Go to Post To me, the changing rules are a big part of the fun. If the rules stayed the same year to year, robots would start to look the same. That would be boring. - Richard Wallace [more]
Unread 07-04-2004, 01:23
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Malicous RC Code?
Originally Posted by Bongle
There was about a 50/50 split between times we had to press the program button, and times where we didn't. Sometimes we'd just fire up the robot and IFI_LOADER, and the program would go, and sometimes we'd have to hit the program button first.
I believe if you have a programming link (IE serial cable in prog port connected to laptop) to the RC at power-up you don't need to press the program button.
The old Pbasic controller had these modems (EWave Stampers) you could buy to debug and program the robot remotely (very useful, cut debug time in half). I could not get them to work on this year's RC (but they possibly could be modified to work). Maybe Ewave will develop new modems for the PIC RC in the future. If you were to plant the modem on a robot (well a 2003 bot) then you could program it from the stands to do a dance or whatever (would make an interesting practice round).
As for this year, small device could handshake with the program port on power-up and then download the machine code for the aforementioned "Dance Program" from an EEPROM in the device. Now there is an offseason project for you
Disclaimer: I am just kidding and tossing ideas around (like hopefully everyone on this thread). Actually reprogamming a competitor's robot maliciously during a match would probably be the worst violation of Gracious Professionalism in FIRST History. However, it is fun to joke about these things. Come on, Who hasn't proposed an EMP burst bot or Tesla coil bot during Brainstroming?
Robot Inspector
Unread 07-04-2004, 11:29
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Wouldn't an EMP bust the computers running the match? Just wondering: that would be a lot of field errors in a row.
Unread 07-04-2004, 22:13
golf_cart_john's Avatar
golf_cart_john golf_cart_john is offline
AKA: John W
FRC #0095 (Grasshoppers)
golf_cart_john is a jewel in the roughgolf_cart_john is a jewel in the roughgolf_cart_john is a jewel in the rough
Earlier this year, I asked a guy from IFI about setting the radio channel. He said you can do it with the little switches OR by using some serial-ish thingummy through the competition port. So, your code probably can't affect the channel unless it convinces a human to plug something into the competition port. The RC must still control its channel, though.
You might be able to do viral stuff by changing the team number and/or the backup battery behavior. Many people forget to reset their RCs after turning the robot off, letting it run on backup power. If you could change the firmware, you could have the RC use the radio while the robot is truned off. Then, you could scan channels and team numbers to establish contact with another robot.
Don't forget, this is entirely for your own entertainment. You'd better not actually use it at a competition (well, not at mine, at any rate ...)
Unread 08-04-2004, 12:52
AKA: Jamie Bliss
If you could find a way to do buffer overflow, you could change the firmware. But since buffer overflow is based on a terminating character, not likely.
Unread 08-04-2004, 15:22
The Lucas's Avatar
Yes it would. That was a counter arguement. One would have to tweak the power of the burst to only affect things in a yard radius (it would take tremendous amount of power just for this) and deploy it when you bump another bot. Also, one would need to shield the electronics on one's own bot (or temporarily turn them off like in Broken Arrow).
Robot Inspector
Unread 25-04-2004, 10:07
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
If you could figure out the 'robot disable' message of competition control......
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 25-04-2004, 10:22
I hope you guys remember that these boards are read by LOTS of people in the FIRST community, many of them having very important roles. I'm not saying what you are trying to do is a bad idea, but if something does happen at a competetion, they will know exactly who to look for.
Unread 25-04-2004, 13:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Not me, I'm sure...
Just in case it does, I was asleep.
Unread 25-04-2004, 14:08
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Okay, time for a rant!
Anything I say after this point is not intended to offend anyone, yada yada, etc.
We should ALL be interested in "malicious code" and other "scary hacker things." If there is a vulnerability (and this goes for all complex systems) someone, somewhere, will find it. The responsible (and challenging/fun) thing to do is to hunt down the vulnerability and inform those responsible to make the world a more secure place. What you should not, under any circumstances do, is try to get your point across by releasing your code into the wild, to the detriment of the common good, to fuel your ego.
FIRST strives to be a microcosm of the engineering world. Security is a very real facet of any system, and if we really want to educate FIRSTers we should pay attention to this.
What really bothers me is that if someone does go out and release code similar to what I've described, I stand a good chance of taking heat for it.
This bothers me, because I've had something similar happen in school and if anything goes wrong on the network it's always "that uppity linux kid's fault." I remember one of my friends being carefully monitored while on the computer, simply because he hung around me a bit and liked to talk computers
So then, when I get some spare time (see: Summer-Vacation) I plan to seriously look into this, because it would really [expletive deleted] hard to have a competition high-jacked by a few broadcast happy l33t kiddies.
End Rant. End Self-righteous indignation.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 25-04-2004, 14:09
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Now you just need a small nuclear reaction
Unread 25-04-2004, 14:13
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Nope. I have plans for an emp device sitting in my room. I didn't realize it until I actually read my book. Its not really that complicated but deadly if you don't know what you are doing.
Unread 25-04-2004, 15:20
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Small Soldiers anyone?
Seriously, you should go about the robot comms as a wireless network, if you can interfere with the data from OI to RC and impersonate it, with a stronger signal, you can very easily override another controller....in theory. As far as reprogramming it goes doesn't that button connect to a digital input? I bet you could find some way to trigger it if you dig deep enough in the code.
Matt Krass
Unread 26-04-2004, 07:29
AKA: Jamie Bliss
I'm sure just garbling the signal is enough. Freaking someone out wouldn't be difficult. But there is a laptop that monitors com and such.
Unread 26-04-2004, 08:47
Programming User
They'll never find me!!!!!
Whoops. And by the way, I'm on your team if anyone asks.
Unread 07-05-2004, 21:41
AKA: Jamie Bliss
I JUST THOUGHT OF IT! :evil:
Find out the memory location of team number/channel/alliance info and change it at run time. MUAH HA HA HA!!!
Like, change it to 0 so you don't stop at the end.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
