Go to Post You mean to tell me there's a weight limit this year?!?!?!!? - Carlo [more]
Unread 26-04-2004, 09:21
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: Four Wheel, all steering, non-omniwheel, ONE power/motor source drive
Originally Posted by Al Skierkiewicz
I hope that the drive train is not detailed in your drawing. There is a need for slip clutches in the differentials to allow turning. Without them the drive motors go into stall during turns. Just two drills or two Chalupas driving the wheels means 200+ amps during turns. Add the two FP, two Chalups and two drills and you have exceeded the current capabilities of the battery and possibly tripped the 120 amp breaker. There was a GM team who had a similar design without the clutches and they repeatedly set the drill motors on fire during turns using one drill for front and one drill for back. This is one application where current sensing is an eye opener. Sorry.
There are slip clutches in the differentials
-Rod-
Team 662
Colorado Springs, CO
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
Quatro 4 wheel drive ufa_mike Control System 1 14-04-2004 21:45
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
