Go to Post ¡viva la weight réduction! - NoSkaOnTheRadio [more]
View Poll Results: What did you think of the Backup Battery???
It was a good new feature i wanna see it again. 54 59.34%
It was ok but a pain at time (neutral thoughts). 25 27.47%
Why did we have to use it, dont bring it back! 10 10.99%
Other, post your thoughts below. 2 2.20%
Voters: 91. You may not vote on this poll
Unread 03-05-2004, 16:04
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Backup Battery...Yay or Neh?
Originally Posted by KenWittlief
I would like to see it become a pure backup battery - not used to power anything unless the main battery droops
AND
I would like to see it charge from the main battery so you dont have to unplug it and charge it separately. We were able to keep the same main battery in our bot all the time at the events this year, and only needed to put the 6A charger on it between matches to keep it topped off (our drivetrain was very effecient this year)
it would be even better if the backup battery had a charge path back to the main battery so it would stay charged all the time - even when the main breaker and the RC are off.
oh, one last thing: I want the letter "M" stricken from the english language!
I agree with everything you said, Ken, except that i bet FIRST won't allow the last part about it charging when the main breaker is off. FIRST wants to be sure that absolutely all possible circuits to the main battery are open when that breaker is off. Logically, it sorta defeats the purpose if you do bypass the breaker with anything.
Team 1257
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
