Go to Post Who says girls can't be cute, fun AND SMART?!? - Marisa Russo [more]
Unread 18-02-2004, 20:11
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
Makefile for programming under Windows with cygwin
I have been forced into the unfortunate situation of having to program the robot under Windows this year. I also can not stand the MPLAB IDE. This is why I wrote this makefile, so I could program the robot with Vim, and use cygwin/make to compile it. (For those of you who don't know, cygwin allows you to use most common Linux commands from Windows. You can get it here: http://www.cygwin.com/)
If my server is up, you can see an pretty HTML version of the makefile here --> http://wolever.no-ip.com/makefile.html
If its down, I have attached the original makefile so you can use that.
You shouldent have to modify it too much - the only thing you will have to change for sure is the path to your code (unless you keep your code in c:\robotics\FrcCode\)
I hope this helps!
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 21-04-2004, 05:26
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Makefile for programming under Windows with cygwin
Very cool, thanks for you help guys.
Unread 21-04-2004, 06:57
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Thanks a ton. I strongly disliked the IDE too, but never was able to write makefiles that worked for unknown reasons...
Unread 21-04-2004, 07:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I don't like MPLAB much, but it's good enough. (I've worked with worse; BrixCC, MSW LOGO, Notepad...). But I do need an excuse to learn Linux.
Unread 24-04-2004, 21:16
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
During Nationals, I modded this makefile, and mine is a bit 'fancier'. It's well-commented, and needs a bit of editing to remove 245-specific code (i.e. trig.c arm.c arm.h, etc)
Oh yeah, try "make me a sandwich". DONT ASK!!!
#Team 245 Adam-Bots
#Makefile -- Designed to make the robot's .hex file under Cygwin
#Created by John Dong -- Team 245 jdong@wideopenwest.com
# Based on WUN's code on ChiefDelphi
MCC18=/cygdrive/c/mcc18/bin/mcc18.exe #Don't change
PIC=18F8520 #Also don't change -- will cause compiles to fail.
#Common Arg flags
#-D_FRC_BOARD -- Enables FIRST extensions -- must be on!
#Oi -- Enable Integer Promotions
#w  -- warning level (3 highest, 1 lowest)
#O-  -- Disable all optimizations
#pa=? -- Procedural abstraction passes.
ARGS=-D_FRC_BOARD -Oi -w3  -pa=3
LINKER=/cygdrive/c/mcc18/bin/mplink.exe
IFILOAD=/cygdrive/c/Program\ Files/IFI_Loader/IFI_Loader.exe
#Change this to the place where your code is stored (to windows - you cant use the cyg directory)
#NOTE -- Add an ending \\ to the folder name -- required later!
CODE_PATH=C:\\jd-code-cygwin\\
	#you gotta have the two \\ or make thinks they are escape codes
#OPTIONAL -- Recompile when hfiles change.
INCLUDE_FILES=arm.h bits.h deadreckon.h delays.h ifi_aliases.h ifi_picdefs.h ifi_utilities.h interrupts.h printf_lib.h pwm_curve.h trig.h user_routines.h
#You should not need to change the following two.
LIB_PATH=C:\\mcc18\\lib
INCLUDE_PATH=C:\\mcc18\\h
abcd:make
me:
	@echo "What kind?"
a:
	@echo "You're too slow....."
sandwich:
	@echo "Here you go!"
	@echo -n
	@echo -n
	@echo " =========      <-- BREAD"
	@echo "~~~~~~~~~~~     <-- mmm, CHEESE"
	@echo " ^^^^^^^^^      <-- Use your imagination..."
	@echo " *********      <-- Like this could be meat..."
	@echo " =========      <-- well, at least this is BREAD"
	@echo -n
	@echo -n
#Default -- make the hex file
make: FrcCode.hex
#Saves a timestamped tbz2 backup
backup: FrcCode.hex
	./backup.sh
#Checks default libs
check:
	./chklib.sh
#Remove all the individual file backup (The files ending with ~)
#NOTE that this does NOT remove your tbz2 backups!
clean-backup-files:
	rm -rf *~
#Removes all compiled files from the directory
clean:
	rm -rf *.o Frccode.hex *.cod *.cof *.err *~ *.rej
#Remove hexfiles
nohex:
	rm -rf *.hex *.cod *.cof
auton_test:
	patch -f < auton-test.patch
auton_notest:
	patch -Rf < auton-test.patch
#These all start the IFI Loader.
safeload: prettycode clean check load
load: FrcCode.hex
	echo ${CODE_PATH}FrcCode.hex > /cygdrive/c/Program\ Files/IFI_Loader/LastHexFile.txt
	unix2dos /cygdrive/c/Program\ Files/IFI_Loader/LastHexFile.txt
	kill `ps -s | grep IFI_Loader`>crap > crap || true > crap > crap
	rm crap || true
	nice -n 5 $(IFILOAD) &
prettycode:
	indent *.c *.h && rm *~
all: clean FrcCode.hex
FrcCode.hex :  ${INCLUDE_FILES} main.o user_routines_fast.o user_routines.o printf_lib.o ifi_utilities.o ifi_startup.o arm.o bits.o deadreckon.o interrupts.o pwm_curve.o trig.o
	$(LINKER) /l"$(LIB_PATH)" "18f8520user.lkr" "$(CODE_PATH)main.o" "$(CODE_PATH)user_routines_fast.o" "$(CODE_PATH)user_routines.o" "$(CODE_PATH)printf_lib.o" "$(CODE_PATH)ifi_utilities.o" "$(CODE_PATH)ifi_startup.o" "$(CODE_PATH)arm.o" "$(CODE_PATH)bits.o" "$(CODE_PATH)deadreckon.o" "$(CODE_PATH)interrupts.o" "$(CODE_PATH)pwm_curve.o" "$(CODE_PATH)trig.o" "$(CODE_PATH)FRC_library.lib" /m"FrcCode.map" /o"FrcCode.cof"
printf_lib.o : printf_lib.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "printf_lib.c" -fo="printf_lib.o" /i"$(INCLUDE_PATH)"
user_routines.o : user_routines.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "user_routines.c" -fo="user_routines.o" /i"$(INCLUDE_PATH)" $(ARGS)
user_routines_fast.o : user_routines_fast.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "user_routines_fast.c" -fo="user_routines_fast.o" /i"$(INCLUDE_PATH)" $(ARGS)
main.o : main.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "main.c" -fo="main.o" /i"$(INCLUDE_PATH)" $(ARGS)
ifi_utilities.o : ifi_utilities.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "ifi_utilities.c" -fo="ifi_utilities.o" /i"$(INCLUDE_PATH)" $(ARGS)
ifi_startup.o : ifi_startup.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "ifi_startup.c" -fo="ifi_startup.o" /i"$(INCLUDE_PATH)"$(ARGS)
arm.o : arm.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "arm.c" -fo="arm.o" /i"$(INCLUDE_PATH)" $(ARGS)
bits.o : bits.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "bits.c" -fo="bits.o" /i"$(INCLUDE_PATH)" $(ARGS)
deadreckon.o : deadreckon.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "deadreckon.c" -fo="deadreckon.o" /i"$(INCLUDE_PATH)" $(ARGS)
interrupts.o : interrupts.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "interrupts.c" -fo="interrupts.o" /i"$(INCLUDE_PATH)" $(ARGS)
pwm_curve.o : pwm_curve.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "pwm_curve.c" -fo="pwm_curve.o" /i"$(INCLUDE_PATH)" $(ARGS)
trig.o : trig.c ${INCLUDE_FILES}
	$(MCC18) -p=$(PIC) "trig.c" -fo="trig.o" /i"$(INCLUDE_PATH)" $(ARGS)
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 29-04-2004, 20:57
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
nice work *gives thumbs up*
When I get to it with my grade 9ns who I am teaching C (this year I was the only programmer on our team) I will fix up my version to support sandwitch and header files (I didnt do much work with header files, so I forgot I had to include them).
Im glad you guys like it thou
Unread 29-04-2004, 21:04
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Very, very, nice work.
I should be able to convince the Windows-Nazi Administration at my school to LFS (yeah, I guess that's a verb now) the laptop they gave me.
If not, this will provide me solice.
Oh, and while I'm at it:
Emacs sucks
Anyone care to start the editor holy war thread?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 29-04-2004, 21:11
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
Originally Posted by phrontist
Emacs sucks
I totally agree
Unread 30-04-2004, 14:25
AKA: Jamie Bliss
But I would love to scrape the Apple logo off and run Redhat. (And OS X is unix based)
Unread 09-05-2004, 11:08
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Correction... OSX _IS_ Unix...
John Dong
Unread 03-09-2004, 11:33
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
In preparation for the new FIRST season, I'm rewriting the makefile to run under Linux, calling MCC with wine when necessary. I'm also working on a LiveCD that'll include the PBASIC Stamp editor and MCC (in some fashion) and wine.
John Dong
Unread 03-09-2004, 19:11
Umm Errr...
Now that would be NICEE!!!
1139 Alumni
Unread 03-09-2004, 22:32
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Keep in mind that you would not be able to distribute such a CD if you finish it, since MCC is a commercial product that you're not allowed to redistribute (unless I'm mistaken).
Unread 04-09-2004, 14:35
Umm Errr...
It seems to me that we all have legit C18 licences and as long as we don't violate our licences he would not be doing anyhting illegal. Besides do you think any of us or anyone at microchip for that matter even care? We are not defrauding them of anyhting. *hides in fear of flames*
1139 Alumni
Unread 16-09-2004, 21:38
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
The version of C18 that they provided us (C-Bot) is a stripped version of mcc -- its hex files are IFI-specific -- they will not run on any old PIC18Fxxxx
Furthermore it does _NOT_ come with a license agreement on the CD. I've contacted both IFI and Microchip, asking about licensing & permission to distribute the .exe on a LiveCD.
John Dong
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
