Go to Post The difference between a robotics kid and a generic nerd. Both use their calculators for statistical analysis. One keeps it a closely guarded secret, the other brags about it on Chief Delphi! - Kevin Leonard [more]
Unread 22-04-2004, 20:42
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Need way to fix power feed on OI
That plug was torn off all thats left is, well, two metal plates with a tiny piece of metal sticking out of each. We can still get power to it(using alligator clips) but it's a real hassel.
Some one suggested to me that it might be possible to hook up a power source via the competition port. But the schematics for it doesn't show anything about a power feed.
If anyone has an idea on how to we can fix this. Please let us know. We are going to an off-season event soon, and is in dire need of that OI in functioning order.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 22-04-2004, 20:53
Re: Need way to fix power feed on OI
you could take the power adaptor, cut off the connector on it, and solder on quick connects.
Then, solder quick connects to the leads on the OI.
Kinda ghetto.. but it works
Unread 22-04-2004, 20:58
see this thread for a similar situation: http://www.chiefdelphi.com/forums/sh...ad.php?t=26004
Unread 22-04-2004, 21:29
I'll reiterate what I said in that previous post...
Check with Innovation First on getting a repair or replacement. The power connector is a fairly substantial soldered connection and ripping it off the board often tears out part of a circuit trace, the through hole connection or makes a crack in the corner of the circuit board. These are repairable in many cases by a skilled maintenance tech, but are not the kind of repairs just anyone could make with just a soldering iron and good intentions. The guys at IF are great and will help if they can.
Unread 23-04-2004, 12:59
Shu Song's Avatar
Melodious Footware
Do you know if this year's OI is still under IF warranty? Cuz I just read their repair policy and it said that if it is out of the warranty, it can cost up to half of the original price (~$200).
Unread 25-04-2004, 00:01
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Heh .. you could just tether it for the entire time.
If you can get alligator clips on it, you should be able to solder some sort of a plug or wire onto the OI, and have it run into some sort of a power supply. 9v I belive. Cant be too hard.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 25-04-2004, 00:08
Shu Song's Avatar
Melodious Footware
there is barely 2 mm of metal sticking out of each terminal. we were very very very careful in using the alligator clips.
Unread 25-04-2004, 00:22
FRC #0973 (GRR)
Eh .. 2mm is enough to solder on and slip some heatshrink over. It might be a better investment to see what IFI will charge you to fix it. If its out of your budget .. soldering or using the clips might be your only option.
2011: ???
Unread 25-04-2004, 07:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
If you attempt to solder it, your warranty is void.
Unread 25-04-2004, 12:27
FRC #0973 (GRR)
And the fact that the connector got ripped off, probally voided the warranty already.
2011: ???
Unread 25-04-2004, 12:32
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
From Innovation First's Site:
Innovation First warrants our products to be free from defects in manufacturing, materials and workmanship for a period of four (4) months from the date of purchase. This warranty covers normal use within the limits specified as stated in the applicable data sheets. This warranty does not cover abuse, misuse, incorrect wiring, alterations, connector damaged, or robot competition damage.
I take it that means it's out of warranty. For most electronic devices, physical damage isn't covered. However, Innovation First can be surprisingly accomodating, especially when it comes to FIRST equipment. I would check with them before doing anything. If they can't authorize a replacement or repair, they should be able to suggest the best course of action to get you back up and running.
Unread 25-04-2004, 15:03
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
If you cant get it fixed before coming to PARC there is no need to worry!!!
We will be using the Innovation First controls. All IO power will come through the Competition port.
As for power up the robot you will have to use the tether....
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
