Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 03-05-2004, 14:47
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Do it over
Perhaps this is in the wrong area?
Perhaps there are other threads about this subject?
Or perhaps I am just confused and missing something.
-Andy A.
Unread 03-05-2004, 17:39
Billfred's Avatar
Billfred Billfred is offline
Re: Do it over
1) I wouldn't have crashed the robot when test-driving it.
2) I would've stood up for myself more.
3) I wouldn't have let the robot tackle me on the last build night.
4) I'd have said that this arm would never hold onto a 2X ball.
But hindsight's 20/20, right?
Unread 03-05-2004, 17:45
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Do it over
Robot designs-
Hang from floor
goal grabber
thats it...
Helped more in build
decide between the things I do around robot time
And most of all try to have taught some more newbs. I got a few this year, but the more the better. .
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-05-2004, 18:10
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Do it over
If i could do it over i would have set aside more time for doing schoolwork.
Penn Class 08
Unread 03-05-2004, 18:56
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Re: Do it over
I can't change this year but next year I will work harder to convince everyone from the start that smaller points (ie. 5pt balls, herding, capping) is more important than the large points (ie. hanging), which I failed at this year. But hey, it stilled turned out well
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 03-05-2004, 19:28
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Re: 'If' we could do it over again...
I would love a smaller, faster, lighter robot that could go up the small stairs and
hang faster than our current one. The bot would also have a scoop at the front for easy ball moving, and (I don't know if this is legal) a stick to keep the ball release from activating for more time to get a mobile goal underneath for quick points or to prevent the opponets balls from releasing. =)
Crazy idea: a snake bot that would crawl up the 10 foot bar and the coil at the top.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 03-05-2004, 19:32
Re: If you could do this game over
Well, I would probably start the program for the bot a little before the bus ride to new jersey
Unread 03-05-2004, 22:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
#25 chain for drive, plastic roller chain and sprockets instead of rubber timing belt and pulleys for lifting arm, bigger reduction on lifting arm, omni wheels, rollers for pushing balls.
Unread 03-05-2004, 22:12
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
I would have spent more time on mechanisms, made the frame lighter to begin with. Would have made sure that all of the connecting links for the chain werent hitting on anything when I replaced them. Learned more about CAD, loosened up some, and had even more fun.
-Aaron
But none of this matters......unless we apply it to next year. One of our mentors came up with the idea of having everyone write down anything that we learned, solutions to any problems we had, and tips for building the robot. This way we have hard copy and everything that is learned one year is not lost the next as we are only a two year school.
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
