Go to Post everything's bigger in [strike]Texas[/strike] Canada. - lukevanoort [more]
Unread 24-03-2002, 11:00
I am interested in this as well. The inteface to the radio modem is RS422, which uses a "balanced" wire pair for both transmit and receive. This serial protocol was developed for high speed data transfer with good noise immunity. The PWM cables do radiate though, so I am interested in a full assessment.
Teams have reported problems with radios in the past and many of them are due to common problems with mounting the modem. i.e. mounting deep inside the robot, antenna mounted against metal(especially the end of the antenna) broken wires in the serial cable and pinched or crimped wires at either connector.
Good Luck
reworking radio control for joysticks ajlapp Electrical 5 05-12-2003 17:38
cut off date? ryan_f General Forum 1 26-10-2003 16:52
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
radio meetings all star archiver 2001 9 24-06-2002 03:10
