Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Unread 27-04-2004, 20:46
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: pic: Torque Converter
http://cvt.com.sapo.pt/toc_en.htm
Great site on all types of CVTs and thier applications.
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 27-04-2004, 21:05
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
http://www.andersoncvt.com/
This is what I was trying to emulate on a smaller scale and with one cone. I couldnt find the supplies (chain) to actually do it the way the anderson is setup but I will try to find a way to do it like it. The site you posted was awsome.
-Thanks
Pat
*edited*
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 27-04-2004, 22:08
NoRemorse's Avatar
AKA: Brian Roberts
If you use oposing cones, you can use standard v-belt. the only problem is your limited to a certain range of ratios due to the width of the belt, and the travel of the cones.
Unread 27-04-2004, 22:21
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Originally Posted by maxlobovsky
noremorse, how does the ratio changing happen? I can't see how the timing belt can move anywhere or how either of the pulleys change size unless maybe the two halfs of the cones move closer to each other...
Although it is hard to see because the tranmission is moving, there are counterweights on the nearest pulley that are meant to push the two halves together. The counterwieghts are similar to those found inside a governor and the force they apply to the pulley varies according to the rpm of the shaft.
Unread 27-04-2004, 22:53
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
494 had the weights on one end, but they also had a torque converter on the other end.
The way they explained it to me was that the counterweights changed the ratio based on RPMs and the torque converter would change it based on load.
Sounds interesting.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 27-04-2004, 22:56
Mechanical Engineer
Sitting here thinking I realized the importance of the second cone and if I put that if I sync the belt and the cones just right, I could actually put 4 ribs on the cones this way it could be a "toothed" belt going between the two cones.
This would be ideal for spinning.
Thanks for all the help. I'll post more drawings as I finish.
-Pat
*wahoo 100 posts*
2010 and Beyond
Unread 29-04-2004, 19:16
Mechanical Engineer
Okay I have revised my design and will be posting hte pics. Could I get some feedback on this design?
-Thanks
Pat
2010 and Beyond
torque converter _GP_ General Forum 8 06-02-2004 19:26
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
