Go to Post I'll give you my prediction in just over 35 hours. - Andrew Schreiber [more]
Unread 26-04-2004, 17:36
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Four Wheel, all steering, non-omniwheel, ONE power/motor source drive
Now that i thinkabout it 4 reverse gears are not needed in my preious design if the wheel turning horizontal _ chains are run off of 2 spockets and two globes or windows or something. Instead of the M more of a X
This way you have no reverse, except for on all ofthe wheels at the same time, but you can turn the front wheels 90 degrees to the left and the back 90 degrees to the right. It wil created tank type steering and turn your front into the side, until the turn is over and the driver staightens out the wheels to dive again. There is also steering like a car, but better, cause you can turn the back wheels too, which is an option now sometime on the newer models .
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 26-04-2004, 17:47
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Would someone mind explaining to me how the power would be transfered to the wheels in a system like the ones shown here. I've been looking at a lot of the pics...and am obviously missing something, because I don't see anyway the power from the motors is getting to the wheels.
Unread 26-04-2004, 18:28
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
This is just my two cents:
I would suggest staying away from the Reverse gear unless you want things to get very mechanically complex. Also, by using a reverse gear instead of changing motor direction, you cannot make point-turns, you can only counter-rotate. Think about it: Your wheels in reverse go as fast as your wheels in forward, and as far as I can understand, there would be no way to stop only one side of your bot. Personally, I would go with separate drives, but thats just my opinion.
Also, Henry_222's idea sounds cool, but:
1 drive motor + 4 module rotation motors = 5 total OR....
4 drive motors + 1 module rotation = 5 total <--- I'd go for that, more power to the floor, even if more complex.
Unread 26-04-2004, 18:43
Ryan F.'s Avatar
Also..if your using the chips in the drive....there isn't a large speed difference...so for reversing...I doubt you would ever notice a difference in just going backwards.
Unread 26-04-2004, 21:06
#0316 (LuNaTeCs)
Fizman- Not that it matters too much, but your wheels should only have to rotate 90 degrees to swerve if you run ur drive motor(s) forward and reverse
Rod- Could you explain how power is transferred from the motor to the wheels on your design, and how the wheels change direction/speed?
Unread 26-04-2004, 22:51
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Not ONE motor, one gearbox. Many motors potentialy. It is all in the application.
I like the ideas....but....
I see this whole venture of one power source to complicated and heavy to deal with. There are many other options.
Also,
I have only ever "peeled out" or skidded wheels on carpet once with a bot. It was a basic bottom chasis and had 6" wheels and a prototype 3 speed on the fly tranny. The wheels are the ones from the kit, Skyways I think. I flew around in 3 and slammed into 1. SKIDDDDDDDDD. And I started in 3, full stick. SKIDDDDDDDD, ZOOM. If the proper wheels are in the application, there can never be too much power. HE HE HE.
Ching Ching, thats my 2. On a lot of stuff.
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 26-04-2004, 23:57
Andy A. Andy A. is offline
Getting old
FRC #0095
-Henry
Sure there can. When you start ripping up carpet, you have to much power and traction.
This does happen, and teams do get disqualified for it.
-Andy A.
Unread 27-04-2004, 07:40
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
I don't know; I see the venture of one power source (while complicated) could potentially be lighter than multiple ones. I mean; even if you have to build a monster gearbox, it'd still only have to be twice the size (maybe less if you're good at compaction) than having two smaller gear boxes. Have to mount 2 motors in a gearbox? Have a gear box X size. Have to mount 4 motors in a gearbox? Have a gear box 2X size. Am I right? So the weight evens out there.
But then you can have a single transmission for the whole thing; 1/2 the pneumatics, 1/2 the mounting, 1/2 the gearing.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 27-04-2004, 10:10
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
With the centralized design you still have the weight of the motors. If you want to add more the a couple you have to have all the gearing to join them. If you want it to shift you can save some weight on only one but you would make up some of that on the amount of chain. Pneumatics don't weigh a lot past the first cylinder. Several of the gearshifting design use 3/4" cyclinder at a very short stroke which are very light.
What you are wanting to do is heavy by nature. With the right design and materials a centralized gearbox may be lighter. This is a tough one to call either way though. The xbox is a fairly good example of this but they said they weighed ninety pounds without shifting. And the only used to motors. More than this would require additional gearing and the gear shifting mechanism would have to be added. In this case you are looking at at around another 20+ pounds which will leave you with a 20 lb arm at most. Weight is a hard constraint to deal with. I think we would see a lot more drivetrains like you envision if we could weight 20 to 30 more pounds.
Unread 27-04-2004, 10:58
FizMan's Avatar
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
Are you saying that:
3 motor gearbox + 3 motor gearbox +2xTransmission < 6 motor gearbox + 1xTransmission?
A central gearbox would indeed require chain and/or a shaft extending out to the other wheels, but I don't see that taking up that much extra weight. Besides; other drive systems would require the same thing to transfer the power out to the wheels.
And with the shifting, it's not just the pneumatics; it's the extra mounting, gearing, maybe another shaft. Plus if you can reduce the amount of pneumatics required to fire to shift; we might be able to ditch the need to include the air compressor.
When I compare something like this to a traditional tank drive system; I see the only extra weight coming in to support the one extra motor to turn all the wheels, and maybe the little bit more with the wheel mounts. And then the reversing gear; which would probably weight the same amount or less than the second transmission. Or perhaps better yet; maybe it can be implemented along with the transmission somehow...
Unread 26-04-2004, 21:10
FRC #0701 (RoboVikes)
I would suggest mounting your 3 speed transmissions in the center and then have miter gears coming off that connect to the wheel modules...we were thinking of doing this but didn't have the recouses to pull it off
Team 701
Unread 26-04-2004, 21:16
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I'm curious if you could run into a situation where you have too much power. There has to be a point where you just have so much power that you can't transfer it to the carpet because the wheels are slipping. Is there any way of calculating this?
Unread 26-04-2004, 21:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The senario you described wouldn't be a problem of too much power, it would be a problem of too little traction.
Unread 26-04-2004, 21:46
Carpe diem
Well the point I was trying to make is... how much power is so much that it doesn't matter? Simply because you will run into the traction problem.
Unread 26-04-2004, 22:03
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
oh, the old coaxial crab drive. a potentialaly shiftable omni drive desing sporting dashing manuverabilty
however there inavoidabaly heavy, complex. heavy, inefficent, batery hungary, recorce-eating things witch through the process of desinging my oun became Painfully apparent.
its still a wikid cool drivetrain tho
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
Quatro 4 wheel drive ufa_mike Control System 1 14-04-2004 21:45
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
