Go to Post Yep, after all, when life gives you lemons, make a robot to pit and squeeze them, purchase sugar, cups, water, and ice and make lemonade!! - vivek16 [more]
Unread 26-04-2004, 15:20
Joe Clohessy's Avatar
Joe Clohessy Joe Clohessy is offline
#0522 (RoboWizards)
Joe Clohessy will become famous soon enough
Send a message via AIM to Joe Clohessy
Exclamation Multiple Auton's
I was wondering of a way to do multiple auton modes. Please if you have any proven information let me know either in a PM or Email DragonMan@si.rr.com .
I tired having a switch to make a digital input on the Robot Controler trigger a different auton mode by grounding the Signal (To make it a 1) with such code as:
(I forgot the actual name for the digital inputs so lets say dig 1 & dig 2)
if (dig1 = 1)
/*Auton mode here/*
else if (dig2 =1)
/* other Auton Mode/*
else
/*do nothing /*
Can someone tell me why this theory wouldnt work ??
Does anyone have an auton mode that has a switch to change between modes that I can look at and pick apart. Thankyou
--2004 NYC Regional Winners
--2004 NYC DaimlerChrysler Team Spirit Award
--2004 NYC GM Industrial Design Award
--2003 NYC Regional Winners
--2003 NYC Motorola Quality Award Winner
--2003 Philadelphia Eliminations With Team 365 MOE and Team 341 Miss Daisy
--2003 8th seed Championship Curie
--2003 Eliminations With Team Hammond the 2002 Championship Winners and Team 223 Xtreme Heat
Unread 26-04-2004, 15:33
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: Multiple Auton's
Make sure you realize that = is the assignment operator in C and == is the equality test. Therefore, you'd have to say:
if (auto_selector_switch == 0)
  Do_Auto_0 ();
Sure, this would work. The only thing you need for multiple auton's to work is some method to select which auto program you want to run. You can have a switch on the RC or the OI. Just chose the program based on its value.
Unread 26-04-2004, 15:53
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Joe, your theory should work just fine. We also used switches to customize our autonomous mode. We could use switches to determine which side of the field we started on, what path to drive, and whether to do it in high gear or low gear. It was all configurable on the field, so our autonomous mode selection was a match-time decision, often based on who was lined up opposite from us.
The code is pretty much what you have above, albeit much uglier. This is an earlier copy that wasn't cleaned up.
Cheers!
void User_Autonomous_Code(void)
	static unsigned int auton_status = 0;
	static unsigned char left_set; // left motor speed set-point
	static unsigned char right_set; // right motor speed set-point
	static unsigned int counter; // used to take snapshot of clock for dead-reckoning moves
	unsigned int pressure;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
		relay2_fwd=1; //turns brake off.....
		if (Clock > Old_Clock) // Old_Clock and Clock are serviced by the IR Timer - this line ensures a new IR cycle has occured
			Old_Clock = Clock;
			switch (auton_status)
				case 0:
					Left_Encoder_Count = 0;
					counter = Clock;
					left_set = 127;
					right_set = 127;
					relay2_fwd = 1;
					if (rc_dig_in10)
						relay5_fwd=1;
					else
						relay5_fwd=0;
					auton_status++;
					break;
			case 1:
		if (rc_dig_in11)
			if ((Clock - counter) < 384) //this stops the robot in low gear right in front of the goal
						left_set = 255;
						right_set = 225;//fudge factor
					else
						left_set = 127;
						right_set = 127;
					    counter = Clock;
					break;
		if (rc_dig_in12)
			if ((Clock - counter) < 460) //this makes the robot hit the goal and go straight 3/4 of the way
						left_set = 255;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
					break;
		if (rc_dig_in13)
				if ((Clock - counter) < 576) // rush down to the other end of the feild hitting the goal HIGH GEAR
						left_set = 255;
						right_set = 255;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
					break;
		if (rc_dig_in14)
				if ((Clock - counter) < 396) //stop beside the mobile goal,
						left_set = 225;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					   	counter = Clock;
						auton_status=2;
					break;
				case 2:
				if ((Clock - counter) < 15) //turn to face right back at you.
						left_set = 0;
						right_set = 255;
					else
						left_set = 127;
						right_set = 127;
					   	counter = Clock;
						auton_status=3;
					break;
				case 3:
				if ((Clock - counter) < 10) //positions itself behind the goal
						left_set = 255;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
						counter = Clock;
						auton_status=4;
					break;
				case 4:
				if ((Clock - counter) < 15) //positions itself behind the goal
						left_set = 0;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					    	counter = Clock;
						auton_status=5;
					break;
				case 5:
				if ((Clock - counter) < 384) //positions itself behind the goal
						left_set = 255;
						right_set = 225;
					else
						left_set = 127;
						right_set = 127;
					    	counter = Clock;
					break;
		// Carol's cubic transfer function that desensitizes small movements, but still allows full speed
		temp_p1_y = (signed long)left_set - 128;
	    pwm01 = (unsigned char)(((temp_p1_y * temp_p1_y * temp_p1_y)  >> 14) + 128);
  		temp_p2_y = (signed long)right_set - 128;
  		pwm02 = (unsigned char)(((temp_p2_y * temp_p2_y * temp_p2_y)  >> 14) + 128);
// Run compressor
		  pressure = Get_Analog_Value(rc_ana_in16);
		  if (pressure < 800)
		  	relay6_fwd = 1;
		  else if (pressure > 925)
		  	relay6_fwd = 0;
		// Get all 6 drive motors working together
		pwm03 = pwm01;
  		pwm05 = pwm01;
  		pwm04 = pwm02;
  		pwm06 = pwm02;
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Unread 26-04-2004, 16:06
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
We had the following code to use 2 pots on the OI to set the aunonomous mode.
Basically, we had 6 varieties of Auton (0-5). We had up to 15 steps per auton program (0-15). We could set the max number of steps as well as set the particular program.
The way it works is that your robot has to be not in AUTONOMOUS MODE, DISABLED and the OI has to be in USER MODE.
After that, you either are looking at the codes or you are setting the codes.
For our OI, we had two software disable switches in addition to the disable from the competition port (OIW_Enable_Sw and OIA_Enable_Sw). We used these switches to decide if we were in the "view autonomous" mode or the "set autonomous" mode. If both of these switches are in the "enabled" state, the program is in the "viewing" mode. If one or both switch is disabled, then the program is in the "setting" mode.
One pot sets the program number (OIW_RHW_Pot), the other sets the number of steps (OIA_Extra_Pot).
The display is as follows XXY where XX is the number of steps the particular program will run and Y is the auton program number -- I use this format because the number of steps is greater then 10 and the number of auton programs is not AND I need to have the entire number (XXY) be less than 255 or it would not display properly on the 3 digit display on the OI.
It is harder to explain than to use.
Below is the code fragment of where we set the codes we use in autonomous mode to select which program runs and how far it runs.
Finally, we also set these numbers to a safe condition upon reset so that we could simply cancel autonomous mode by simply hitting robot reset.
Joe J.
if (!Enabled && user_display_mode && !autonomous_mode)
if (OIW_Enable_Sw == 0 || OIA_Enable_Sw == 0)
if ((OIA_Extra_Pot >> 4) < 16) auton_stop_cnt = OIA_Extra_Pot >> 4 ;
else auton_stop_cnt = 15 ;
if ((OIW_RHW_Pot >> 5) < 6) auton_prog_no = OIW_RHW_Pot >> 5 ;
else auton_prog_no = 5 ;
User_Mode_byte = (auton_stop_cnt *10) + auton_prog_no;
Unread 26-04-2004, 17:25
Here are two ways teams I helped accomplished it this year.
1) Use a BCD style rotary switch available from Digi-Key (hooked to digital input pins 15-18 in this case). 16 choices using 4 digital input pins or 8 choices using 3 pins. The extra selections were used for diagnostic software rather than have so many autonomous programs.
static unsigned int swtc; //set equal to the switch input
swtc = PORTJ>>4; // Auto select switch 0-15
switch(swtc)
	case 0:
	default:
		AUTO_0();
		break;
	case 1:
		AUTO_1();
		break;
2) Use a regular Radioshack style mechanical rotary switch. In this case a 6-position switch hooked to digital input pins 11-16.
if (!rc_dig_in11)
	 Auto_1();
else if (!rc_dig_in12)
	 Auto_2();
else
	 Auto_1();
Unread 26-04-2004, 17:54
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
That's surprisingly similar to ours. I guess ours is a dumbed down version, but it's worked almost flawlessly the past two years.
Ours has a selector switch (10 position I think) where we select the autonomous program that we want to run. That coupled with the R/L switch on the robot selects the waypoint list that will get executed. While the robot is DISABLED and not in USER MODE, the RC is constantly taking the value of the OI auton selector and assigning pointers to the correct list (actually an array in memory, but that doesn't matter). Once the driver goes into USER MODE, we lock in the autonomous program and any changes to the selector switch are ignored. The OI display follows XYZ, where X is 0 for right, 1 for left; Y is the program number; Z is the current waypoint number in the program.
I said it's been almost flawless because at Nationals in 2003 we failed to run autonomous in one of our qualification matches. One of the field crew members hit our OI select button and took us out of USER MODE after the drivers locked us in. No one noticed so no one re-locked us in. Apparently we needed to be in USER MODE in 2003 for us to run auto so we just sat there for 15 seconds.
Unread 27-04-2004, 07:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
We used 5 switches on the OI: 1 for side select, 4 for auton select. Each of the 4 switches represents a bit. We set a variable with these values in Process_Data_From_Master_uP() (which got me to notice the bug in main.c).
For Auton, we do this:
 // Do instructions
 switch (AUTON_MODE)
  case 0:
   //Do nothing
   break;
  case 1:
   Auton_1(); break;
  case 2:
   Auton_2(); break;
  case 3:
   Auton_3(); break;
  Getdata(&rxdata);   //DO NOT DELETE, or you will be stuck here forever!
  Putdata(&txdata);   // DO NOT DELETE, or you will get no PWM outputs!
  Generate_PWMs(pwm13, pwm14, pwm15, pwm16);
 Process_Data_From_Local_IO();
}// End Loop
Then, we wrote the Auton's in seperate files.
Unread 27-04-2004, 08:39
AKA: Dr. Joe
FRC #0088 (TJ2)
Looking at this thread, I think I will start a new one...
I thinkthat this is a great thread. I think that it brings up another good point. Innovation First does a great job, but in some ways they have no idea what we, the users of their stuff, really need.
I am going to start a new thread that will be a title something like "what should the "Default Code REALLY include?" Of course, one thing it should include is an easy way to select auton programs.
Look for the thread, coming soon to a forum near you...
Joe J.
Unread 03-02-2005, 18:54
scifi3018 scifi3018 is offline
scifi3018 is an unknown quantity at this point
wow those are great solutions what we have is alo0ng the lines of:
 |rc_dig_in_01| + |rc_dig_in_02 << |+ |rc_dig_in_03 <<|
or something along those lines, it creates a 3 digit binary number that has 8 options, 0-7,what it does is sets digin 1 as the 1's place, digin 2 as the 10's place3 and digin 3 as the 100's place, so we have options of 000,001,010,011,100,101,110,111, and we have a case set afeter that with our autonomous modes, in retrospect its a bit confusing for some people tyo understand, and a rotary selector would have een nice
Unread 03-02-2005, 22:37
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
wait...
we were talking about this during our meeting today, and we didn't think that switches on the OI (vs on the robot) would work.
this is because i didnt think that your robot would recieve data from the OI during autonomous mode. (its autonomous, why would you get the data?)
altho, we did think it possible that it gets data once in the beginning, and could read the switches then.
can someone clear us up on this?
thanks,
~Stephanie
Team 1351
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 03-02-2005, 22:47
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah, I was under the impression that you may not (can not?) access information from the OI during autonomous mode.
Unread 03-02-2005, 22:50
The OI switches and joysticks can be read by the robot any time autonomous mode is not active. It's no trouble to constantly read the value of a selector switch into a variable while auton_mode is false, and use that variable when auton_mode is true.
We liked having lots of autonomous options last year. Instead of eating up a bunch of switch inputs on the OI, we used a rotary switch to select between taps in a string of resistors and connected that to one of the joystick _aux inputs. The code saw an analog value, compared it against a collection of programmed low/high limits, determined which switch position had been selected, and stored a number representing that position in a global variable.
We'll be doing something similar this year.
Unread 03-02-2005, 22:58
russell's Avatar
#1430 (WRONG)
Someone should sticky this. I know I will be refering back to it as soon as we actually have a working bot.
Unread 03-02-2005, 23:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by RbtGal1351
wait...
thanks,
~Stephanie
Team 1351
You are correct. Data generated by the OI is not transmitted to the RC during autonomous mode. The field control system disables the transmission of any data from the OI during this period.
-dave
Unread 04-02-2005, 00:21
RbtGal1351's Avatar
AKA: Stephanie
FRC #1351 (TKO)
-dave
yay thank you!!!
~Stephanie
Team 1351
SVR 07: 36th seed
multiple definition error in MCC/Linker (possible bug?) wun Programming 5 01-04-2004 17:49
Multiple programs/autonomous routines galewind Programming 12 09-01-2004 22:25
question for teams created among multiple high schools archiver 2001 20 24-06-2002 03:58
multiple e-mail notifications srawls CD Forum Support 3 23-05-2002 12:55
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
