Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
  #31   Spotlight this post!
Unread 26-04-2004, 07:10
Re: Omni Wheels Survey
Wildstang has used a variety of different designs for omni wheels over the years. We scratch build our own and have modified the design each time we used them. This year we used two driven omni (we call them BUPODfor Biased UniPlanar Omni Directional) and two crab drive modules for four wheel drive. In crab from side to side we had to add some software to help the robot drive straight which we called "Drive Straight". The omni wheels tend to go where they want when they are not driving.
  #32   Spotlight this post!
Unread 26-04-2004, 09:11
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by George1083
....Mecanum wheels have the rollers at 45* angles which produces the same vectors as a normal holonomic platform with its wheels at 45* angles.
are you sure about this? when a mecanum moves 'forward' or 'backward' (relative to its wheels) the rollers don't spin, so the mecanum unit functions as a normal wheel would. i assumed that since the rollers were at 45*, when the robot "crabbed" left or right, it would exhibit the same charecteristics.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
  #33   Spotlight this post!
Unread 26-04-2004, 13:40
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
If the mecanum wheels produced 100% power in the forward or reverse direction, it would be impossible to strafe. We know that this setup can strafe, so the power must be in the direction that the rollers are facing.
Another proof is to watch a video of a holonomic platform with mecanum wheels. Watch what happens when 2 wheels on a diagonal are powered. The robot moves in the direction that the rollers are facing.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
  #34   Spotlight this post!
Unread 26-04-2004, 13:58
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
George, i know 1083 wants to try to build its own omniwheels next year and i was wondering if you were planning to make them bigger than those 4.72" ones from omniwheel.com. I can't actually think of a valid reason why wheels that small are bad, but very few teams seem to use wheels that small, so there is probably a reason. Maybe a larger wheel gives you the potential for better traction. (yes, i know in theory traction is only dependent on the weight of the robot and the materials contacting each other, but in practice, it isnt that simple) Your grooved omniwheels seemed to have better traction than any others, bought or built.
Team 1257
  #35   Spotlight this post!
Unread 26-04-2004, 19:45
RogerR's Avatar
AKA: Roger Riquelme
sorry i took so long replying...
If the mecanum wheels produced 100% power in the forward or reverse direction, it would be impossible to strafe. We know that this setup can strafe, so the power must be in the direction that the rollers are facing....
thats the thing though; the only time that the mecanum wheels are acting like 'traditional' omni wheels are when the bot is moving at any angle between forward/back and side to side. when moving forward/back, they act like treads. when strafing, they act like propeller blades.
<hare-brained idea> on that note (prop. blades) i'd also like to throw out an idea that i got from watching the bots strafe back and forth. what if you were able to change the angle of the rollers? decreasing the angle would move you less distance per each "wheel" rotation, but would give you more pushing force.the angle of the rollers could be changed by a mechanism similar to the ones used to change the blade pitch on prop. aircraft. </hare-brained idea>
  #36   Spotlight this post!
Unread 26-04-2004, 23:10
George1902's Avatar
FRC #0180 (SPAM)
If we do build our own, they'll prolly be bigger. I think bigger ones are easier to make, although I'm not totally sure about that. 6" would be a good size, I think.
The main problem we had with the smaller wheels was clearance. I think our robot ended up with < .5" of ground clearance.
Thank you very much. =-]
That's probably the best argument for us using them again in the future.
George
  #37   Spotlight this post!
Unread 27-04-2004, 07:51
Zotas Zotas is offline
FRC #0177 (Bobcat Robotics)
Rookie Year: 1995
Zotas will become famous soon enough
I am interested in what you guys (Wildstang) used for the rollers that interacted with the carpet. I took a peek and it looked like you had neoprene disks, except they were not punched. Can you enlighten us?
Thank you,
Jake Mazotas
  #38   Spotlight this post!
Unread 27-04-2004, 09:54
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Thank you,
Jake Mazotas
They were 3/4" diameter Polyurethane rods (75 durometer) bought from McMaster Carr.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #39   Spotlight this post!
Unread 27-04-2004, 17:21
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
Tiffany!?
::GASP::
Not only have you guys seen one, but it was at the Florida Regional with you.
sry george meaning that nobody made wheels like us-- design that james came up with and that i got to help make and well yeah get to fix them again
  #40   Spotlight this post!
Unread 30-04-2004, 10:51
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
We (X-CATS 191) used Omni wheels for the first time this year as well... They worked very well and we even made them from scrath recycling old copier parts we pulled out of some dumpster. I'll have to get some closer pictures for ya.
We made an 8 wheel drive system that walked up the platform. It worked well except for the side traction when we were halfway up a step and then we had issues sliding.. Oh well you live and learn...
Ellery
  #41   Spotlight this post!
Unread 30-04-2004, 11:37
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Old copier parts work great for robots. We have pieces of an old one we keep in a box. Lot of good things. We about used a ratchet for our winch that would have came from one and use a couple other pieces to couple a motor to a shaft. If you look beside the van door motor in this picture you can see a piece of an old copier on its right between it and the pillow block. If you could see the top it has a little hole and says oil. We didn't use any though.
  #42   Spotlight this post!
Unread 30-04-2004, 13:04
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Talking Re: Omni Wheels Survey
I think everyones forgetting (or you just werent around) one of the proven bots out there with large omni wheels and they happend to use 6 of them they went in all directions they didnt get pushed around and there was no easy side to push them from they turned marvelously and speed and power to boot
MIM Metal in Motion 343 2002 bot still one of my fav robots of all time check them out and youll see there design ... i wanted to build something like that but i couldnt get the whole building omni wheels thing started any suggestions or things only expirience teaches u when building this nice lil wheels? things i should watch out for when tyring to build and use them?
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
  #43   Spotlight this post!
Unread 03-05-2004, 13:22
Cobbimus's Avatar
Cobbimus Cobbimus is offline
CHIEF TOR-MENTOR
#0343 (Metal-In-Motion)
Cobbimus is an unknown quantity at this point
I was primary operator on team 343 this season and would like to thank you for your comments on "Manuel Overdrive". One thing you might watch out for on your omni wheels is the fact that the small wheels on M.O.'s omni wheels are metal and this year metal was restricted from touching the carpet on the playing field, this may only be a temporary rule or permanent. Thats all the advice I have for now, but I will pass word along to our engineers and they might be of more help to you. Thank You and may gracious professionalism live on!
  #44   Spotlight this post!
Unread 03-05-2004, 13:48
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Question Re: Omni Wheels Survey
Why where they metal? what did that do?
  #45   Spotlight this post!
Unread 04-05-2004, 13:24
Generator of Entropy
FRC #2973 (The Mad Rockers)
That was definitely a sweet robot - we teamed with them to win KSC regionals (with 186 also). Kinda funny that they've switched from omni wheels to Brekoflex drive and we've switched from Brekoflex to omni wheels.
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
pic: #1018's omni wheels CD47-Bot Robot Showcase 22 19-02-2004 15:04
We need Omni Wheels!! archiver 2001 0 24-06-2002 01:02
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
