Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 29-04-2004, 09:45
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Programming via Edubot
I work as the programmer for my team, but the computer on which I am able to do my work is at home. It would be nearly impossible to bring the robot to my house, so I was wondering if it was possible to download code onto the EDU RC from the computer and then somehow use the EDU RC to download the code to the robot.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 29-04-2004, 10:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Programming via Edubot
Not in any known way. Have a laptop?
Unread 29-04-2004, 10:58
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
A pen drive would work. Our team uses ours for everything. Programs, graphics, and everything else. You can get 30 mb cheap and a mp3 will double as one.
Unread 29-04-2004, 13:16
I's a long way to go between home and school if you need to make a single code change.
Your project will also easily fit on a standard floppy if you first delete the unnecessary automatically generated files produced by the compiler, linker, etc. (.o, .cod, .cof, .lst, .map)
Unread 29-04-2004, 13:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
That's what I use (but a beefier 128 MB. I carry all the docs, too.). (The Muvo is the only USB key that doubles as a mp3 player). But you still need a laptop. If your school has computers, see if you can use one of them (just put IFI_Loader on the key). If not, see if one of your sponsers will 'lend' you a computer.
Unread 29-04-2004, 15:21
Joshua May's Avatar
Go Bears!
Another team member has a laptop that I have used in the past, and we're thinking about getting a team laptop, nothing special but something that does the job. The computers at our school won't allow us to put software on them, but I'm going to try to get administrative access to those, that would be easier.
Also, for our robot next year, I plan to have a removable component which holds the electronics and the RC (similar to 830's this year) and I could just transport this back and forth, at least between the shopa nd the computer lab.
Thanks for the responses!
Unread 29-04-2004, 15:27
Yep, your only option right now is to disconnect the RC and take that home for downloading. Aside from the pain of disconnecting and pulling out the RC, you'd just need the 7.2v battery and at least a standard 9v battery to run the RC long enough to download your code changes.
Or a REALLY long cable!
Unread 29-04-2004, 16:02
Programming User
You can't power the RC from the 7.2 volt without first attaching it to the main power supply. Don't know why. Don't think it's possible to program with it either, even if the RC is using the power from it.
Unread 29-04-2004, 17:07
Ah, but it is possible.
The RC will resort to the backup battery when the 12 volt supply fails.
Since it won't START using only the 7.2v, all you need to do is fool the RC into thinking a 12v source is there at startup. A fresh 9volt battery just touched to the 12v terminals will fool it into thinking a somewhat drained 12v battery is actually being used. That's how we normally started our RC in the pits to drop in program changes when we didn't want to power-up the whole robot, i.e., when the drivetrain was under repair at the same time.
Unread 29-04-2004, 18:55
Programming User
Clever. Never thought of that. But can you actually program it using the 7.2v? I'm wondering because writing FROM tends to put a relatively heavy load on the power source.
Unread 29-04-2004, 19:07
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Yes you can download running only on the 7.2 volt battery because one time while working on autonomous mode I really wanted to download a program but our main batteries just died so we pushed the robot till the drill motor put out enough voltage to start the RC so I could download the program.
Unread 29-04-2004, 19:18
Programming User
Thanks for clarifying that for me. That method is even more clever than the nine volt one.
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
Programming the IR James Hine Programming 1 10-03-2004 14:08
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
pbasic programming punarhero Programming 4 21-01-2002 23:32
