipersna Rumor Mill 6 04-01-2002 23:27
