Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
Unread 25-04-2004, 20:17
roboteer49 roboteer49 is offline
friend to all!
roboteer49 is on a distinguished road
gear ratios
I know this has been talked about but all i need to know is for someone to tell me what is the gear ratio to connect a chiaphua and a drill(w/ gearbox)
I am making a gearbox that simply connects the two together w/ spurs
Any other help would be great thanks!
Unread 25-04-2004, 20:34
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: gear ratios
Check out JVN's whitepaper in the white papers section. It will allow you to put in the information for each motor and find out what you're looking for.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 25-04-2004, 21:05
friend to all!
Re: gear ratios
Is this right:
Chiaphua= 5500 rpm
Drill (no gearbox) =about 19000
The ratio is about 3.5:1
I can't seem to find the rpm of the drill w/ gearbox
I think by having the drill gearbox it will eliminate more gears. I am trying to make the gearbox as simple as possible. Lighter the better
Sorry if im sounding stupid
Unread 25-04-2004, 22:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: gear ratios
Drill no gearbox 19670 rpm
Drill with Bosch Gearbox high gear 1550 rpm
Drill with Bosch gearbox low gear 460 RPM
I personally recommend the team 716 2003 single speed transmission (in the whitepapers). It was fairly simple and lots of fun to build and it worked great. It has a nice low output speed too which is good for big tires. I do suggest you get extra drill gearboxes. You should remove, rotate, and reinstall the motor cage to lock the drill in low gear, then put a blue rubber band over the shifter clips, and then a hose clamp (not too too tight) over that. That method has worked best for us. Make your drill transmissions easily removable and have extra couplers and left hand bolts ready because you will have a transmission fail at least once and the coupler never comes off (a least not without a fight) after it has been run. That's just the nature of the Bosch drill transmission in FIRST robots. But as for all the parts outside of that, flawless.
If you have any questions on the team 716 2003 single speed gearbox, contact Andy Brockway, the designer. We used it this year and made a few slight changes/improvements and have a full inventor model and you can contact me with any questions as well.
Unread 25-04-2004, 22:20
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: gear ratios
the ratio that i've seen the most when connecting the two motors and using a drill gearbox (in high) is 3.5:1, with the 35 tooth being on the chip, and the ten tooth being on the sprocket.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 25-04-2004, 22:54
friend to all!
Re: gear ratios
haha
I know what u mean, the drill gearbox was the death of our robot this year,
my team wants a dual motor next year so we are going to experiment with that over the summer. Thanks for ur input guys!
Next year I will personally double... no, quadruple check the gearbox
Unread 26-04-2004, 14:17
friend to all!
Re: gear ratios
A few Questions:
RogerR: The ratio for the drill w/ the gearbox is 3.5:1, isn't this the ratio without the gearbox.
Sanddrag: We are going to use 6 inch wheels, should I put the gearbox in high and configure a new ratio or change the ratio from the output shaft to the wheels.
I really apperciate ur guys help
Unread 26-04-2004, 20:44
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Re: gear ratios
You may want rethink using the drill motor geaxboxes, they are more trouble than they're worth. While we didn't use a gearbox, we mated the chip and drill motors to a comon shaft with sprockets and chains. The chip ran a 9 to 9 tooth, while the drill ran a 9 to 32 tooth. The match was so good, the software that was written to equalize the two motors wasn't needed. On the dyno we put out .55 hp.
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
Unread 26-04-2004, 21:25
Re: gear ratios
While I am able to visualixe this, a picture would be magnificent. Looking at any picture of a drive system is always a learning experience for me Thanks. Also. what pitch chain was it, .1475 ?
Unread 26-04-2004, 23:43
RogerR's Avatar
AKA: Roger Riquelme
Re: gear ratios
sure is, only reversed. where as you would have the pinion on the drill motor, and the gear on the chip, with the gearbox on the drill, there positions are reversed.
Unread 27-04-2004, 00:00
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Re: gear ratios
I found a good whitepaper once...I believe it was something like the Who's ctek's....they have a complete design for a gearbox using the chips and drill motors together.
Unread 27-04-2004, 00:07
Re: gear ratios
Yeah, they are team 716 as I stated above http://www.chiefdelphi.com/forums/sh...32&postcount=4
Now, if you want to use the drills in high gear with the Chiaphuas, look at what we (696) did last year or 498 did this year (same thing). Here's a pic http://www.team696.org/forum/image.php?iid=164
If you have any questions about anything drive systems related, send me an e-mail.
Unread 27-04-2004, 22:24
S.Nickens's Avatar
Morpheus
#0011 (M.O.R.T.)
Re: gear ratios
Hope this helps. We used .250 ( 1/4 ) pitch chain and sprockets. The large sprocket on the right is driven by the drill motor, you can't quite see the 9 tooth sprocket driven by the chip on the same shaft to the right of the 32. This main shaft also drives two 9 tooth sprockets which go to our reduction sprockets/shafts. There are five sprocket/shafts for the primary drive leading to the wheels.
The setup was very reliable. If you need more specs let me know.
Unread 27-04-2004, 22:38
friend to all!
Re: gear ratios
What kind of bearings do u use for the drive train?
I need to hav a bearing that can be inserted in the plate like S. Nickens
Also S. Nickens did u have to replace ur gearbox during competition, ive decided to use the gearbox in high with a 3.5:1 ratio w/ the chip.
Im not good w/ rpm, what would be the rpm of of the drive shaft so i can determine the speed, again thanks.
hehe, one last question, is there a way i can determine if the chain i use to connect 2 sprockets will not sag?
Unread 27-04-2004, 23:04
S.Nickens's Avatar
Morpheus
#0011 (M.O.R.T.)
Re: gear ratios
We used 5/16 ID flange bearings the were press fit into the side plates held in place with retaining rings.
We didn't use the gearbox that came with the drill motors. We took out the motors, pressed off the gear and made a custom shaft to adapt to the sprocket shafts. We mounted the drill motor with a custom aluminium mount that also acted as a heat shield. Both motors were mounted to the inner sideplate. I have some AutoCad drawings if you're interested.
The drill motor runs approx. 20,000 rpm, with the reduction of the 32 tooth sprocket it runs 5500 rpm, equal to the chip.The drill runs a 9 to 32 and the chip runs a 9 to 9, so you you have two motors spining a single shaft that spins at 5500 rpm. From there you need to determine your estimated velocity and wheel dia. to determine your final reduction. There are some good white papers to help you figure this out. If I can help answer any more question, just ask.
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
