Torque curves
So I have a question about torque curves. I have purchased this motor:
http://www.lynxmotion.com/Product.as...&CategoryID=11 I have asked the seller for a torque curve for the motor and they tell me they don't have one. Can I make my own torque curve for the motor without testing it? I was thinking a linear fit between the stall torque and the no load RPM. Would this work? Should I use a different fit? Any help would be awesome. thanks. |
Re: Torque curves
Actually, linear interpolation does work (Adam - I actually took the time once and worked through all the equations and theory you mentioned, and it works out very nicely - at least for the drill motor, which is what I compared my theoretical results to).
Anyways, don't take my word for it - Joe Johnson posted a spreadsheet a couple of years ago which asks you for a few simple parameters (voltage, stall torque, stall current, free speed, free current) and comes up with plots of speed, torque, power, and efficiency. It also has a sheet of information on FIRST motors (although be careful; the Fisher-Price motor is certainly out of date, and others may be as well). |
Re: Torque curves
Re: Torque curves
John |
Re: Torque curves
You guys ROCK!!!!!
Thanks to all |
| Power, speed, and torque... AGH | Gui Cavalcanti | Technical Discussion | 5 | 10-11-2002 19:02 |
| Friction, traction, torque - oh my... | Gui Cavalcanti | Technical Discussion | 30 | 13-08-2002 18:01 |
| How fast could a torque motor turn if a torque motor could.. | archiver | 2001 | 0 | 23-06-2002 22:54 |
| Drill motor torque curve | thedillybar | Motors | 1 | 10-03-2002 05:19 |
| Traction Limited, rather than torque | Simon G | Technical Discussion | 6 | 23-01-2002 07:08 |
