Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Unread 30-04-2004, 03:21
Amanda M's Avatar
Amanda M Amanda M is offline
dpl
AKA: M/C Cord
Amanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to allAmanda M is a name known to all
Send a message via AIM to Amanda M
Re: Any pictures for Centered 2-Wheel Drive?
our (60) 2004 design was a little different, but I think it does the same thing. It had six wheels with the two center wheels being 3/16 of an inch lower than the other four. It was very maneuverable and reliable. If you want to check it out, look at http://www.team60.com (I don't have a direct link)
hitomi o tojite sora o miage hadashi no mama de odoritsuzuketa
kaze ni motare...
Close your eyes, look up at the sky, and keep dancing barefoot against the wind...
Unread 30-04-2004, 10:01
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
I have many pictures of the 263 2 wheel drive robots from 2001 through 2003 if you are intereted you can IM me for some more detailed ones and things you want to make sure you don't do.
2002:
http://firstrobotics.net/02gallery/pages/263-1_jpg.htm
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
Quatro 4 wheel drive ufa_mike Control System 1 14-04-2004 21:45
independant 4 wheel drive ufa_mike Control System 21 07-04-2004 01:20
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
