Go to Post I tried, but our freshmen lost enthusiasm about filing the blocks of aluminum I gave them into Andymark Performance Wheels after only a few hours! - Greg Woelki [more]
Unread 25-04-2004, 07:24
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Omni Wheels Survey
I'm surprised Pit Bull hasn't said anything on this thread. His Title is "Mr. Omni-wheels." (or something to that meaning)
It depends on your drive setup it you can be pushed (easily) or not. If you do something like a Killough Platform, you can never truly be hit from a "side." (If you don't know what a Killough Platform is, look it up on Google.)
Unread 25-04-2004, 08:58
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
sorry a little late had a party here last night the people didn't leave till 2 am.
anyways...
omni wheels love em! i came up with them this year for our bot just so that we can turn in high gear and climb very easily and that was accompolished very well. if another bot did hit us on the right side all we needed to do we counteract it and drive towards that side and they couldn't push yes any more. they really work great and are wonderful. i will have a white paper up soon on my creation. check for it in a few weeks...
p.s. we had 2 omnis in front 2 pn. wheels i the back... heres a pic
pit out...
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 25-04-2004, 09:36
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
I'm trying to develop a drive system that can move freely in all directions for next year. And I rummaged through the whitepapers, and it the concept of using four omni-wheels, two in either direction, would work.
Okay; that's a pretty bad drawing; but you get the idea. By running the two sets of wheels at different speeds, you can strafe your robot in different directions. This means you'll have a seperate gearbox/transmition/motors for each set of wheels, correct? Say you have two motors per set of wheels. Does that mean you can really only apply two motors worth of power in any one direction? So if you were up against a robot that had a tank drive with four motors of power in one direction, you'd only have two to their four? Now I'm just learning the basics of these engineering principles, so tell me if I'm way off.
And again; with that design, if a robot pushed yours, you'd really only have two wheels of traction to push back with?
Looking at a few designs of omni-wheels that use the metal spinners for the treads (rather than the plastic ones) what's the possibility of those damaging the carpet if you're in a pushing match and your wheel slips?
Also, what's the advantage of using omni-wheels if not for all-direction travel? For example in the above robot picture; you have the two omni-wheels in the front. You said it was so you could turn in high gear easier; so the omni-wheels provide half decent forward-backward traction and little lateral traction. Are there any other benefits?
Thanks for your time answering these.
Unread 25-04-2004, 09:58
Nathan Pell's Avatar
Nathan Pell Nathan Pell is offline
FRC #0233 (The Pink Alliance)
Nathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to behold
Team 1083 and 180 both used omni wheels to make a holonomic drive train. It worked very well; we rarely were pushed, as we were so much more maneuverable than anything else out there. Also, unlike casters which just "sit" there and can rotate easily, our wheels were attached directly to the motors and gear box, so pushing them was not as easy as casters.
I highly recommend holonomic drive when you want to be maneuverable.
Unread 25-04-2004, 10:15
FRC #1405
omni wheels = motorable casters....that can or can't be movable sideways.... like mine, they can't move sideways but they rool b/c of the rollers..
we opnly used two because of the game, we wanted to get on that ramp very qucikly in which it did b/c we had a 1/2" lip to catch the edge of the 6" platform.
anything else or i missed?
Unread 25-04-2004, 13:26
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Ah, you're referring to Patrick's 3DOF whitepaper right? After driving the Cornell robocup robots for a while with an XBOX controller, I have to say that such a design is just plain awesome for being mobile. If someone tries to push you, there are so many ways to move. Google Cornell Robocup and check out some of their videos for a demonstration. Patrick is also updating the Cornell team's status at the American Open in New Orleans (their first match should've been 30 min ago) in this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=28159
In addition, our team has used omniwheels in 2002 and 2003... search these forums for pics of them (and descriptions) or PM me. They've worked beautifully. We switched to tank treads this year.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 25-04-2004, 18:03
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
... Say you have two motors per set of wheels. Does that mean you can really only apply two motors worth of power in any one direction? So if you were up against a robot that had a tank drive with four motors of power in one direction, you'd only have two to their four?...
this is the main reason that i (personally) don't like "traditional" holonomic setups. mecanum/ilon wheels (such as the ones on these robots) solve this problem to a degree, since it allows you to harness the power of all 4 motors whenever the bot is moving in a direction perpindicular or parrallel to that of wheel rotation. this setup is weakest when it is moving diagonally when only two of the wheels are being powered. in addition, since the rollers overlap, and are rounded, there isn't as much bumping present as there is in the traditional omni-wheel.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 25-04-2004, 18:28
David Bridge's Avatar
David Bridge David Bridge is offline
Totally Sweet... Man
FRC #0177 (Bobcat Robotics)
David Bridge will become famous soon enoughDavid Bridge will become famous soon enough
Send a message via AIM to David Bridge
For anyone considering the use of omni wheels on their robot, Andy Baker put out a great white paper on how team 45 made theirs and it has all the specs you need to make a great pair yourself. We on team 177 used a slight variation of these wheels on the back of our robot (we kept pneumatic tires on the front) and they allowed for excellent turning. Despite what people say you do not need at least 3 of these wheels by any stretch of the imagination. We recieved many comments from people attending the Philly regional and nationals that they thought we would be very easy to push out of the way with omni wheels and that they were surprised to see us do all of the pushing. If you saw any of our matches you know that defense was a big part of our game, and these magnificent wheels made that possible.
http://www.chiefdelphi.com/forums/pa...le&paperid=226
Unread 25-04-2004, 18:48
FRC #1405
i am interested in your omni wheels, and why u guys choose to put them in the back.. please explain.
we should get all the robots that have omni wheels and make a big gallery of them, that would look cool..
Unread 25-04-2004, 19:03
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
well it was our first year with omini wheels-- we actually have to fix them up-- only problem i saw was the rubber on the wheels-- a lot of driving just wore them down-- all well-- i'm sure S.P.A.M. won't mind sharign our design-- nobody we saw had a drive system like us-- and we plan on making them better
Unread 25-04-2004, 19:06
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
I saw a few teams using omni wheels bought from this site:
http://www.omniwheel.com
They have an interesting selection.
Rob
Unread 25-04-2004, 19:09
Rob
we actually did buy some from that site-- took the whole supply actually for that time period but the wheels didn't work for us--didn't hold our load and no clearance-- i had to actually take down the plastic but that didnt' help much either--so we had to fabricate our own wheels at the end of the 6th weeks-- but we did it-- many teams have seen our wheels they are really cool
Unread 25-04-2004, 23:35
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
i believe 1083 had your same holonomic drive system as nathan pell posted above. I wasn't priveleged enough to see SPAM in action, but i know that 1083 was excellent.
Team 1257
Unread 26-04-2004, 02:35
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Tiffany!?
::GASP::
Not only have you guys seen one, but it was at the Florida Regional with you.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 27-04-2004, 17:21
Originally Posted by George1083
Tiffany!?
::GASP::
sry george meaning that nobody made wheels like us-- design that james came up with and that i got to help make and well yeah get to fix them again
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
pic: #1018's omni wheels CD47-Bot Robot Showcase 22 19-02-2004 15:04
We need Omni Wheels!! archiver 2001 0 24-06-2002 01:02
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
