Go to Post I am a geek. - Andy Baker [more]
View Poll Results: What did you think of the Backup Battery???
It was a good new feature i wanna see it again. 54 59.34%
It was ok but a pain at time (neutral thoughts). 25 27.47%
Why did we have to use it, dont bring it back! 10 10.99%
Other, post your thoughts below. 2 2.20%
Voters: 91. You may not vote on this poll
Unread 02-05-2004, 16:27
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
Re: Backup Battery...Yay or Neh?
we never seemed to have a need for the back up battery aside from competition when it is required we don't even plug it in.
and as for turn off the RC we were told at the SLT regional by IFI after the third time we forgot to plug in the battery.
Unread 02-05-2004, 16:51
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by jimfortytwo
I wonder if those who unconditionally hated the backup battery have had the pleasure of the low-voltage reset before?
Note I don't like the backup much, but that I did mention that.
Unread 02-05-2004, 18:20
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
To all those who are indifferent about the backups, just don't worry about them and you'll be fine. The RC still runs off of the main battery, and a lot of teams will never have to worry.
To us, they are a godsend, considering the current draw our robot has. Two years ago, when we tried six motor drive for the first time, lack of a backup battery was one of two major setbacks; this lack of available power would cut out our RC in pushing matches. In 2003, they fixed the other problem with the nice 120 amp breakers we take for granted (which used to sometimes pop when we stalled our gearbox). Finally this year the second problem was fixed and we no longer have to worry about our RC cutting out after too much pushing.
In the end, there's nothing really that should make you unhappy with the backup batteries; either they are very useful, or they are neither bad nor good.
Unread 02-05-2004, 18:56
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Originally Posted by MikeDubreuil
Oh okay thanks, 2.5 minutes. Seems unnecesarily long, but it's a step in the right direction.
What i was told about time delay shut down after the main power is cut is for matches. When the power is cut or a main battery is lost during a match, or even if the main battery is never turned on, but the "back-up" battery is still there, the LED's still blink. Other then the LED blocks this year your robot alone has no alliance distinction (red or blue) while on the field. The time length supplies the estimated amount of time it would be from the start of a match until the scoring of that match is completed by the refs, so they know who is red and blue right away. Now also when your bot was under arena control and lost the main battery, the light pace changed if the bot was being powered by only the smaller "back-up" battery.
-Michael Dessingue
Unread 02-05-2004, 19:04
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Excellent, I forgot about that. It looks like 2.5 minutes was a good choice after all.
Unread 02-05-2004, 19:59
Avarik Avarik is offline
Avarik is an unknown quantity at this point
I thought it was a really good idea, and it seemed to help with loss of radio packets. In talking with some of the IFI guys when we didn't have our backup battery plugged in for a match or two, they noticed we had a much larger loss of radio packets then those teams who did have backup batteries!
Unread 03-05-2004, 13:14
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I liked knowing the robot would not reset on the field. What I would like is someway to know the voltage level in real time just as we have with the main battery. Several times the IFI person came and told us, just as a match was starting, that our back-up was dead. We had to play with the hope that there was enough juice to power our winch latch servo. Luckily each time it was when we had switched starting positions on the field and it was our partners that had not been plugged in or they never charged it because they did not need it.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 03-05-2004, 13:56
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
That would be a definate improvement if we the operator could tell what the voltage on the backup batter was.
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 03-05-2004, 14:49
Carpe diem
If you use the 2004 Dashboard Viewer it will tell you how charged the backup battery is.
Unread 03-05-2004, 15:05
I like the time delay operation of the RC using just the backup battery. We used it pretty extensively to test over in the programming corner without having to setup a 12v power supply. It was also handy just dropping new programs in without having to power-up the rest of the electrical sub-systems.
You can use the User Mode display on the OI (or the dashboard) to display the backup battery voltage, just like the main battery display. You just need to use the matching code. I think the default code was setup to display it.
#define backup_voltage	 rxdata.rc_backup_batt*15.64/256
It does have that floating-point number that you might want to shift out of the way.
Unread 03-05-2004, 15:59
I would like to see it become a pure backup battery - not used to power anything unless the main battery droops
AND
I would like to see it charge from the main battery so you dont have to unplug it and charge it separately. We were able to keep the same main battery in our bot all the time at the events this year, and only needed to put the 6A charger on it between matches to keep it topped off (our drivetrain was very effecient this year)
it would be even better if the backup battery had a charge path back to the main battery so it would stay charged all the time - even when the main breaker and the RC are off.
oh, one last thing: I want the letter "M" stricken from the english language!
Unread 03-05-2004, 16:04
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
AND
I agree with everything you said, Ken, except that i bet FIRST won't allow the last part about it charging when the main breaker is off. FIRST wants to be sure that absolutely all possible circuits to the main battery are open when that breaker is off. Logically, it sorta defeats the purpose if you do bypass the breaker with anything.
Team 1257
Unread 03-05-2004, 16:23
Carpe diem
AND
I would like to see it charge from the main battery so you dont have to unplug it and charge it separately....
Ken posts and the forum readers go wild!
Excellent idea Ken. IFI, if you're lurking on the boards, this is what I want for Christmas next year.
Unread 04-05-2004, 05:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Gee Mike, I wonder what gave you the idea to post this thread??
I would like to see it again, but as an optional feature that you are not required to use. If you do not choose to use it, then you take your chances with resets.
Unread 05-05-2004, 07:31
Hello everyone!
The backup battery was a great addition to the new controller. It does cover up faults that would have been obvious in the past. If your drivetrain was so current hungry in the past, the low voltage dropout would have alerted you to something being wrong. Without that big indicator, many teams now are going into competition with problem drivetrains that have no indication of problems until they break or die from lack of main battery voltage. That makes it really tough on your alliance partners.
The backup battery powering servoes is another problem in that teams with many servoes risk losing the backup without any previous indication. Although everything on the robot is running fine, none of the servoes work. I think it might be an easy thing to add a charge path from the main battery to the backup for charging and powering the servoes. Since the guys at IFI are really smart, I am betting they have already started working on this.
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
