Go to Post There's the problem!! The #1 reason to blame the programmers: They always forget to grease their code. :rolleyes: - Jack Jones [more]
Unread 28-04-2004, 22:25
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Who Likes Wheels?
OK, now that it is the offseason, many of us are coming up with concepts to possible use next year. Lots of people are also going over their favorite features of other teams machines. Why don't we share some info?
Wheels are fundamental to the operation of a FIRST robot. What types of wheels does your team prefer, and why?
If you buy your wheels, please list (and say why):
Source
Material
Size
Durometer rating (if applicable)
If you make custom wheels, Please list (and why):
What materials you use
How they are designes/assembled
What the wheels use as tread material and how it is fastened to the wheel
Don't feel left out if you like tracks! Tell us about them as well!
Hopefully everyone can get share some good info that we can all benefit from.
Thanks!
Rob
Unread 28-04-2004, 22:49
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: Who Likes Wheels?
Every year I explain this to an onlooking kid or a judge, I get the same response: "Wait... what the... is that wood?"
For several years, 188 has gone with a very cheap and effective method of making our own wheels. Once the gearbox design is completed and we decide what size wheels are optimal, we simply make them ourselves. A few pieces of plywood, a lathe, and some carpenter's glue do the trick. As you can imagine, the time it takes to make cylinders of wood is well within one night and can be performed by one or two people. We've experimented with a number of things including metal C-channel (back when that was legal) and numerous rubber treads, which we only have to fasten on with wood screws (they are far enough in that they don't contact the carpet, but still worry rookie inspectors every time). Sometimes we modify the tread's shape for lateral motion. We bolt in a sprocket and Forstner out some material to finish off. People are always surprised by the amount of traction we get from wood and rubber screwed together, but usually don't even realize that our robots have wooden wheels to begin with, because we paint them metallic colours. It looks pretty cool.
Anyway to sum it up, we get awesome traction, wheels to our specifications, and low weight, all for a lower price than getting them made or buying them off the shelf. Ghetto? I think not.
Unread 28-04-2004, 23:19
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Well.....
Last year we experimented with gum rubber. MMMMM I lub that stuff.
As some or many may know, we cut out roughly 8" circles of 1" gum, and then cut the middle out of them to make it lighter in the final design. We then took 2, 1" thick gum rubber circles (cut out with hole saws) and sandwiched them in 3 pieces of 1/8" aluminum and secured them tightly together with screws. EW also made hubs to attch sprockets to, out of round stock aluminum 3" I think. We ended up with 4 wheels that had 2 gum rubber cuts in side. 8 traction points. The wheels were, dually's if you will. The gripped like mad. We still can boast no person can puch or robot. We haven't tested on other bots cep for matches and stack guarding (we would tip over before these wheels would slide, (we didn't tip)). They were nice. I rember one match in a mini were 341 (Daisy) tried to take down our 4 stack. They ended up pounding away at us and bending 1/8" physical limits for our arm, but the stack stood. Their drivers were persistent, and would not give up. That was a fun match .
Man I love those wheels. And I think, if memory serves, we won the KOH (king of the hill) contest at Ramp Riot. Because of their traction on the ice.
They wieghed about 8 lbs each though. We will find a way to get them back, and underweight if need be, I am sure of it. mwahahahaha.
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 28-04-2004, 23:31
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
http://www.skywaytuffwheels.com/2002/products_002.htm
Basic 9 inch or so skyway wheels. They work great....enough traction...but not too much like those pneumatic wheels...where you can't turn.
Unread 28-04-2004, 23:35
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Hence the joy of a 2 wheel drive conversion system.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Hinkel Y.'s Avatar
Hinkel Y. Hinkel Y. is offline
FRC #0188 (Woburn Robotics)
Hinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura about
Send a message via MSN to Hinkel Y.
This year, ours weighted around 2 lbs. (with sprokets and chains) and lathed down to as much as possible cuz of the weight... But a word of advice... MAKE SURE YOUR SCREWS ARE WELL FASTENED!!! Let's just say we had an incident once with our programmer and our robot doing something bad...
Note: It wasn't any of the student's idea to choose the colour gold for our wheels...
Unread 28-04-2004, 23:36
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
We decided to use 8" pneumatic wheels on the front and back this year. We learned a couple things:
1. We had amazing traction. With a 4 motor drive system and these wheels we had excellent torque and the pneumatic wheels could really transfer that power to the carpet.
2. We also learned that with both the front and the back using pneumatic wheels we had poor maneuverability. We had the bouncing while turning problem.
We'll definately be experimenting with using a different wheel types on one side during the off-season; I'm pushing for omni-wheels.
Unread 28-04-2004, 23:50
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Originally Posted by Henry_222
Well.....
-Henry
Yep, I remember that very well.
Weren't we against eachother at several minis? I can see that scene all over again, like 2 or 3 times, just you guys zooming under the bar and guarding your stack. We couldn't budge ya (but then yeah, our drivetrain was dead. It's so sad now, daisy2 barely moves at all).. When she was alive we had special sticky wheels as well, and I only remember one team pushing us off cleanly (68)- although I don't remember 222 ever trying to get us off the ramp..
-I'd definitely reccomend these gum rubber wheels for anyone who's looking for mad traction, just be ready to use some kind of drop-down caster system or something to turn...
Unread 29-04-2004, 00:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We have used the same wheels Mike used for the last 3 years. I remember when we were one of the few teams in 2002 that used them, and then a bunch more last year, and tons more this year.
Just goes to show you how great they are
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 29-04-2004, 01:06
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
We use go-kart racing slicks. They we like 9" last year and 12" this year. We got them from Carl's Tires (local) but I imagine you could find them if you look. They are pneumatic, rubber, are wide and have a lot of traction. They work great on carpet, and the plastic surfaces. I've yet to see anyone push us with those wheels on the ground. They are connected to sproket with machined hubs. But downside is in the weight. This year each wheel weighed in at about 6 pounds. That is about 24 pounds of wheels.
BTW, I like the wooden wheels. I've made eduwheels out of foam board and electric tape.
Unread 29-04-2004, 07:43
Ben.V.293 Ben.V.293 is offline
Ben.V.293 will become famous soon enough
Send a message via AIM to Ben.V.293
Team 293 usually uses milled alluminum rims that we wrap with rough top conveyor belting that we get from mcmaster. The belt we get is on catalog page 1089. The belt gets lots of traction and has always worked out well for us.
Ben Van Selous
Unread 29-04-2004, 07:49
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Yeah we had the same problem two years ago. We ended up using tires twice the size of yours. The problem was fixed using duct tape believe it or not and going to two wheel drive.
Unread 29-04-2004, 08:00
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
We used the 12" pneumatic wheels from the kit in the front and 8" pnuematics in the back. For the past few years we have used pnuematics and while they provide awesome traction, that is the tradeoff for poor maneuverability. At the beginning of this season we were going to have the same problem again until we went to Quincy. A few teams there had bought what I think is some sort of pool or plumbing tubing. Cutting those in half and tie-wrapping them around the back tires provided us with what you might call cheap and easy omni wheels. The ridges gripped for some decent traction going forward and back and let us slip to the side when turning. For any team who needs a quick fix I recommend going to Home Depot or another home supply store to pick some up. i don't have a picture handy but if I find one I'll put one up.
-Tom
FRC78: 2010-Present
FRC121: 2002-2009
Unread 29-04-2004, 09:09
See the back left wheel here: http://firstrobotics.net/04Gallery/i...0069-1_jpg.jpg
Unread 29-04-2004, 09:14
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Originally Posted by Joe Ross
That stuff is really awesome! It's a cheap and viable alternative to building your own omni wheels. The only problem (that we had) is that the tubing had a tendency to slip to one side or the other, and it's kind of a pain to replace, because you have to position the zip ties in such a way that they don't stick out and have sharp edges. It's also kind of hard to cut straight.
But it's still good stuff.
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
