Go to Post anything that craves Mountain Dew is definitely intelligent enough to be dangerous. - IMDWalrus [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 04-05-2004, 09:29
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: Tank Treads
www.brecoflex.com
amazing belts, we have run all the weeks of testing, a regional, an soon to be like 4 offseasons on our first set. They have some amazing traction, we were never pushed at BAE. they are also self tracking to prevent throwing belts.
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 04-05-2004, 10:07
cazbar171 cazbar171 is offline
AKA: Eric Casper
#0171 (Hard Core Engineers)
cazbar171 is an unknown quantity at this point
Re: Tank Treads
which item are those in the catalog?
Unread 04-05-2004, 10:11
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: Tank Treads
The biggest thing to keep in mind with tracks is the strength of the track. You don't wanna be blowin your belts. I suggest the brecoflex tracks also. Our team had quite a large amount of success with them this season. They are easy to work with and have awesome traction...almost too much traction. You just gotta be careful how much you put on the ground. In the past weve also used timing belts. They are okay but I'd take the brecoflex tracks of them anyday.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 04-05-2004, 10:14
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
Re: Tank Treads
Originally Posted by Greg Perkins
www.brecoflex.com
http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=6139&direction =DESC&sort=date&perrow=4&trows=3&quiet=Verbose
What series and size of belts did you use from brecoflex? also did you have any problems turning on the carpet with the treads?
-Aaron
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
Unread 04-05-2004, 10:24
AKA: Mongo
Re: Tank Treads
we did have a problem turning...however the reason was we had so much of a footprint on the carpet. we easily fixed that by increasing the center idler pulley of our drive. we are now able to turn on a dime and have an amazing amount of torque.
as for the series, ask Pat (team134guy) he should know. i dont know off the top of my head
Unread 04-05-2004, 10:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Tank Treads
According to my handy dandy Brecoflex binder, Linatex, Super grip, Correx gum, PVC Blue, Polyurethane, and a few others have the highest CoF's.
I could go through the whole catalog and tell you what your options are, but that'd take way too much time
Go to www.brecoflex.com and order one of their free product catalogs. They'll send you a binder with whatever inserts you choose. They sent me mine in two days, if I remember correctly, and they come with a wealth of information.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-05-2004, 12:51
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Re: Tank Treads
We used Brecoflex as well. We used used two "bogy" wheels on each track toward the center of the bot that were about 1/8 of an inch lower that the others. This greatly improves turning. We also used spring loaded tensioners to keep the tracks tight rather than having one sliding wheel that you lock in place. We've used this system for two years now and never had a belt come off or break.
- Gene Falendysz
Unread 04-05-2004, 18:36
Mechanical Engineer
Re: Tank Treads
I couldn't find a series number. I believe its a custom belt so this is what we have. We used a PVC base backed 75mm wide w/ I believe a polyurethane timing belt. We got the self aligning tooth assortment w/ two pulleys to match. Def use the pulleys. Theyre designed for this track and will save you some machine..SOME they are heavy so youll have to take some out. I'm not sure on the length....but you can figure out what you need.
You can use this catalog though. The selection is nearly endless, you can mix and match til you find what you like.
BTW we did have trouble turning. My suggestion is put a larger center idler in to help reduce the footprint. We went w/ i believe 4 one hundreths of an inch.
To keep tension we used a piece of threaded rod with the axle. The base was slotted so it could slide. Then just double nutted it. Illustrated below. n=nut O=axle
n
n
n
O
n
n
n
-Pat
2010 and Beyond
Unread 04-05-2004, 22:32
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Talking Re: Tank Treads
What exactly do you mean when you say you reaised the center pulley to decrease the footprint. IF you would like i can include a CAD drawing of what i have in mind as far as how we want to lay things out.
"I'm sorry, after all he is just a wookie!"
Unread 04-05-2004, 23:00
AKA: Mongo
Re: Tank Treads
yes if you looked at the side of the bot, the middle idler pulley was set about a half an inch below the other two pulley, ccutting the footprint in half but making it turn
Unread 05-05-2004, 20:07
Cory's Avatar
AKA: Cory McBride
Re: Tank Treads
Nobody has mentioned cost yet, surprisingly. Just a belt can set you back around $200, if I remember correctly, and the pulleys for the belts will cost you a pretty penny as well. Most teams who use treads end up needed more than one belt obviously, since they tear, wear down, etc.
All this adds up to quite a bit, and can be very prohibitive for some teams.
Cory
2001-2004: Team 100
Unread 05-05-2004, 21:45
Mechanical Engineer
Re: Tank Treads
Cory
Yes the brecoflex will cost you. But these belts are built specifically for this application. They are built to last. We are still on our first set of belts. We've gone through practice and testing, demos a competition and within the next month and a half two more. We are comfortably within the belts working limits. They are very durable belts (least the set we are using).
You really gotta look at your application and and cost benefit relation.
-Pat
2010 and Beyond
Unread 05-05-2004, 22:24
Cory's Avatar
AKA: Cory McBride
Re: Tank Treads
-Pat
They may have worked fine for you, but they really aren't built for this application. They're built for material handling, in factories, etc. We often put tons of torque through them, and much more wear than they will ever see in a factory.
I know for a fact that teams like 226 and 61 have torn multiple treads in half until they got some super reinforced version of the belts for like $300 if my memory serves me correctly.
I have heard from multiple teams that they have had to replace their treads at least every competition, especially last year with the cheese grater ramp, which adds up to a lot of money.
Personally, I think the decision to use tracks or not comes down to money, more than anything else.
2001-2004: Team 100
Unread 05-05-2004, 23:01
Mechanical Engineer
Re: Tank Treads
I agree whole heartly in what your saying. One of the biggest things with tracks is that you need to make sure that you have attiquit(spl?) belts. I think the belts we used this year would have probably shredded last year. You have gotta match the right belt to the application. I know I've seen alot of teams use too thin of a belt (specifically brecoflex but im sure there are others) and watched it tear in half. Obviously it wasnt strong enough for the job. We used a 75mm belt. Thats a fairly wide belt that your less likely to tear. There is always the possiblity of tearing. Thats a part of the cost benefit relationship.
SO to my point i agree with you cory.
-Pat
2010 and Beyond
Unread 06-05-2004, 16:14
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Re: Tank Treads
Yeah 300 is kinda low closer to 400 i belive for a set. We have still torn those belts but the center stays connected so that its alright that the out side tore. The bad part is we would rather break a track then burn out a moter. Throught just testing automode last year and kept hitting the side the moters where really hot. We did not run with them becuase if we had to fight for the top they would not slip at all and our moters would burn out.
We just use different traction. There are four kinds. Slicks, Red Slicks (Not thick red on the track), Thick Red (Thick red on the track) and Green (The most traction you will ever need). Last year was good for the thick read. Did not mess them up. Once we tore one it sliced the red slick to peaces. This year the thick red was awsome! Great on the surface to climb!
My adivise. Dont go with the Green unless you have the solid center. Go with either the Slick Red ones or the Thick Red ones. Having a pair of just slicks is a good a idea for emergencrys.
Check out our web site at. www.valleytech.k12.ma.us/robotics
Keep It Simple - Team 61's Motto
Any Thing on out Robot Can be Fixed in 5 Mins!
2005 Motorola Quality Award
2004 Battle Cry 5 @ WPI Eighth Finalists...4th Seed! 6-3 Record! Thx 237 & 830!
2004 Mayhem on the Merrimack Champions! 4th Seed! 9-2 Record! Thx 562 & 1289!
2004 Mayhem on the Merrimack Fastest Robot Award!
2004 Beantown Blitz Champions! 4th Seed! 11-1 Record! Thx 571 & 1100!
2004 National Semi Finalists
2004 Florida Regional Judges Award
2004 Florida Regional Champions! Thx 945 & 386!
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
