Go to Post You know you have bad field problems if both Dean and Woodie come out to try to fix them... :) - tim_reiher [more]
  #31   Spotlight this post!
Unread 28-04-2004, 17:07
jesse27's Avatar
jesse27 jesse27 is offline
#0027 (rush)
Team Role: Student
jesse27 is an unknown quantity at this point
Send a message via AIM to jesse27
Re: Making your robot drive easier
Originally Posted by ali_rockon22
Make a really solid gearbox. I find that you don't need any more then 2 speeds. High and Low. Also you can have wheels with a high C.O.F but to make your bot turn easier you need to 6 wheel drive and lower the middle set of wheels about 5 thou lower then the other ones and there you have a killer drive system.
Team RUSH has used that same wheel set up in past years, and we used it again this season.
  #32   Spotlight this post!
Unread 28-04-2004, 19:29
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Originally Posted by Andrew Schuetze
Question about "Home Depot Lumber cart Drive-train"
Is the lowering of the center wheels as significant as is with the lumber carts? They have a definate see-saw effect and are truely always driving on just four wheels. Center set plus either set on the corners.
Or is it just enough to lower the contact patch on the corner wheels so that the frictional forces are reduced such that it can turn and not dance around corners?
A post early on indicated approximately 5 thousandths of an inch lower. Is that consistant with other six wheel 'bots? How much did you lower the center wheels?
Thanks a bunch for the posts and pics
APS
This is determinable (spelling?) based on the robot and your best judgement. Our robot used tracks as previously mentioned and we increased the size of them 4 one hundreths. It really depend on the situation (length and wheel size)
I also see a debate about manueverability of two wheel and six wheel drive. From my point of view tracks are a simple solution...as long as they are used in moderation. We found you can have too much of a good thing. We have found that by having a caster with a track extending 1/2 to 3/4 of our base we have extremely good handling and manuverability and lots of power. This is the first year we've gotten away from the caster and managed fine.
Just some thoughts.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
  #33   Spotlight this post!
Unread 28-04-2004, 21:35
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Originally Posted by Chris Hibner
I think the key to an easy-to-drive drivetrain is having the optimal lateral coefficient of friction (not the lowest). That is much easier said than done, but here is why I feel this way:
1) If you have too much lateral friction, your drivetrain will not turn well (or maybe not turn at all). This is obviously not desirable for many reasons that everyone knows, so I'm not going to explain further.
2) If you have too little lateral friction, the robot can become difficult to drive. Why? Inertia!
I couldn't agree more.
For years we had trouble tripping breakers while turning with a 4WD base due to too much lateral friction. Last summer we started experimenting with the 6WD base, and when we finally got to drive it we found it turned TOO well. Our center wheel is offset 3/16", and when we turned at full speed, the robot would basically turn on the 2 center wheels. The other wheels were still in contact, but they had very little weight on them so there was very little friction preventing the robot from turning. In high gear our robot goes about 15 ft/s, and when we turned the robot flew around at more than 1 rev/s.
We liked the extra manueverability, but it was too difficult to control with a standard 2 joystick tank drive. We ended up using a steering wheel and a throttle. See this thread for more information about how we implemented the steering wheel.
Another problem was going straight. Less lateral friction meant it was easier for the robot to turn even when one side was only slightly more powerful than the other. In our case the flip-flopped drill motors were our biggest problem, but even things like worn down treads or slightly more friction on one side could cause the robot to veer off to one side if you powered the motors at the same voltage. 980 had the same problem as us. We (254/60) solved it using prox sensors which gave us about 54 counts/rev and allowed us to adjust the voltage being sent to one side to keep it going straight. 980 used a gyro (the ADXRS150EB) in basically the same way. We were going to use a gyro too, but Analog Devices ran out of them.
I don't like the 2WD idea because it would be way too manueverable. You need some friction out there on the ends of your robot to provide some torque to slow you down while turning. And if you try to solve it by adding more friction to the skid-plates then you just lose power when you want to go straight. You can try to solve it using software and sensors (and in fact I'm probably going to work on something over the summer to use sensors to have the robot maintain a certain orientation), but it's not going to be easy.
We plan on sticking with the 6WD at least for the next couple of years. Sure there are alternatives out there (treads, swerve, holonomic), but as John said 6WD is a great combination of strength and agility.
Team Communication - Making it easier Balbinot Website Design/Showcase 3 10-02-2004 13:50
What motors do you use to drive your robot? _GP_ General Forum 25 25-01-2004 21:14
Rookie team drive tream idea Max Lobovsky Technical Discussion 18 21-01-2004 03:36
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
