Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Go Back   Chief Delphi > Other > Math and Science
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 26-04-2004, 11:07
SchmitTheNordic SchmitTheNordic is offline
SchmitTheNordic is an unknown quantity at this point
nother egg drop contest
We are having an egg drop contest as part of a mechanical engineering class, but we have a few restraints.
1. Minimize weight
2. Fall as close to a target as possible
3. Must use a drag inducing device of some sort (i.e. parachute)
Our height is only 25 feet, and there are no size restrictions, only weight and accuracy count. Any ideas would be greatly appreciated, thanks in advance for your time.
Unread 26-04-2004, 11:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: nother egg drop contest
If this is indoors, a parachute would work, since there's no wind. you could make it small enough to provide some drag, but not move off course, or larger with a hole in the center. If it's still moving pretty fast, put some sort of structure on the bottom that will crush inward when it hits the ground, transfering the force of impact into that instead of the egg.
Good luck,
Cory
2001-2004: Team 100
2006-Present: Team 254
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Here ya go...check these threads out...
Egg Drop
Egg Drop (Old)
Why are peoply always asking for assistance with their egg drop projects? Can't you just figure it out on your own....
Unread 26-04-2004, 11:35
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Anecdotal Egg Drop
A guy I know always likes to talk about an egg drop contest he saw in college. The winner was the egg that fell from the highest floor without breaking, with tiebreakers decided by flight time (the shorter the better).
The design that won was a steel tube, capped at one end, filled with a viscous fluid. The tube had fins along the back, looked somewhat like an upside down rocket, and was very heavy. To use it, you simply floated the egg on the fluid, and let the beast go. The only problem was that when the "rocket" landed, it would bury itself (bomb-style) in a concrete courtyard. After three or four drops resulting in three or four successively bigger holes (but no broken eggs), the contest judges finally decided to award the designer the prize, as long as he didn't drop it anymore.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 26-04-2004, 12:12
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
We had an egg drop contest in 5th grade. The rules were a little different, but it was still a lot of fun. You had to make a container that was rigid, weighed at least one pound, and could protect an egg from an eight foot drop, a twenty foot drop, a fourty foot drop and a three hundred foot drop.
I made it to the fourty.
I haven't updated my signature since last May. Who wants to suggest a replacement?
Unread 26-04-2004, 21:52
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
I just did one in physics and we could only use five feet of paper and a foot of tape....really light weight....make a cone the long way of an 8.5 by 11 and stuff it then use a parachute for drag (i think you said you have to use a drag device), my egg won from a drop of 40ft.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 26-04-2004, 22:30
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Googled it and found this:
http://www.niemworks.com/else/im/eggdrop/jeff_b.jpg
http://www.niemworks.com/else/im/eggdrop/jeff_m.jpg
http://www.niemworks.com/else/im/eggdrop/richard.jpg
Unread 29-04-2004, 13:52
RiceRobotica RiceRobotica is offline
"Can I touch your hair?"
AKA: Becca
#0870 (Team RICE)
Team Role: Operator
RiceRobotica will become famous soon enough
Send a message via AIM to RiceRobotica Send a message via MSN to RiceRobotica
I had an egg drop recently and our restraints were much different. It must be the size of a shoe box, not a boot box. We could have NO kind of restraining drag. No parachutes, no bubble wrap, packing peanuts or expandable foam. Well, I filled a box with rice krispies, made a 3 way hammock with panty hose that the egg sat in and covered the box in air filled balloons. The balloons acted just like when the mars rover dropped and cushioned the fall. It actually help up the acceleration a bit, but it was constantly accelerating the entire time, just slower. The top and bottom, long, thin balloons would pop, instead of letting it bounce and possibly break the egg. It worked quite well. The class, though, made me take the balloons off. Needless to say, rice krispies were everywhere.
No. Really. I'd really like to touch your hair!
Machinist and Strategist/Drive Team Mentor
870 Team RICE
2003 UTC New England Regional Johnson & Johnson Sportsmanship Award winners
2003 SPBLI Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award winners
2003 SPBLI Regional Champions
2004 SPBLI Xerox Creativity Award winners
Unread 29-04-2004, 15:26
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
You could possibly use a helium filled balloon as the drag and it would help slow the decent enough so that the impact of hitting the ground wouldn't break the egg. Then fill a cup with house insulation material and put the egg in the middle of the insulation. Then tie the balloon to the cup and bombs away. Make sure u have just enough helium in the balloon so that it just barely drops. The impact of hitting the ground should be close to none.
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 29-04-2004, 18:13
AKA: Becca
#0870 (Team RICE)
Team Role: Operator
Well, the thing was, Steve... With mine, it was just regular air filled balloons. They increased the surface area, but with a little space in between, some air could filter through to make it stay balanced. This is what it looked like with the top off. The top had two long skinny balloons duct taped to it and the top strand of panty hose was pulled through a hole there, suspending the egg in the middle of the box.
870 Team RICE
Unread 29-04-2004, 18:53
Team311's Avatar
Team311 Team311 is offline
School Is Boring
#0311 (Red Jammers)
Team311 will become famous soon enough
the last egg drop contest that my troop had i took a small ups shipping box and put the egg in two peices of egg carton. and then filled the box with towels and closed the box. they dropped it from the top of the highest tree they could find and the egg didnt break.
-2002 Long Island Regional Chairman's Award Winner
-2002 Einstein Division Champion and #1 seed
-2002 National Finalist
-2002 BattleCry@WPI Champions
-2003 SBPLI Website Design Award Winner
-2004 UCF Regional Finalists (thanx 233 & 1144)
-2004 SBPLI Imagery Award Winners
-2004 SBPLI Regional Champions(thanx 1114 and 229)
-2004 SBPLI Regional Engineering Inspiration Award Winner
Unread 30-04-2004, 23:25
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
i had an egg drop contest for my classes at FAU last summer... and i was only allowed to use two sheets of newspaper and 12 inch piece of tape... i technically made a cylinder where i had the egg secured and then a cone.. which would make a face like a rocket... had the egg about 8 inches off the ground (when it touched the groud)... so the tips of the cone will be smashed and the egg would be secured... i dropped that from 5th floor and it still did not break... since you are allowed to use anything... why not try putting some foam or something soft around the egg and then secure it in the cylinder...
Where in the World is GizMOE Today Contest Bill Enslen Robot Showcase 43 05-05-2004 13:20
Egg Drop Contest Matt_Kaplan1902 Math and Science 27 02-02-2004 14:45
NEW 2004 Repeat contest - Pioneer HS, AA MI wishes to Host kmcclary Off-Season Events 0 23-09-2003 13:34
Egg drop help Please..:-) archiver 2000 9 23-06-2002 22:49
Rookie Team needs to borrow a FIRST goal for CDI contest kmcclary General Forum 7 17-10-2001 19:49
