Go to Post Who knew a single variable could be so deadly? - 3DWolf [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 01-05-2004, 23:56
JakeGallagher's Avatar
JakeGallagher JakeGallagher is offline
Mmmm Hot Sauce
#0134 (Team Discovery)
Team Role: Operator
JakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant futureJakeGallagher has a brilliant future
Send a message via ICQ to JakeGallagher Send a message via AIM to JakeGallagher Send a message via MSN to JakeGallagher Send a message via Yahoo to JakeGallagher
Problems with a video!
I'm having some problems with a promotional video a team mate and I created...It's too big...for a 3:24 video, its about 630 MB. I've looking to encode it into something a little smaller, preferrably without having to buy software, but I don't really want one of those little DivX insignias on the corner...is there a way anyone can help us out? Thanks.
[Edit]
I forgot to tell you that the video is in .mov format, but if the tool you give me can change it to a Windows standard (*shudders*), or if you know of another tool that can do that...I know I'm being picky, but I really want to get this video circulated to everyone I can, and at the moment, it's just not possible.
Thanks again.
[/Edit]
I haven't updated my signature since last May. Who wants to suggest a replacement?
Unread 02-05-2004, 00:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Problems with a video!
If you can put it on CD and mail it to me, there's a chance I can reduce the size, put it on CD and mail it back to you. But I couldn't get to it until at least a couple weeks from now.
Unread 02-05-2004, 00:20
Brian M. Brian M. is offline
CGA Team USA-Also On FRV Team 30
FRC #0500 (CGA Team USA)
Brian M. is on a distinguished road
The RAD Video Tools should be able to convert .mov files into DivX: http://www.radgametools.com/bnkdown.htm
Also, as talked about before, the DivX logo can be disabled from the "Decoder Configuration" dialog box. In the "Quality Settings" tab, check the "Disable Logo" box.
[ Team USA/500 : www.CGAteamUSA.org ]
- 2005 SBPLI Long Island Regional Engineering Inspiration Award
- 2005 SBPLI Long Island Regional Website Award
- 2004 UTC New England Regional Leadership in Control Award
Unread 02-05-2004, 16:40
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
[Edit]
Thanks again.
[/Edit]
If you have Quicktime Pro, you can encode your .mov into any video and audio codec you wish.
I like the 3ivx codec for video and ACC for audio.
The best method, is to use your video editing program to encode it into a smaller file.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 02-05-2004, 19:15
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Post Re: Problems with a video!
Depending on what you're looking to achieve (full-screen video playback, or windowed playback), the best thing to do is use a smaller resolution with a higher bitrate. If you check out the videos my crew and I made (http://www.moe365.org/video.php), we went with two versions. The high quality version is about 37MB. That used a variable bitrate setting in the DivX 5.0.1 codec. The low quality version is about 8MB using a set bitrate. Though these movies have a pretty low resolution, when you blow them up to full screen, you don't loose a lot quality wise. Hope this was helpful!
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Last edited by SuperJake : 02-05-2004 at 19:16. Reason: Made some englash mistakes
Unread 02-05-2004, 20:27
Mmmm Hot Sauce
Team Role: Operator
Thanks for all the help--I should be able to post the encoded version soon enough. I'll get it up somewhere when it's finished.
Unread 02-05-2004, 20:33
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Just run it through iMovie and set the encoding to a different setting
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 02-05-2004, 20:40
Mmmm Hot Sauce
Team Role: Operator
*Le Sigh*
I don't have a Mac that can run iMovie! :-C We made the movie in Adobe Premiere on my partner's dad's computer...and that's why it's in .mov. If it were in MPEG I think the file was about 2.6GB.
Ah well, I'll try to track down a recently built Mac...
Unread 02-05-2004, 20:49
GET IT ON!!
*Le Sigh*
.MOV is only a wrapper, not a codec. You can select any codec to make it a smaller file.
Rhode Warriors
Unread 02-05-2004, 21:32
MattK's Avatar
Tap it.
try exporting it as a mpeg than run it through virtual dub (free- just google it)
If you want to you can also use the windows media encoder (yuck!), its free and makes the file much smaller.
my myspace!
Unread 16-05-2004, 15:53
JAH's Avatar
JAH JAH is offline
My two weeks notice is in...
AKA: Jason Hoff
FRC #0234 (Cyber Blue)
JAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to behold
Send a message via AIM to JAH
If you made the movie in Adobe Premiere, wouldn't it be an AVI? But oh well, Premiere comes with a program called Cleaner 5 EZ. In Premiere, go to File--> Export Timeline--> Save for Web... It'll then open up Cleaner 5 EZ and give you some options of file formats and compressions ratios and stuff. IM me at jasfirst234 or email me at jhoff@cyberblue234.com if you need more help.
Jason Hoff
Team 234
"Red, White, and CyberBlue..."
2006 Arizona Regional Imagery Award Winner
2006 Arizona Regional Entrepreneurship Award Winner
2006 Arizona Regional Website Award Winner
2006 West Michigan Regional Website Award Winner
We've got 2 Woodies, Chris Fultz and Scott Ritchie.
Unread 15-04-2005, 23:36
RX782 RX782 is offline
RX782 is an unknown quantity at this point
Cleaner 5 is too expensive, Premiere has poor resizing techniques, and iMovie is Mac only.
My suggestions:
VirtualDubMod for encoding, AVISynth 2.5 for filtering (and linear editing), XviD or x264 (more cpu load) for compression, and the AVI container. Audio should be MP3 only because of MP3's common place amongst users.
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Cyber Blue 234 REAL Teaser Video JAH Robot Showcase 7 17-02-2004 00:06
video for demos ryanspensley General Forum 3 09-05-2003 12:45
rendered .avi problems Gunslinger 3D Animation and Competition 8 15-01-2003 18:50
Good video footage miketwalker General Forum 0 28-03-2002 17:14
