Re: Tank Treads
We used Brecoflex as well. We used used two "bogy" wheels on each track toward the center of the bot that were about 1/8 of an inch lower that the others. This greatly improves turning. We also used spring loaded tensioners to keep the tracks tight rather than having one sliding wheel that you lock in place. We've used this system for two years now and never had a belt come off or break.
| Swerve/crab drive and tank turning | activemx | Technical Discussion | 9 | 23-02-2004 18:26 |
| tank treads vs. threaded wheels | lj8758 | Technical Discussion | 14 | 24-01-2003 00:30 |
| Under or Over? To tank or Not to tank that tis the question! | archiver | 2001 | 2 | 23-06-2002 22:53 |
| TANK TREADS...welp. | archiver | 2001 | 13 | 23-06-2002 22:50 |
| What problems have you encountered using treads? | M.I. | Technical Discussion | 8 | 15-01-2002 22:13 |
