Go to Post The engineer mentors ARE part of the team, equals with the students in every aspect - KenWittlief [more]
Unread 25-04-2004, 23:16
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: PIC controllers and c++???
I too do not pretend to know what im saying, but i do know that, at least in the early days, C++ compilers would actually convert the C++ code entirely into C code and then use an already existing C compiler to compile that. The point is that it is entirely possible, and i think likely, that you could find or at least modify a compiler to do this for you.
Team 1257
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
Cheaper speed controllers Max Lobovsky Kit & Additional Hardware 8 09-03-2004 13:18
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
speed controllers archiver 2000 5 24-06-2002 00:19
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
