Go to Post Never underestimate the power of human ingenuity. - Wetzel [more]
Unread 02-05-2004, 14:48
omega's Avatar
omega omega is offline
omega is an unknown quantity at this point
Question window
does anyone here know any good code for programing a window in c++
similar to the defalt window for vb
Unread 02-05-2004, 14:58
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: window
Try on Google. There should be tons out there. Maybe you'd just have strip some extra stuff off.
Unread 02-05-2004, 16:08
omega's Avatar
Re: window
ok thz ill try it
Unread 02-05-2004, 16:46
Programming User
Re: window
ok thz ill try it
If you can't, I'll give it a try.
Unread 03-05-2004, 03:24
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: window
Well, it really depends on what you want this window to do. The most basic Windows program that creates a dialog box would just be something like this:
#include <windows.h>
int WINAPI WinMain(HINSTANCE hInst, HINSTANCE hPrev, PSTR szCmd, int iShow){
   MessageBox(NULL, "Hello, World!", "Simple Dialog", MB_OK);
If you want to do more complicated stuff, email/PM me and I can hook you up with some examples. Also, take a look at RoboGUI, which you can find at www.robbayer.com, as it contains a bunch of Windows code. If you're interseted in MFC, take a look at RoboEmu too.
-Rob
Unread 03-05-2004, 07:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: window
If you are using MSC++ 6.0, the 'Dialog' resources are what you're looking for. Either that or do it all in code.
If your using .NET, haven't a clue.
Unread 09-05-2004, 11:11
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: window
Forget about old-fashioned C-style Windows apps... too hard to create/manage.
Use MFC C++ projects for MSC++6 or .NET.
If you're using .NET 2002, use MFC. If you're using .NET 2003, you can try SWF (System.Windows.Form), aka Managed Windows Forms to write C#-style code. Note that managed code will only run on the .NET Framework.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Help with window motor HWRobotics Motors 15 11-02-2004 02:43
window motor connection albertgates General Forum 1 12-02-2003 17:18
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
Re: window motors archiver 1999 1 23-06-2002 21:56
