Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 04-05-2004, 11:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
How do I save a quicktime .mov file?
I want to save a quicktime movie file locally, namely for example:
THIS ONE
It's embedded into the webpage. I found the actual hyperlink directly to the movie file, and opened it in Quicktime media player, but alas, there was no "Save As" option available to me?!?!?
Anyone know of any feasible way to save a QT .mov file like this particular one?
I even tried opening it in WMP, with no luck at all...
Oh, and watch the movie if you feel like it. It is really cool, hence why I want to save it locally.
Unread 04-05-2004, 11:23
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: How do I save a quicktime .mov file?
You could make an HTML file on your home computer with a link to the movie file, and then, in your browser, right click and use the Save As function.
Most of the time, when I have the link to something I want to download, I use the program "wget" for linux, but I'm not sure how available that is to you.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-05-2004, 11:24
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
THIS ONE
You have to view the source of the website. Find where the movie file is actually stored on the web server. Then create a link to it in a regular HTML file. Then right click your link, and choose "Save Target as".
I did that for you though. Here's your link: http://www.blur.com/quicktime/480x360/rockfish_480.mov.
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
^ Or what they said ^
Use this URL
Then open the Quicktime movie player on your PC and do an "open url."
Paste in that URL and then save as.
Purdue Alumni
Cummins, Inc.
Unread 04-05-2004, 11:27
Wow.. 3 responses in only like maybe 3 minutes. Sweet!!
Well, I feel like an idiot now, this solution was so simple, I overlooked it.
Thanks all!!
Unread 04-05-2004, 13:52
Kevin Watson's Avatar
La Cañada High School
FRC #2429
I want to save a quicktime movie file locally...
As others have suggested, save this code to a file with the extension .htm or .html. Just place your link on the "href=" line, save it and then open it up in your browser.
<html>
<head>
<meta http-equiv="Content-Type"
content="text/html; charset=iso-8859-1">
<title>Get That Web File</title>
</head>
<body bgcolor="#FFFFFF">
<p><a
href="http://www.blur.com/quicktime/480x360/rockfish_480.mov">Right-click here
</a></p>
</body>
</html>
-Kevin
Kevin Watson
http://kevin.org
Unread 04-05-2004, 14:30
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Bah! Make a web-page and then use that to download the file. Sure, it'll work, but there's a more elegant way ... I just can't resist:
# get_movie.pl
use LWP::Simple;
$movie_file = $ARGV[0] || "http://some.site/foo.mov";
$download_name = $ARGV[1] || "mov01.mov";
$movie_content = get($movie_file);
open(MOVIE,">//path//to//your//favored//download//directory//" . $download_name);
binmode MOVIE;
print MOVIE $movie_content;
# note that code is untested
# and you should always use warnings/strict!
Now you have a solution that'll work as many times as need be. Just type in movie.pl movie_url_address foo.mov and voila. No need for a two-step process once the script is done. Overkill? ... I think not!
Unread 04-05-2004, 14:36
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
What I do is open up the file in the quicktime player and export it.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 04-05-2004, 16:38
The problem is that not everyone has (or wants to have) Perl installed on their computer. Everyone who has access to CD, on the other hand, has a web browser installed.
Also, that rockfish thing is pretty cool. Thanks for having this problem, Elgin!
Unread 04-05-2004, 19:45
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
im pretty sure that if you go into your temporary internet files, it will be there, so you can just copy/paste it
Unread 04-05-2004, 20:41
mtrawls's Avatar
Well, that just identifies a more serious problem than not being able to save a movie file, no? A problem quickly remedied, however. And recognizing that my solution might not be too widely used, I offer it to at least demonstrate that TMTOWTDI*. (Granted, there're some ways to convert a perl file into an executable that can run even without having the perl interpreter installed; probably too much trouble than it's worth though. )
* There's more than one way to do it. Coincientally enough, the motto of perl.
Unread 04-05-2004, 20:58
Hehe. Just joking at this point. I once heard a response to this statement, and it went something like this:
"There is only one way to do it, and that is in C.
Learn C, you hippies!"
I apologize if this sounds offensive. I posted this in purely a humorous intention. I consider myself a hippie, too.
Unread 01-02-2005, 22:23
lcmessage lcmessage is offline
lcmessage is an unknown quantity at this point
Re: How do I save a quicktime .mov file? HELP!
Hey guys,
I tried all the methods you said - but i still can't download the movie. In fact, it's off of a secure website (you know like before i access the page it says all that "this website is secure blah blah do you wish to continue?").
Does this mean that it's impossible to download the .mov then?
- Lance.
Unread 01-02-2005, 22:35
Originally Posted by lcmessage
Hey guys,
- Lance.
Right click the link above and "save as" or whatever the equivalent is on your type of computer/OS/Browser.
Unread 28-02-2005, 16:06
huskyboy huskyboy is offline
huskyboy is an unknown quantity at this point
Having trouble downloading these files:
http://www.ats.ucla.edu/stat/seminars/ed231e/
save as lets me download a .mov file but the file is less than 1kb... opened it with text editor and it just has information to another link... tried to use that link to get the file and could not...
any advise?
need from lecture 2 and beyond
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
QuickTime or .MOV to AVI or MPEG archiver 2001 2 24-06-2002 02:00
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
