Re: gear mod
I called a place near me and asked how much it would be for a custom spur gear about 2 inches in diameter cut out of 3/16 steel plate. They said for 4 of them is would be $40-$50 apiece and would take a day.
Now, I didn't ask if they need a file to import but I assume they do. Now my problem is getting a proper drawing. Can MasterCam or Autocad do gear drawings good enough to cut from? You all might want to look at this thread too: http://chiefdelphi.com/forums/showth...g+spur +gears EDIT: One thought that crossed my mind about meshing the 32P with the Module .7 is that a 54 tooth 32P gear is about .200 larger in pitch diameter than a 54 tooth Module .7 gear. Gearing depends on the difference in diameter between the two "wheels" However, these "wheels" have teeth. The number of teeth is directly proportional to diameter of the "wheel." So in a situation meshing gears of different pitches, what makes the ratio, teeth or diameter or a bit of both? Doing this seems like one of those things that isn't supposed to work but it does. Last edited by sanddrag : 27-04-2004 at 18:34. |
Re: gear mod
some one is likely to come along with a better sounding answer, but the pitch diameter is the diameter where proper meshing should be. So when using gears that "mesh", but doesn't have the expected pitch diameter, the true pd is not being achieved in one, the other, or both gears. In that case, it's hard to say what ratio they're running at. Perhaps it's somewhere between the ratios using the dp of the correct gear and the substitute.
Re: gear mod
Unless the mesh is so bad that the gear teeth pass each other the ratio is the [Nteeth-on-Gear1 / Nteeth-on-Gear2]. Joe J. P.S. Knowing the ratio tells you the ratio of speeds exactly, but it does not allow you to know the ratio of the torques. Don't forget that the ratio of the torques is [the gear ratio X efficeincy]. This efficiency is going to drop considerably when you loose "conjugate action" (by mating involute gears with different DP's or Pressure Angles for example). Lapping or running the gears in will help in this regard, but it is no substitute for using properly matched gears to begin with. JJ Last edited by Joe Johnson : 28-04-2004 at 10:03. |
Re: gear mod
Personally, I think the 32 pitch and .7 mod meshing is awsome. In the sense that, if someone can do it well, more power to them. They have learned what few can do, defy engineering rules. We gotta get together and talk about how to send a banana back in time
![]() haha sorry for the randomness.. onto real suffs. I would buy .7 mod gears off PIC design, you can get them in steel with a .1875" face width up to about 128 teeth. I have bought a lot of gears off PIC, and I always get them in EXACLY 14 days. Very strange... By the way, wire EDM shops have gotten very cheap. While I would never get gears done there, (you can always buy better ones) I always go to EDM to get precision work done. I am working on a 3 speed shifter, and I got the intricate shifter cut into the gears for VERY cheap. 12 gears total (I made a spare set) for about 200 bucks. It was really cheap because it was the same cut. The guy even offered to harden them before they were cut for 50 bucks. Of course I could not resist. |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain help | thedillybar | Technical Discussion | 9 | 08-01-2002 21:54 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
