Go to Post No matter their age, no matter their generation, every mentor and student must be responsible for their actions, and for understand that compromise and maturity are the paths to team success. - Eugenia Gabrielov [more]
Unread 28-04-2004, 21:47
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Next years Design for our chasis
The attached drawing files show our wheel for next year, and a possible chasis. Sorry the drawings are a little sloppy, i am out of practice.
The just is please tell me what you think
:EDIT: Sorry guy wont let me upload.dwg files if you want to see them i will email them to you
:EDIT: I added the files in Zip format. ENJOY!!!!!!!!!!!
"I'm sorry, after all he is just a wookie!"
Unread 28-04-2004, 21:56
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Re: Next years Design for our chasis
Screen capture it and save it as a .jpg, Then you can attatch it.
I Hate Signatures!
Unread 28-04-2004, 23:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Or you could zip it and attach that.
Unread 29-04-2004, 23:45
It's a Bird
AKA: BoogyShoes
Ok I took a look at the drawings and I'm confused. Your wheel is 3 inches in diameter and 3 inches thick? Any particular reason for that? and what's with the little holes?
I Hate Signatures!
Unread 30-04-2004, 15:37
dddriveman's Avatar
AKA: Driveman
I want to try for low profile wheels for next year. The green holes are Set screws, and in the chasis.dwg file the little yellow holes are the axles.
If any more questions let me know
Unread 30-04-2004, 15:51
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Next year I want to build a spherical robot. Just because I'm crazy like that.
And my spherical robot will kick your robot's butt.
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 30-04-2004, 15:52
It's a Bird
AKA: BoogyShoes
I tried to IM you but couldn't get a hold of you. A few things. Are you planning on keying the wheels? Because set screw won't hold it on there. Second is why do you want the wheels 3 inches wide? I can understand low profile, but they don't need to be that wide.
Anyway my hat is off to you for starting early.
I Hate Signatures!
Unread 30-04-2004, 16:20
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
how thick and of what material are the square cross section members that make up most of your chasis and how do you plan to join them?
Team 1257
Unread 30-04-2004, 17:37
dddriveman's Avatar
AKA: Driveman
The material is 80/20 that is one inch thick. I plan on either welding it or using the angle brackets.
TechnoKat design usage, communicated with judges Andy Baker General Forum 13 24-03-2004 17:37
Design Sharing Rod General Forum 32 14-01-2004 22:00
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
