Go to Post By inviting engineers and mentors to be a part of your team and partnering with them...brings added value, depth, strength, expertise, and wisdom to the team and to the overall experience. - JaneYoung [more]
Unread 25-04-2004, 07:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Need way to fix power feed on OI
Originally Posted by PhatMike
Eh .. 2mm is enough to solder on and slip some heatshrink over. It might be a better investment to see what IFI will charge you to fix it. If its out of your budget .. soldering or using the clips might be your only option.
If you attempt to solder it, your warranty is void.
Unread 25-04-2004, 12:27
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
And the fact that the connector got ripped off, probally voided the warranty already.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 25-04-2004, 12:32
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
From Innovation First's Site:
Innovation First warrants our products to be free from defects in manufacturing, materials and workmanship for a period of four (4) months from the date of purchase. This warranty covers normal use within the limits specified as stated in the applicable data sheets. This warranty does not cover abuse, misuse, incorrect wiring, alterations, connector damaged, or robot competition damage.
I take it that means it's out of warranty. For most electronic devices, physical damage isn't covered. However, Innovation First can be surprisingly accomodating, especially when it comes to FIRST equipment. I would check with them before doing anything. If they can't authorize a replacement or repair, they should be able to suggest the best course of action to get you back up and running.
Unread 25-04-2004, 15:03
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
If you cant get it fixed before coming to PARC there is no need to worry!!!
We will be using the Innovation First controls. All IO power will come through the Competition port.
As for power up the robot you will have to use the tether....
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
